Question about Philips Televison & Video
Tv will not search for digital channels
Had the tv approx 4 years. Worked perfectly well until this morning it appears to have gone back to its original screen. cannot get the tv to go to the service set up screen which would then allow us to search for the digital channels. All it offers is a search for analogue channels. We are not using the original remote as this has broken so am using a philips universal instead. Dont know if this is anything to do with it. Could the integrated freeview have sopped working?
  • 67 Answers
SOURCE: My Tv says Keys locked
Posted on Nov 14, 2007
SOURCE: philips universal remote 4 digit codes
For combination tv/vcr the codes on the Phillips remote are 0039, 0739. I can only enter the channel I want to watch I can not use the up and down arrows for some reason.
Posted on Feb 15, 2008
  • 5 Answers
SOURCE: Cannot get freeview anymore
see the solution (which is basically power off, re-scan) at the bottom of this thread
worked for me...apparantly a known bug with software 1.14
Posted on Mar 05, 2009
  • 476 Answers
SOURCE: digital channels have stopped working, only blue screen!
Try resetting the TV:
  1. Switch on TV and switch to any analogue channel.
  2. On the TV: Press and hold the MENU button.
  3. Menu screen will appear on the display.
  4. Do not release the MENU until the menu screen disappears.
  5. TV will go blank for about 60 seconds and then display initial set up screen.
  6. Follow the on-screen prompts to re-tune the TV.
If this does not work then the problem is likely to be a loose ribbon cable or main small signals board inside the TV.
Posted on May 19, 2009
the q guy
  • 393 Answers
SOURCE: Universal Remote used to control Digital converter box
I found that this website should have all the codes and instructions for most remotes
if this helps please give a fixya rating as thats how we get paid.
Posted on Jun 12, 2009
What caused no sound on ABC channels 2 and 21 only?
You would need to ask the broadcaster of the stations that question.
Mar 24, 2017 | Televison & Video
How can I set the channel BACK to CH 3 from CH 4
1) Set your TV to channel 3.
2) Insert a pre-recorded tape into this unit.
3) Press the OUTPUT button on the DVD/VCR so that the VCR OUTPUT light is lit.
• If noise appears on the TV screen, press the VCR/TV button on the remote control.
4) Press the PLAY button once.
5) After a few seconds, press the PLAY button on the DVD/VCR for 3 seconds.
• The RF output channel will change to channel 3 from channel 4 and you will see a playback picture.
• When a picture does not appear on the TV screen, repeat step [4].
6) Press the STOP button to stop playback.
Nov 17, 2007 | Emerson EWD2004
I have had a Sharp AQUOS LC-46PD7X for over three years and just a couple of days ago I started getting a problem where I turn the TV on and it either displays a digital channel for a couple of minutes and...
Hi ibrahl,
I too have the same model and vintage and have been experiencing low signal problems for quiet some time now. It only became apparent when we hooked up the ps3 playTV unit and the digital channels we were having problems with on the Aquos was broadcasting fine. Both devices use the same antenna connection so its not an aerial issue.
I tried reset back to factory settings and reloaded the channels via auto but now those digital channels I had problems no longer appear on our channel list so they're gone for now. I was wondering the same thing about firmware updates but havent found anything on the Sharp website. Found this video but this model uses USB for updates">
Jan 02, 2011 | Sharp Televison & Video
Change channel, lose picture. power off/on, picture appears
switched HDMI plug from HDMI1 to HDMI2 port and that solved the problem
Oct 11, 2009 | Polaroid Televison & Video
Quazar Model VHQ520/VHQ540 cannot record after inst Digital Conv
You need to set the vcr to channel 3 or 4 (whatever channel the digital converter box is set to broadcast on) to record a program. The digital converter box has to be set to the channel you want to record the show from.
Apr 09, 2009 | Quasar VHQ400 VHS VCR
Can't change channel using the remote or buttons on tv
Simple Fix
I had the same problem, couldn't change the channels with the remote or on the side of the TV. This was for a Vizio 37"
Here is the fix:
1. Turn on TV
2. With remote, press the Menu Button
3. Go to Antenna Menu
4. Select Auto Search
Let it search, it could take several minutes. It may not finish to 100%, mine got stuck at 79% for 10 minutes. It's fine if that happens, go ahead and cancel.
5. It should be done, your remote will work perfect along with the TV channel buttons.
Sep 07, 2008 | Vizio L32 32 in. LCD HDTV
Pagnor plasma tv picture problem
i was perchase philips7310 tv toner card in last 2 year back
tha problems is volume is work fine picture is not coming dispaly
plz tel me what is the problem
Jul 10, 2008 | Philips SAA7130 TV Tuner/FM Radio/Video...
Channel issue
Do you have a lot loose connection inside tunner. Need be re solder. Do this and TV will be ready!!.
Apr 17, 2008 | RCA F27442 27" TV
Televison & Video Logo
37 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
