Question about GE Washing Machines
GE harmony washer bleach dispenser clogged
Bleach dispenser has lately not totally emptied, and so is sporadically bleaching other loads, and ruining various clothes. Tried pouring hot water in dispenser several times, its coming out overflow tube. wondered about blowing air somehow in there....
  • 100 Answers
SOURCE: LG TROMM WM2487 Bleach not getting fully removed after cycle
Keeping in mind that the bleach gets dispensed into your wash on the second to last rinse cycle and that most all rinse cycles are in cold water.  Is your cold water valve screen plugged causing your washer to rinse poorley?  Are you using the HE detergent?  If not maybe the washer is sudsing up to much and haveing a hard time rinsing all the suds and bleach out.
Fill the washer up with no clothes in it on a cold/cold wash setting does it take a long time to fill the washer up?  Also when it is full and agitating is there suds in the washer?
Last suggestion is if the drain is hose is alot higher than the top of the washer it might have a hard time draining out all of the bleach water before the next load
Posted on Oct 31, 2007
  • 1294 Answers
SOURCE: Leaking water from the Liquid chlorine bleach dispenser
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Jan 13, 2008
  • 14 Answers
SOURCE: Liquid Bleach dispenser doesn't work correctly
This may not be relevant, but by design, bleach does NOT dispense in the Buly/Bedding, Kids Wear, and Silk/Ultra Delicate cycles. If you try to use it, it remains in the dispenser.
As for the yucky smell, leave the door open when not in use.
Posted on Apr 23, 2008
robocop
  • 90 Answers
SOURCE: Whirlpool bleach dispenser not dispensing properly
It sounds like the bleach dispenser is clogged or has a crack in it. What we do, is when we bleach our clothes and I know that this is extra work, but we wait until the washing machine is full of water, then add the bleach directly to the wash.
Posted on Jan 19, 2009
SOURCE: Bleach remains in bleach dispenser after washing and even after extra rinse cycle
I put the bleach in with the load right on top of the whites, so I dont have bleach left in the dispenser for the next load. Seems to work okay.
Posted on Jun 10, 2009
How to use auto bleach disspencer
put laundry in washer add detergent add bleach in the dispenser and start the machine . bleach goes into water below the clothes so it can never ruin stuff .
Feb 18, 2015 | GE Energy Star WCVH6260F Front Load Washer
Washing machine bleaching colored clothes by mistake
thanks for the question its possible that the bleach disp is clogged and when its suppose to release the bleach some stays hehind and theres still some left over from the last load i would check that thanks the appliance doc
Sep 16, 2008 | Washing Machines
GE WSXH208AWW doesn't dispense detergent, softner or bleach. Dispenser is totally dry after wash cycle.Appears no water gets to tray.
I'm having almost the same problem - the bleach & softener both will NOT dispense, but (LUCKILY) the detergent does dispense on mine, for now.
In order to get the solutions (bleach, softener, detergent) to go into the washer, the water needs to pour through the dispenser somehow. Dry means NOT working (mothmanmeg).
I need help, too!! We tried taking the drawer out & cleaning, no luck.
Apr 17, 2010 | GE WSXH208A Front Load Washer
Bleaching subsequent loads
I'm no repairman but here's a coupla thots:
1 - try running an empty load after bleaching. Save money and just use cold water. First add a few cups of water to the bleach dispenser to help flush out the old bleach that might remain, then run it.
2 - lemon juice is naturally acidic and should neutralize the bleach. You could add some to the bleach dispenser and do the above. Maybe mix a half-cup with a few cups of water and put in the dispenser, then run it. (Lemon juice [or vinegar] is good thing if you get bleach on your hands, too.)
OF COURSE -- Test to see if this works with a couple colored rags before running any good clothes through.
3 - How about using oxygen bleach alternatives (color-safe bleach) instead of regular bleach?
I suppose there could be a problem with your dispenser, idk....
Feb 20, 2009 | GE WBSE2090A Top Load Washer
Jan 18, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
The Bleach Cup
An overloaded machine.richardm69
Nov 23, 2008 | GE Profile WPRE6100G Top Load Washer
Bleach ruins colored load done after white load
Your bleach dispenser is the problem. It needs to be replaced. All of the bleach isn't leaving the dispenser so when you go to wash your colored clothing what's left in there comes out. Best thing to do till you fix it is wash your whites last. You can try running some white vinegar through the wash on the hottest cycle. Pour the vinegar into the bleach area and the soap area and run it on hot. Run it a couple of times. If there is anything clogging up the dispenser this might clean it out. Let me know if you have any other questions and good luck.
Oct 18, 2008 | Whirlpool GHW9300 Duet Washer
DARK CLOTHES END UP WITH BLEACH DOT STAINS
Hello sa-kap,
yYu said,
Hi, I have a top loading Kenmore Elite washer (don't know model #) from the year 2002. It has the automatic bleach dispenser. The problem is that if someone has washed clothes with bleach sometime during the day and someone else comes along and washes dark clothes, the clothes get ruined with dot bleach stains. It appears that the bleach remains in the washer. Any tips or do I need to buy a new washer? Any help would be greatly appreciated. Thank you
V.C.My problem is similar to that which VCasabona is having. Not just dots occur but often big splotches. It may not even be just a colored load following whites on the same day but, on occasion, it occurs on the next laundry day, a week later with the first load that is not the whites with bleach. Also, my wife adds the bleach to the filled washer (old school, I guess), rather than pouring into the dispenser. My water pressure, which is not at issue, is not what I need to address to remedy the situation. I have noted that the ledge that is part of the floating tub had some build-up of deposits, some of which may have been bleach. These I've reached in with damp cloths and removed as best I can. I've run full, empty loads through hoping this would flush out any lingering bleach. Because the occurrences run intermittently from infrequently to frequently I cannot be sure if any of my attempts to remedy the problem are having any effect. I've guessed at the model # of the Kenmore top load washer we own since Dec of 1999
Sounds like some water is remaining in the tub after the pump gets done emptying the washer.
So its the pump!
The Kenmore Elite is a good washer and I believe worth fixing!
Unless the cost is half the price of the cost of a replacement.
Bless You,
Please write me a good rating before you sign off.
Jun 20, 2008 | Kenmore 24032\24036 Top Load Washer
Reimbursement for ruined clothes
you should never put bleach in the dispenser ,
unless it is colorfast bleach.
always add bleach diluted directly in the drum to prevent this from happening in the future.
the dispenser may never clear the bleach fully.
check is in the mail.
Feb 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Nov 16, 2007 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Washing Machines Logo
37 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
