Question about GMC Denali 700C Road Bike
How to remove front forks
A friend of mine sold me the bike. I'm trying to give the bike an overhaul and thinking about converting it to a mountain bike. Never the less I'm definitely giving it a new paint job. I need to get the forks off to grease the bearings and they aren't like any bike I've messed with before. I'm very mechanically inclined so just point me in the right direction please.
  • GMC Master
  • 1,192 Answers
Repainting via rattle-can is a bad idea - looks poor and will not hold up. As for forks, just google "overhaul threadless headset."
Posted on Jul 30, 2017
3 Suggested Answers
  • 3433 Answers
SOURCE: front end bearings need to be replaced
Yes New bearing should do the trick
Posted on Sep 26, 2009
michigan man
  • 3533 Answers
SOURCE: I think I need to
the bearing should be behind the rotor give these websites a try or if all fails stop by your local library and get your hands on a Haynes auto repair manual for your truck wish you the best of luck Michigan Man.
Posted on Oct 15, 2010
How do i remove the forks i have to replace the fork boots 1990 kx 60
Remove front wheel, undo the upper & lower triple clamp bolts that hold the fork legs & slide out, fit boots & refit
Ride safe
Feb 01, 2012 | kawasaki Motorcycles
In changing 2005 Harley Heritage Model FLSTCI fork oil, how many ounces of fork oil should I use? What does wet or dry mean?
I'm sorry but I don't have the specs on the quantity and type of fork oil for your year and model bike. I work on the older bikes that the dealers will no longer service. But, I can describe the difference between the "wet" and "dry" conditions of the fork assembly. If you take the front forks apart, clean them out, and put them back together with no oil in them, they are considered "dry". For a simple drain and refill type oil change on them where you don't get all the oil out of them, they are considered "wet". I hope this helps, You can call you local dealer's service department and they should tell you the quantity and viscosity of the oil that goes in the front forks on your machine. They'll tell you something like 6 ounces of "Type E" oil, for example. Harley-Davidson uses these types of specs to describe their oils. If you go to a website for fork oil, like PJ1, they may give a cross reference or equivalency chart for converting H-D "Type E" to their oil. I think that would be their 30 weight oil. If the front end seems too "stiff" with 30 weight, you can drop down to 20 weight. I think Honda makes a 25 weight but not sure. Your Harley won't mind the Honda oil. BG.
Good Luck
Aug 23, 2011 | 2005 Harley Davidson FLSTC - FLSTCI...
I have a 2006 Harley Dyna, was wondering if front fork torque specs are the same as Sportster front fork specs? I have quite a gap between triple tree and goose neck...fork lock pin doesn't line up in...
You didn't say which Dyna series bike you have but I'm going to say that Sportster specs are not the same as for a Dyna. If you think you have a gap between your triple tree and the steering head of the bike, something may not be assembled correctly. I'd take to a shop or a dealer and have them check the front end.
Good Luck
Jun 11, 2011 | Harley Davidson FXD Dyna Super Glide...
Keep having leaking fork seals.have replaced seals and oil after every ride lately.(4)have tried two brands of seals last time disasembled whole of forks cleaned every part,shims everything and had...
G'day. A couple of suggestions-
Damage to the fork slider-chips or dings.
Too much oil in the fork on re-assembly can cause the seal to go.
Worn or loose fork bushes will flog the seal prematurely.
When you transport the bike-if you don't use a seal saver can pop the seals.
So let me help with these.
Be sure that the fork slider is not scored,dinged or damaged on th surface.
A good double check of the oil quantity is to ensure that when you have re-filled the tube with oil & primed it(worked the air out of it), the oil level should be 100 to 110 mm from the top of the leg to the oil with the fork fully compressed. If the level is less than this-drop it to 100mm.
To check the fork bushes-try pull on the front forks front to back(wobble) & feel for looseness in the bushes.
And finally-When you transport the bike-put a chock(I use an empty 5ltr oil container-but you can buy propper chocks from the bike shop) in-between the forks at top of the front wheel .
Now when you pull the front end down it will stop on the chock & stop the front forks being under excessive compression for extended periods-so it saves the fork springs from sacking out too.
I hope this proves helpfull.
Kind regards Andrew Porrelli
May 20, 2011 | Sherco 5.1i Motorcycles
How do i change fork oil an will it make them stiffer an is they a number where i can talk to ya
To change the fork oil, look down on the lower part of each fork leg just above the axle on the backside of each leg and you'll find an Allen plug or small screw. Take this screw out, hold the front brake and push down on the front forks. The fork oil will come out of the tube. Do both sides at the same time. Once you get the oil out of them, reinstall the drain plug. Then, take the large hex cap on ONE TUBE AT THE TIME and pour the correct amount of the correct fork oil into each tube. There is a specific amount of oil that must be poured into each leg. Since you simply drained your forks instead of disassembling them, you should use what is known as the "Wet" quantity of oil. I'm pretty sure your bike takes 9.0 ounces of oil in each leg. Call your local dealer and they'll tell you how much oil to put in. Your bike came from the factory with "Type E" oil in the forks. The viscosity of the oil determines the dampening effect of the forks. Heavier oil will stiffen the front forks, a lighter viscosity of oil will make the front end softer. You can check the Internet for fork oils and they should give you a comparison of what weight oil is equivalent to "Type E" oil. I think PJ 1's 30 weight oil is the same as type E Harley oil. Use only "fork oil" in your front forks as it has special "anti-foaming" agents in it. If the oil foams up, you'll lose the dampening effect in your forks.
Good Luck
Apr 20, 2011 | 2004 Harley Davidson XL 1200 C Sportster...
Leeking fork seal. Triumph Trophy 1200. Disacembly procedure please
Did not see our bikes manual (I may have missed it) You can download a similar bike or request your own
Feb 08, 2011 | Triumph Trophy 1200 Motorcycles
What's a "hardtail"? What's "full suspension"?
A "hardtail" is a mountain bike that has a front suspension fork (like the one on the right) and no shock absorber in the back. Good hardtails are light, fast and responsive, and because of this they are good for climbing.
Even the cheapest mountain bikes these days tend to have suspension forks. That's not necessarily a good thing, since most of the forks on cheap bikes are of poor quality and will probably need replacing before too long. The cheapest forks also tend to be sold only on new bikes, and not separately. Find out the make and model of the fork, and search around on the web for it. The price will give you an indication of the fork quality.
Most decent bikes are sold with Rock Shox, Manitou, or Marzocchi. Marzocchi has been making forks longer than anyone and has probably the best reputation, but they tend to be expensive so you won't find them on anything but expensive bikes. Rock Shox and Manitou make lower-end (but reasonably good) forks. Other reputable brands such as Fox and Suntour make forks that may very well provide a good service life, but are not as well known for mountain bike forks. Replacement forks can be found at very low prices during sales and clearance events, so they can be upgraded later (sometimes at a bargain price). A "full suspension" bike has the front suspension fork and a rear suspension (like the bike on the right). These are highly recommended if you ride in a lot of rocks, as the rear suspension allows you to glide over rough terrain. They're also good for big jumps. The rear shock adds some complexity to the bike, and a good bit more weight at any give price point, plus there'll be a bit more maintenance. Plus, you'll pay a few hundred dollars more than a hardtail for a bike of otherwise equal components. Depending on your terrain, it might be worth it; riding a hardtail in big rocks can be brutal.
Dec 16, 2010 | Cycling
Change oil fork
There is a bit of directions on how to change the oil. I will give you a link to a site that has pictures with step-by-step directions that will work for any bike fork.
If you have any more questions, feel free to ask..
Nov 25, 2009 | 2004 KTM EXC 200
I want to up grade my xr 200 1999 front forks , better forks and disc brake what bike will do this to my xr im thinking of change over,
Think of any of the motocross bikes.You will fit the cr front ends but it is also best to change the brake master cyl. at the same time.Check the weight of the exchange bike to get it pretty close to yours.Spring sizes and weights will then give you an upgrade ride and you dont have to play around with them too much.Look in the 250 2 stroke range first.Plenty of them around and the weight is similar.Hope this helps you
Nov 19, 2009 | 1999 Honda XR 250 R
Vibration in handlebars/forks??
Front end vibration can be caused by front rim/tire out of balance, worn wheel bearing(s), bent front rim, or fork misalignment.
Since you recently had fork work done, I would first check the forks for proper alignment, then have the bike on a stand and spin the wheel to see if there is wobbling. To check for bearing wear, while the front is off the ground, try to rock the wheel from side to side. If you can feel or see movement, you will need new bearings.
Hope this helps
Mar 17, 2009 | 2000 Harley Davidson FLSTC Heritage...
GMC Denali 700C Road Bike Logo
188 people viewed this question
Top GMC Cycling Experts
Arnie Burke
Arnie Burke
Donald Ayers-Marsh
Are you a GMC Cycling Expert? Answer questions, earn points and help others
