Question about Fuji FinePix S7000 Digital Camera
OOPS- Sorry about the error in the post above-our lines run horizontally. Thank you.
  • 3 more comments
  • cbartholomew Oct 25, 2008
    We have the Fuji FinePix S7000 digital camera and recently it started getting horizontal lines like interference across the picture. There are 2 lines that remind me of those that old VHS tapes used to get. After these lines appear the camera shuts itself down. We've replace batteries at least 6 times and nothing will fix it. Thank you.
    Yes, the horizontal lines show up on the viewfinder and if you can get a pic in before it shuts down, they show up in the pic too. Thanks
    Thanks so much mistersony, you've been helpful. I hate to have to send it in but at least we know what the problem is and can be taken care of. Have a great day!!! You're the best.
  • Any Guy
    Any Guy May 11, 2010
    OK saw your previous post. So you get vertical lines on the LCD screen and then the camera shuts off? I believe that camera also has an LCD viewfinder; if so, do you see the lines in the viewfinder as well as on the LCD screen on the back of the camera?
  • Any Guy
    I'm sorry, I didn't see your previous post, could you detail your problem for me again? Thanks..
  • 320 Answers
The lines you are seeing are likely caused by one or more components that have failed in the internal power supply of the camera. That is also consistent with the camera shutting off. I'm sorry but your camera will have to be serviced. I'm sorry to have tell you that, but if you appreciate my advice, please rate my solution, it is appreciated. Thanks
Posted on Oct 25, 2008
  • Any Guy
    Any Guy Oct 25, 2008
    Thank you for the rating, it is much appreciated!
Probl?me avec e-tec 150 hp 2006 Moteur calle ? 2000 trm . merci !
English please.
your welcome. no french here.
but tell what PC
oops you posted HP computers for a car.
sorry.
Aug 06, 2017 | Boating
My suzuki swift 4WD 2007 model speedometer not working DTC error code p 1777
double posted?
replace the speed sensor.
the SM covers all this, ever seen a service manual.
is this a USA car,?
you posted to USA forum. so...
DTC errors are based on
engine and trans in your car, called the Drive line
we cant guess that ever. why work on car not knowing whats there>? how can you buy parts or read correct chapter in the service manual lacking this 1 key fact.?
the speed is dead most times with VSS dead.
replace VSS , clean it or fix its busted up wires.
swift or swift +
we only have 2007 in canada no USA< so why not say country first
why must we beg?
2004 to 2011 in canada, sorry cant do outside N.America, sorry.
ill look up the canada codes, is speedo in KPH?>?>>?>>>
swift non + ended 2001 here.
oops my source of books has no canada swift books.
answer:
the VSS can only be in 2 spots.
under hood, (there is one other exception)
1: on the axle near (pinion ring gear), to measure speed.
2: on some cars the ABS wheel sensors.
In case 2 , the ABS knows speed and simply tells the PCM speeds at all times and in turn PCM sends speed data to the CLuster.
are all fuses good.?
Mar 16, 2017 | Suzuki Swift Cars & Trucks
Horizontal lines on screen
Visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu at the left top corner or the display window. It will make search easy. Some times, the ads attached with each posts might help you to find the availability of spare parts. There are more than 580 posts to different brand TVs.
Aug 13, 2012 | Samsung PN42C450B1DXZA PN42C450 42 Plasma...
Wavy horizontal lines across the screen
It sounds that the main power supply section to your TV has the fault. The horizontal thik lines that appears crawling down across the screen should be of video 'HUM'. Have you replaced the main filter capacitor at the power supply section? If not, replace it along with the main rectifier. The AC power is rectifed by a bridge and applied ot this main filter capcitor. It will have a capacitance value between 120 to 350MFD 450VDC. Check this section. Measure the rectifed DC voltage acorss this main filter capacitor. It should be around 350VDC, if your home power supply line is 220VAC. If it is 110AC, this DC voltage will be around 165VDC; and it should be. If rectified DC voltage found lower than the input AC voltage, replace the rectifier bridge. In some sets, this bridge section have four diodes. Some other circuits, a bridge rectifier stalk may be used.
May 20, 2012 | JVC AV-27050 TV
I have the same problem
Oops...looks like I messed up on the one above you. I didn't realize until after I hit answer that it was a downloaded game and not the actual game...my bad. Sorry about that.
The downloaded games tend to do that...you need to download a translator.
A lunar IPS patch utility I guess.
I'm not a computer guru by any means. I just wanted to clear up the fact that I messed up on the other post. Sorry about that.
Sep 16, 2009 | Nintendo Pokemon Yellow Version: Special...
Horizontal lines across TV screen Panasonic CT-31SF13U
The problem sounds like a vertical deflection issue form what you describe.
On average they are usually in the simple repair categories. On average they would run in the $50 range if you take it to a reputable repair shop.
There are several possibilities
Bad capacitor (s)
Bad vertical IC
resistor in the power supply to the vertical circuit changing value
Jan 24, 2009 | Zenith B25A10Z 25" TV
When I send email I keep getting a message that there was a error in a previous email that I sent
Im sorry, but because you have not answered my questions above, I cannot help you further. please try and do what I said in the above posting which is:
"If you are using an on-line email (such as Yahoo, Googlemail,hotmail etc) then the only thing that comes to mind is that you havenot typed in the email address right.
For example:Someone@yahoo,com is wrong as it should be a "."(dot) not a "," (comma)but they can look very like each other depending on what font you areusing in your browser.
However, if you are using an off-linereader/email program, like Outlook Express, then the problem could bewith the set-up of your pop account etc.
Thank you
Aug 23, 2008 | Computers & Internet
TV - Thin horizontal line picture on screen
Is this a LCD TV? IF it is it could be something on the video processing board. Let me know the model # and well will go from there. Thank you Jay
Jan 31, 2008 | Televison & Video
Canon ZR200
Hey,
I just started to have the same problem, 5 grey lines and intermittent audio. I the settings and i tried different tapes and No Joy. Then I tried to record onto an old tapes to see if the new recording would do it and the camera showed me a strange icon for exposure. I set the exposure back to 'Easy' and Viola, I recorded and the playback is now clean. Even old tapes play OK now...
The settings must have gotten wacked somehow. I glad it worked out, good luck.
Oct 06, 2007 | Canon ZR400 Mini DV Digital Camcorder
Fuji FinePix S7000 Digital Camera Logo
54 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
