Question about GE Nx1300e Led Network Keypad Nx1300eled
GE NX-1300E My Home security system went off suddenly, I replaced the battery, but the key pads dont come back on. I checked that the new battery is charging properly. Please help!
  • 488 Answers
This kind of issue is usually caused by either a logic fault or an issue on the main board.
Look for a defaulting switch on the board. remove ALL power, press and hold the switch and restore power, this should default the board back to factory settings. You will have to reprogram the system so take note of what areas are assigned to what zones..
Make sure the power pack is supplying the correct voltage too, check on the pack for its output and make sure the same supply voltage is reaching the board.
Also, check for blown or damaged fuses as the keyad should have its own fuse, check these electrically - looking to see if the fuse is damaged is not sufficient, check to make sure it has continuity with a multimeter and be careful if you try using a normal test probe as these can cause issues with digital circuitory.
Posted on Feb 15, 2012
2 Suggested Answers
  • 74 Answers
SOURCE: hi i have a ge Caddx NX-148E-RF - beeps only on the hour anoying
Press * 2 and it should tell you what the problem is.
AlarmProfessor.net
Posted on Aug 23, 2010
We have a Direct Alarm Supplies home Networx NX 16 security system installed in our home after we have a power blackout & the power comes back on the alarm goes off. Is this normal or how to fix
If you have had the system for some while, its internal battery eventually looses full charge by constantly being charged by the system. When you loose power the alarm will try to resort to the battery that obviously can handle the job no longer and forces the system to alarm. Recommend that you replace the battery on a regular basis around 12 / 24 months. Otherwise may be a configuration of your system that identifies power loss as a setting.
Apr 01, 2017 | The Home Security
Keypad message reading 12volt low battery on three wireless zones. changed out all batteriies and still getting message.
This could be referring to your battery backup for the control panel. Make sure your battery connections are secure and check the batteries' voltage with a multimeter. If it is showing less than 12 volts and has been connected to the control panel for more than 24 hours, the battery is bad and needs replacement. Contact your local alarm company and ask them verify the battery is bad, and they can install a new one for you right then.
Feb 23, 2011 | GE / Caddx Networx NX 8 Control Panel...
I have a GE home security system. Last week there was a power surge due to a blown transformer in the neighborhood. A few hours afterward the systems siren sounded & would not turn off. So we...
It might not hurt to try the "Microsoft Solution" and reboot the system. First disconnect the AC power then disconnect the battery. Wait 1 minute then reconnect the battery and reconnect the AC power.See ifyou can arm and disarm the system. Then reconnect the siren and try again to arm and disarm the panel. If the keypads beep it can usually give you an error code that will help you pinpoint the problem.
Aug 30, 2010 | GE Security Simon 3 Wireless Home Security...
Hi i have a ge Caddx NX-148E-RF - beeps only on the hour anoying
AlarmProfessor.net
Jul 04, 2010 | GE Security Simon 3 Wireless Home Security...
Bouht a forclose home with a simon alarm in it but dont have the access code how do i fix this
1. disconnect the AC power ad the battery
2 . Opent the front panel
3. Depress Cancel, Set Time and Minutes+ keys all at the same time and plug in the transformer.
4. System says System XX OK.
5. Reconnect battery
System is defaulted, installer code is 4321 and master code is 1234
Alarmprofessor.net
May 06, 2010 | GE Security Simon 3 Wireless Home Security...
My alarm started going off by its self. I went to shut it off but both key pads where dead and it would not stop. I disconnected the siren to stop, if I reconnect the siren it will continue to go off. The...
I really wouldn't be too concerned about it happening again. I've been in the security business for over 30 years and while I see systems "glitching up" such as yours, it is rare that this happens. However, if it happens again, I would get someone to take a look at it. Sometimes glitches are caused by not grounding the control panel properly. I have found over the years many security system installers fail to or don't take the time to ground their systems. So, if this happens again have someone who knows what they are doing come out and take a look at it.
Apr 25, 2010 | GE Security Simon 3 Wireless Home Security...
Is GE Simon 3 a good security system and reliable? We want to know if it is dependable and if it's a very good system to use in our home.
I personally would not recommend. during a break in key pad will draw someone with hammer right to it. A few well placed hits and its done for. Thats is my opinion.
Jan 25, 2010 | GE Security Simon 3 Wireless Home Security...
I replaced back-up battery in my GE simon 3 ( 4 hrs ago), however when I perform a system status check I still get the msg "low battery".
You must unplug the transformer to the system before installing the new battery so the system recognizes that the battery is in place. Once you have installed the battery it is safe to plug the transformer back in.
Jul 25, 2009 | GE Security Simon 3 Wireless Home Security...
New battery warning light still on
power down the system by unplugging the transformer and the battery.  power it back up by battery first followed by the transformer.
Apr 08, 2009 | GE Security Simon 3 Wireless Home Security...
GE Nx1300e Led Network Keypad Nx1300eled Logo
237 people viewed this question
Top GE Home Security Experts
Sean
Grantec 2000
Level 1 Expert
Are you a GE Home Security Expert? Answer questions, earn points and help others
