Question about Welding Tools
I have a powcon 300 am welder and it will only work when the power is turned up past 60 and the amp/volt meter is not showing and positive reading it will only show -3 or -4 what could be the problem ???
3 Suggested Answers
  • 7 Answers
SOURCE: dead unit Cyclomatic PowCon 300 SM
Well John Henery I'm new to this type of correspondence,but I'll give it a try!
#1 Disconnect from power & remove the 10 bolts holding the cover.(There should be diagams by each of the 3 jumper sets to be changed.)
#2 Standing at the front look to the rear left ,and you should see 4 studs. (Dotted line=buss jumper)
x----x x----x x x----x x
240V 480V
#3 At the front center down low there will be 4 more studs.
240V 480V
#4 On the right rear there is a vertical board with 10 studs.
x x x x x x
x x x x--------x x
x x x x--------x------x
x x
(240V) (480V)
As far as your no power problem look at the main power switch. Of the wires that go to the welder, 3 will go to the power board, and 2 to the control board. When you hook the power cord to the house power you need to make sure to use the 2 cord conductors that will also feed the control board.
I do have an operator's manual for a 300SM, contact me at blandt101@att.net ,and I'll get you a copy.
Tom
Posted on May 25, 2009
  • 225 Answers
SOURCE: I was just looking at an old forney welder and was
if the unit does not say ac/dc it is probably ac only,forey is still in business,factory is in colorado.
Posted on Feb 07, 2010
How do I wire in a amp meter please
amp meters are wired in series in a power circuit
that is to say cut the wire and attach each end of the wire to the terminals of the amp meter
you have to know the amps in the circuit to get an amp meter large enough to read the current or it will burn out
( a 60 amp meter for a 120 amp power wire is not right)
in that case you can get an amp meter that runs a resistance in the back of the unit and as volts and amps are directly related by reading the voltage drop across the resistance the current (amps) can be read
That allows a small amp meter with a high face reading to be attached to a large current wire 10000 amps etc
you can also get amp meters that have a crab claw clip that goes around the power wire and by reading the flux field voltage converts that to an amp reading without touching the wire ( used by electricians to check current draw in electrical motors etc )
Apr 12, 2017 | Cars & Trucks
Low voltage at recepticials
If the front DOES NOT say "chopper technology", then the fine control knob MUST be turned all the way up for full aux power. Low engine RPM can also cause this issue. If your meter can read frequency, it should read a little above 60 Hz at full speed with no load.
Mar 12, 2014 | Lincoln Ranger 225 Engine Driven...
1997 gmc jimmy starter motor not turning
You need a better battery. When you hook the amp meter and read 0.3 the ECM needs to sleep
Jan 05, 2012 | 1997 GMC Jimmy
Fan on my big buddy heater just stopped working changed batteries still not working?tried the switch nothing .i only have radiant heat.
I would first check the wiring connections to fan and get a multi meter , set on 12 volts dc and see if fan motor has 12 vdc input voltage.
Too cheap to buy a voltage tester at wal mart ot harbor frieght, you can use a 12 volt bulb and socket, if you already have one. Remove fan wires & hook up 12 volt light bulb & if it lights, you got the juice. Carefull,dont let live wires touch because you short out $26.00 big buddy fan transformer. work with fan transformer unplugged from wall and dont plug in until you sure no wires touch.
use electrical or duct tape. electrical tape better.
otherwise,just buy the multi meter, they only $8.00 to $10.00
read & understand instructions, before you try to use it. otherwise,you could burn out your new meter.
well worth owning &
learning to use multi meter. I use it thousands of times.
if fan motor has juice but wont run, check fan shaft to see if it turns freely or scrapes or is stuck. oil fan motor bearings ,change the brushes.
make sure that the fan blades are not touching the fan housing and can turn freely.
if it still dont work, buy new fan motor.
if no juice at fan motor, check mr heater switch with the power off,unplug transformer from the wall or remove batteries.,
and use the ohm meter setting of the multi- meter to test for continuity of the switch when the switch is in the on position.
power must be off when using the ohm setting of a multimeter.
if power is on & using the ohm setting of the multi meter, you will blow out the multimeter. The ohm setting uses a 1.5 volt dc battery inside the multimeter to test for a compleated circuit.
so, 12volts dc would blow it out on ohms setting.
TESTING FOR OUTPUT OF FAN TRANSFORMER OR BATERY PACK.
If the switch is good,reinstall it on mr.heater and test the output of the transformer or battery compartment using the 20 volt dc scale of the multi meter. the voltage scale you select ,must be higher than the voltage you expect to find ,in order to avoid damage to the multi meter.
observe polarity,positive to red and negative to black.
the dc voltmeter setting is totally polarity sensitive and a reversed hook up could blow out the meter.
multi meter means it can read ac volts, dc volts,ohms and dc amps. Read and understand the included instructions before using a multi meter
a good single battery in new condition reads 1.62volts dc
1.5 vdc is almost dead, a good used battery reads 1.58 to 1.6 vdc
below 1.58 vdc is weak battery and 1.48 vdc is usually totally dead, but may be enough for momentary usage under 1 minute.
Sep 08, 2010 | Mr. Heater Big Buddy Heater
The battery light came on and the battery was replaced. The alternator was also checked and determined to be ok. Now the battery light comes on and the slternator shows as charging at about 14-15 Volts any...
check the battery with a volt meter. Place the probes from the meter inverted which means positive from the meter to negative on the battery and negative from the meter to the positive one the battery. MAKE SURE YOU STE THE METER TO THE DC & NOT TO THE AC MODE BEFORE YOU TURN THE METER ON. Now start the engine and see if a reading shows of 14 - 15 volts. If so the diode is bad in the altenator. The diode suppose to keep the current running only one way. If the current is running both directions the altenator does not charge the battery completely and the battery light will come on this way also
Jan 31, 2010 | 1997 Jaguar XJ6
It doesn't seem to have any power. Set the welder as high as it goes and it doesn't penetrate like it used to. I'm using co2 to try and help but it still appears low on power
It sounds like you might have a shorted diode or two on the rectifier. The stud mount diodes can be replaced while the ones that are pressed into the aluminum plate can not.
To check the stud mount diodes they need to be isolated from the heatsink. Unscrew the nut that holds it to the heatsink. Using a digital volt ohm meter set to the diode test position, place one lead on the threaded stud and the other on the soldered wire. Note your reading and swap the position of your test leads. A good diode will show O.L. one way and have a diode drop of .2-.9 volts the other way. Shorted diodes will have a reading of something like .001 volts.
Nov 11, 2009 | Welding Tools
No voltage to feed motor
You have to use a volt meter and trace the circuit from the feed motor back to where the voltage does exist, and then you'll know which part is failing
Oct 29, 2009 | Clarke Power Products Clarke 130EN...
Dead unit Cyclomatic PowCon 300 SM
240V 480V
240V 480V
x x x x x x
x x x x--------x x
x x
(240V) (480V)
Tom
Apr 10, 2009 | Miller Welding Tools
Checking power consumption
you need a clamp on amp probe, a multimeter wont hack it. if you can get a amp probe, you first seperate the wires on your cord and then place the probe over one of the wires only this will give you your consumption. by the way, your approx usage of watts on a 26 inch lcd tv would be 160 watts. models do vary.
Mar 29, 2008 | Televison & Video
Wrong connection continuation
If you're installing this in a vehicle with a 12 volt charging system (most automobiles are 12v), I think the batteries may be dead in your multimeter. You shouldn't read anything over ~15v.
When you measure this again, place the black lead on the ground terminal of the amp.
Dec 16, 2007 | Jl Audio 300/4 Car Audio Amplifier
Welding Tools Logo
55 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
