Question about Fostex Mr16hd 16 Track Digital Recorder
I refcently purchased a MR16 Fostex it comes on lights up and shuts down . What is possibly wrong ?
    Genius:
  • 1,212 Answers
Power supply. Most likely an electrolytic is failing. It may or may not show any signs of it. Other possibilities are bad solder connections, loose wire connections, or possibly a bad MOSFET if it uses a switchmode power supply. Also check the general construction to make sure nothing is shorting internally. Sometimes wires get pinched.
Posted on Feb 15, 2012
You have to hold the power button - all the buttons will flash and then when the LCD display lights up you can release the power button
Posted on Oct 27, 2012
  • Mordechai Jones Oct 27, 2012
2 Suggested Answers
  • 5603 Answers
SOURCE: For a long time I have been recording on my MR16
Likely you will need an updated driver software compatible with WIn7 for the Fostex. Check the Fostex site for update.
Posted on Sep 10, 2011
How can I record my songs to my tablet or my laptop
The best way is to use the USB output from the Fostex. Connect the USB cable from the Fostex to the USB input of the notebook. A Windows computer should show a USB Audio Device in the device manager. If not, you'll have to get a driver from Fostex and install that. But it should just work, it did in my Vista notebook. Then simply get any number of recording software packages (Windows 8 may have a built-in app). I've used Cool Edit and Reason 4 for recording and editing. You should not record the songs using the notebook's microphone input because (1) the analog noise of a recording generated by the notebook's A-D converter is horrible, and (2) you'll have level and impedance matching problems, even after purchasing something like a pair of Bogen WMT1A line matching transformers. Once you've got it recorded, put it in the cloud and download it onto your tablet. I don't think tablets have USB ports, but maybe yours does.
Jan 12, 2015 | Fostex Mr16hd 16 Track Digital Recorder
How can I fix my Fostex mixer?
Sound lime a faulty rom have u tried to upload the firmware again
Nov 21, 2014 | Fostex Music
I can only hear static through the headphones on my Fostex MR16. The recording sounds fine when I transfer to computer, but I can't hear myself playing.
They make headphone amps that will take a line level and boost it in volume until it can drive headphones. I'd get one of those, and plug it into any available "line out" or "rec out" on the back of your Fostex. Sounds like the D/A converter section that feeds the headphone output has gone bad, and my solution will get you around that.
Nov 27, 2013 | Fostex Mr16hd 16 Track Digital Recorder
How long should it take to format a Fostex MR-8HD 40 gb drive?
The speed will depend on the speed of the processor used. However if it has not finished after 8 hours, shut it down and restart if it seems the drive is in endless loop. Check jumper settings before you restart..
Feb 06, 2012 | Fostex Music
Fostex MR-16 Multitrack Recorder The screen
Hi, try and reset it. it will come back to normal.
Take care.
May 18, 2010 | Fostex Mr16hd 16 Track Digital Recorder
My Fostex mr8 hdd "full"
If you can reformat the drive after dumping out anything you want saved MIGHT fix the problem...
The unit MAY not be able to tolerate fragmenting when you delete a snippet here and there... It may require large blocks of contiguous space.
Feb 27, 2010 | Fostex Mr 8hd CD 8 Track Recorder with CDr
I have the Fostex MR-8 mk II without the burner. I'm having trouble as of late at exporting my finished song to a laptop computer. It's worked fine in the past. Could it be my USB cord is bad? The computer...
USB cords are cheap and can often be found even in Thrift stores... try a new one to eliminate that possibility... I will say they RARELY go bad unless they have been abused.
Remember that reading a USB stick by the computer is FAR different than transfering data from the Fostex...
MAKE SURE the driver for the Fostex in your computer is intact...
OFTEN the stupid DLL files that were working get CLOBBERED by new software and suddenly old things that used to work don't anymore... Thank MS for the stupid thing of allowing new software to change DLL's.
Jan 07, 2010 | Fostex Mr 8hd CD 8 Track Recorder with CDr
It stays stuck on home screen.it was not plugged in to power protecter when the power turned off . My fostex vf-16 is a later model similiar to the mr16 model
Try going to the Fostex.com site and download the instruction book. It could be a small electrical fault inside the machine. If you've tried all then take it to a Fostex dealer and have the look at it. They're too expensive to play around with.
Good Luck
Sep 04, 2009 | Music
Fostex Mr16hd 16 Track Digital Recorder Logo
179 people viewed this question
Top Fostex Music Experts
Michial Gueffroy
Ben Armstrong
Are you a Fostex Music Expert? Answer questions, earn points and help others
