Question about LG WD-1041WFH Front Load Washer
Lg intellowasher wm-11150fb - LG WD-1041WFH Front Load Washer
3 Suggested Answers
  • 1382 Answers
SOURCE: My LG Intellowasher WM-1280FHD is refusing to
LE code stands for locked motor error. When this error code appears in your front load washer it indicates a fault in the motor unit.
1 . Check the connections to the Coil/Stator at the rear of the unit possibly it should be something like a broken wire.
2 . Coil/Stator Assembly will be defective preventing the drive to operate.You should go for a replacement of that assembly.
Thank you !!
Posted on Jul 14, 2010
I have a LG INTELLOWASH m/c WM 1080 FHD and when it is spinning, it continually grinds, it sounds like the bearings are going, is this the problem?
yes more than likely put ure fingers inside thumbs outside and squeeze in and out any movement bearings r gone
Feb 13, 2015 | LG Washing Machines
IE error on LG intellowasher
IE = Inlet Error. Turn off supply valves to hoses and remove hoses from back of machine. Pull inlet screens out of the washer where the hoses were previously attached, clean them out, and re-install. That solves the IE problem about 95% of the time. (Usually, you only have to clean out the cold one.)
Jan 02, 2011 | LG WM-1290FHB Front Load Washer
My LG Intellowasher WM-1280FHD is refusing to spin, even when empty, making strange noises and displaying the code LE. I cannot find the manual to know what this means. Can anyone help?
Thank you !!
Jul 14, 2010 | LG WM-2277HW Front Load Washer
Can't get beyond the filter to get objects out
You could fry blowing hard down the the outlet hose, this may dislodge it.
The only other way would be to remove the pump from the washer, and retrieve it that way.
Hope this helps.
Jan 22, 2010 | LG WM-1480FHD Front Load Washer
Lg intellowasher model wm 1290fhb door will not open. tried waiting 1 hour! tried power on and off, tried child lock
  1. Press the SPIN SPEED and SOIL LEVEL buttons simultaneously.
  2. Press the Power button, while pressing the SPIN SPEED and SOIL LEVEL buttons. Then buzzer will sound twice.
  3. Press the Start/Pause button repeatedly with about 1 second interval until the lamps goes out.
  4. The washer powers off and unlock the door.
Oct 18, 2009 | LG WM-1290FHB Front Load Washer
LG INTELLO WASHER WM-11150FB
the bellow or door boot is what i assume were talkin about.and needs replacing cause its ripped correct? peel back front rim of bellow and is secured by a spring clampremove clamp and it is then attached by a larger clamp to outer tub assy, might be some work but youl get it
Feb 24, 2008 | Washing Machines
Intellowasher WD-12126RD
it is coputer box in the washer. if it work on all other cycles. and stop on rinse. it need a new computer box . and in not hard to change.
Feb 15, 2008 | LG WM-2277HW Front Load Washer
LG WD-1041WFH Front Load Washer Logo
50 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
