Question about Brookstone MightyMax Tower Fan
Power on but no action
Remote does not work either
Why did the remote suddenly stop working?
Try disconnecting power at the source, not a switch. Wait for a minute or so and turn on the power again. This action may "reset" the receiver. You also may find that remote control is restored after a power outage. Finally, if nothing else works, you may have to install a replacement Lutron receiver.
Aug 16, 2015 | Lutron Electronics MIR-ITFS-LF-WH...
2003 Honda pilot door locks and remote not working
There is a small electric motor inside the actuator assembly that has probably "burned out". Same problem with my 03 pilot. The remote would not lock the other doors or arm the security system unless you physically locked the driver's side door. Eventually my passenger side burned out as well. Fixed it myself pretty easily. Cheap fix too. works like new now. http://www.ebay.com/itm/120935451126?var=420082237231&ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
Sep 05, 2012 | 2003 Honda Pilot
HL-t6187s control problems
Check with Samsung, your model falls under a class action settlement related to power supply issues that your TV may be experiencing. Here is a link to more information about this settlement.
http://www.ccl-la.com/blog/index.php/samsung-has-reached-a-settlement-in-class-action-lawsuit-over-faulty-tv-power-supplies/
Jul 16, 2012 | Samsung HL-T6187S Television
Tv has no power button.. remote works cant turn on tv with remote (not linked up)
Unless the TV is in the standby position there will be no power to the processor circuit and IR detector which is needed to process the incident signal from the remote to the processor for action.
If there is no standy check the power and the processor +5 which is most critical.
Nov 07, 2011 | Sharp G0797cesa Remote Control
The remote actions things twice with one button push
technically we call it debouncing it causes due to the faulty microprocessor in remote also it can happen due to faulty carbon contacts of remote below buttons.the solution to this is to replace remote but before that do one thing 70% THIS WORKS open ur remote then take a dry cloth & clean the surface below buttons if u r lucky then remote will be OK
Mar 14, 2010 | Logitech Harmony 550 LCD Remote Control
My samsung ws28a116d remote will only adjust the volume and mute the tv no other actions seem to work , is it possible to adjust the picture size without the remote ?
To reset the remote so that it works properly again, take the batterys out of the remote, then press and hold the power battery for at least 30 seconds to drain out any power left in the hadnset , then replace battterys and it should work again. We had this fault and this solution worked for us
Aug 28, 2009 | Samsung Televison & Video
Cant turn off panasonic PIP
To turn off the "stuck" pip on a Panasonic tv without a remote, turn off the tv. Then hold down the "Action" button on the front of the tv and press the power button. This will activate a reset and self check of the systems and voila! The pesky pip screen will be gone! This is on an approximately 10 year old regular crt "CT-xxxxx" series tv.
Jun 12, 2008 | Panasonic CT-36D32 36" TV
Turning off PIP without remote
To turn off the "stuck" pip on a Panasonic tv without a remote:
1) Turn off the tv.
2) Then hold down the "Action" button on the front of the tv and press the power button.
2-b) Continue to hold down the Action until the tv powers all the way up, and the reset menu comes up - be patient.
Expected Reslut: Self check menu should appear.
Expected Reslut: The pesky pip screen will be gone!
If the self check menu does not appear, you did not hold the Action button long enough.
Simply begin from step one.
Thanks to Imhiro
Sep 28, 2007 | Panasonic CT-36D32 36" TV
Ilo 26inch HDTV Remote will not work TV
ok, i own the 26in POS and about 7 months into ownership it becomes unresponsive to manual buttons and remote(except power). the conditions that may have caused this problem may have been heat.....BUT if you turn the ilo COMPLETELY off(no standby) for a day or two it should start working again. mine always has.
Aug 16, 2007 | iLO 3200 32 in. LCD Television
Dryers Logo
37 people viewed this question
Top Brookstone Dryers Experts
Dan Webster
Dan Webster
Are you a Brookstone Dryer Expert? Answer questions, earn points and help others
