Question about Sharp LC46SB54U 46 in. LCD TV
Power light keeps blinking but the tv won't respond to anything
5 Suggested Answers
jdvillanueva
  • 2098 Answers
SOURCE: Sharp Aqous 52' opc &
Hi patricia_597,
Unplug the unit from the outlet, then while unplug, press and hold the power on button for one minute to drain the voltage and refresh the boards...
Try to open again and see if the symptoms remain the same...
If yes, the power supply board produced an out-of-regulation condition and disable the unit. The most common caused of this symptom is the leaky/dried filter electrolytic capacitor in the output of the power supply section. It will drop the voltage from normal and trigger the blinking of the led light. It will not power up unless isolated the faulty parts.
Leaky capacitor sometimes has a bulged/dome at the top but not all. Dried capacitor has no physical indication of fault and looks new and in good condition but actually not. You must have a capacitor checker to determine its condition and pinpoint the faulty one.
If you don't have necessary tools and test instrument and can't troubleshoot the unit yourself, I would advice you to look for a qulified technician to isolate the symptoms..
Also check if your unit is under warranty period, avail it because the manufacturer will fix it for free. Don't attempt to open the back panel because it will void the warranty.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Apr 25, 2011
  • 11800 Answers
SOURCE: power & OPC lights keep
That signal the fact that the power source is in protected mode - a component has failed in the tv and now acts as a short. When the power source tries to start the failed component starts to draw so much power that the voltage drops; this trigger the protection system of the source that shuts it down to save it from frying.
To fix the tv you will need to open the tv and test the voltages on the output rails of the power source to find out which one is triggering the shut down. Then just follow it to the failed part. This requires a good electronics experience.
In your tv the most usual part to fail is the sound board: the radiator on the audio amplifier is undersized so the amplifier overheats and fries. The sound board will have to be replaced - a $250 job at a repair shop.
Posted on Jul 14, 2011
  • 8457 Answers
SOURCE: TV won't show picture the
The main tv Tuner signal board have problems or it is dying or might be dead already.But sometimes this tv will still work and can be used,i have the same tv have the same problems it work for me all the times.By doing this process.Everytimes Power and OPC lights blinks.Just push the remote power switch again for tv to repower the tv power and OPC lights again,have go thought this process pushing power remote switch again have to do this like 3 or 4 times sometimes before the tv to work.Tries websites like Shopjimmy.com or Ebay.com to buy a whole new refurbish main tv Tuner signal board for the replacement.
Posted on Jul 30, 2011
rabbitbrains
  • 575 Answers
SOURCE: I have a Sharp Aquos TV that started to turn on
It sounds like a bad capacitor. If you are handy, you can search on Youtube on how to replace them on your model. If not, have a proffesional look at it. The individual parts should be inexpensive. The service charge varies. Good luck!
Posted on Aug 30, 2011
Samsung plasma blinking red light, tv won't turn off
Hello, The real problem is on your TV 'scircuit. Due to high electric power supply there might be a short circuit damage. It's better you call up your service technician and ask him to offer you a onsite support.
Nov 11, 2017 | Samsung PN51D7000 3D Plasma TV
The TV won't turn on. It is plugged in, but won't turn on at all. Is it fused?
It has a fuse and if the power light comes on and blinks a specific code that would be a error code.
This set weighs close to two hundred pounds, follow the power cord inside the set as it goes almost directly to the fuse which should be a 6.3 amp fuse----careful if its bad, it is a slow blow and special, a Radio Shack or Generic one the same amperage and type will blow for no reason, if its bad don't keep feeding it fuses.
Dec 08, 2012 | Sony FD Trinitron WEGA KV-36FS120 36" TV
TV won't turn on. red light blinks twice and nothing happens
This is an error code of some fault inside. Kindly call in a qualified service technician.
Jul 25, 2012 | Magnavox 32MF301B LCD TV
Power button won't turn tv on. light keeps blinking on and off
Main board to your TV is faulty. Check the chroma and video processing section. In most cases, it will be due to an IC fault.
Jul 23, 2012 | Curtis-Mathis Televison & Video
TV won't turn on
Before going OFF, the standby LED might blink. These blinks are fault indication. The number of blink should be counted. Count the number of blinks at one time, before the TV goes OFF. [eg: 4 blinks Power SOS P Board; 6 blinks Driver SOS 1 SU / SD / SC Boards
(SC energy recovery circuit)] and so on. you can get more details from this site named 'Electro-help'. You can reach it by searching the keyword "electronicshelponline" by internet.
Jul 03, 2012 | Panasonic TC-P50X1 50 in. Plasma HDTV
Can a tv lose the ability to read codes from a universal remote cause i tried three different un. remotes and my tv doesent react to them.. thnx
If the infrared sensor inside the TV is faulty, TV won't respond to any remote controls. You can make it sure by looking into TVs standby light. If standby light on TVs front panel blinks once, when you press a key in the remtote control, make sure that the sensor inside is working properly, and the code you are trying to enter is non once for your Brand TV, If there is no blinks as such stated above, make sure that the infrared sensor inside your TV is faulty. If you want more details about codes, setup proceedings, repairing a remote & checking it, just visit this site. Th site name is "Electro-help".. Just search for it by type in 'electronicshelponline' in your browsers' search page. It is a blogspot site, in English language.
Jun 22, 2012 | RCA Televison & Video
The infrared receiver light just keeps blinking red and TV won't power on. Tried unplugging for a little while but didn't help.
kindly count the blinking led to diagnose where the fault came from..
also try the initial check....open the back cover and inspect the power supply board for any bulged capacitors inside..
Jan 18, 2012 | Polaroid 4241-TLXB 42 in. LCD Television
My Mitsubishi tv power light keeps blinking
have a 55 inch Mitsubishi TV.. the green power light keeps blinking.. is there anything I can do myself?.. or I have to have someone to get it fix?
Nov 29, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Sharp LC46SB54U 46 in. LCD TV Logo
73 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
