JVC DVD player read no file then eject the disc tray.....
Dear Friend,
Haneefa, have a nice day! Let me introduce myself. I'm Gildo from Philippines. 5 years Electronic technician. Could you please help me to solve my problem with JVC DVD player? It symptoms was the same way as stated below as posted by other guys.
"My JVC XV N322 also have a similar problem...the off/on button doesn't seem to switch on or switch off the player... display shows LOAD as soon as the power is turned on, then READ and finally NO FILE, its the same with any disc.. i tried cleaning the lens but the problem persists.."
Could you please teach us how to retrieve the corrupted file.
Thanks and advance!
Respectfully yours,
Gil
(SamGildo)
Fixya's username
  • 1 more comment
  • Gildo Sanchez Jr.
    Gildo Sanchez Jr. Oct 25, 2008
    Dear friend,
    I'm glad and appreciate for your immediate response to fix my DVD problem. We have available universal IC programmer lab tool in our company. I'll request to my colleague to allow me for software downloading.
    Please send the flash dump file to my email add gsanchezjr@yahoo.com.
    Thank you very much!
  • Gildo Sanchez Jr.
    Gildo Sanchez Jr. Oct 31, 2008
    Dear Friend Haneefa,
    I appreciate your help so much!
    You're excellent in software problem.The flash IC dump file you've sent was very effective to fix my personal DVD player and I'm happy for this!
    Thanks again and more power!
  • Anonymous Feb 18, 2009
    I havea JVC XV-N322 DVD player and today, I tried to play a DVD and it woudl not play. all it would say is "Now Loading" Then "No Disc" ..then I place antoher DVD into the tray and it plays it perfectly..If you have anything that can help me correct this...It would be most appreciated., MY email is kasul_rahul@yahoo.com
    I would be most grateful if you could help...thank you.
  • 80 Answers
Dear friend,
do u have a universal ic programmer lab tool? if u have a lab tool reflash ur dvd player flash ic. i have a flash dump do u want flash dump i will send u. Thank u
Posted on Oct 25, 2008
Cannot eject a dvd from a dvd player
usually if you look in the front you should find a small hole turn on the Player and push a Paperclip into the hole this is a manual eject for the tray. If there is NO hole then Unplug the Player and remove the outer metal cover Do NOT stick anything into the Inside of the Player taking a flathead screwdriver You can coax the slide tray to eject the disc If it is an internal feed and eject system across the top there should be a crossbar with a spindle in it facing downward onto your disc remover this crossbar and you can safely coax the disc out of the front without damaging your disc. your issue is when the disc was inerted it was misaglinged in the player so the system misinterpreted it as being a No Disc and locked out the ejection of the disc in the players brain there is NO disc in the player at all after you removed your disc reassemble the player and either return it or toss it out for recycling and get another one
May 04, 2012 | JVC Televison & Video
My JVC TH-G30 gives me a locked message when I try to open the load tray what should I do?
hello Setting the disc ejection lock
You can lock the disc tray to prevent the disc form
being ejected.
When the main unit is turned off, hold down the STOP
key at the front panel for 5 seconds
If you attempt to open the disc tray by pressing
OPEN/CLOSE key, the disc tray does not open and
“LOCKED” appears in the display window.
To cancel the disc ejection lock, hold down the STOP
key at the front panel for 5 seconds again when the
main unit is turned off.
“UNLOCKED” is displayed in the display window.
Note:
Before the main unit is turned off, DVD/CD function
should be selected.
Mar 29, 2010 | JVC TH-G30 Theater System
My jvc dvd player/vcr will not eject disc says its reading but wont play or eject
You might want to check the thin ribbon cables attached to the dvd inside the unit, pull them out and slip them back in.
Nov 24, 2009 | JVC HR-XVC27U DVD Player/VCR
Dvd player will not open disc, display lock
Sound like it either has one or two problems, the door is stuck and or the door eject motor has failed. Look in the front to the player for a small paperclip like hole, and use a paper clip to manual eject the and engage the loading mechanism usually located under the door for most cases. Check you manuals troubleshooting section for manually ejecting a CD..
Please leave comment.
Oct 12, 2009 | JVC XV-N312S DVD Player
Dvd player is locked
If there was a dvd in the tray and the cable guy moved the dvd player, there's a good chance the disk might have slid off the tray and is now blocking the tray from opening. Also if the machine was moved there is a good chance the tray/laser lock might be on. It is a switch or button located on the bottom of your dvd player. Check your manual for exact placement. It is built in for shipping purposes so they don't get broken from rough handling. Hope this helped!
Jan 12, 2009 | JVC THC6 Home Theater System 5-Disc...
DVD tray won't open
Try to reinitialize the DVD functions, in the manual:
http://books.jvcservice.com/booklist.asp?Model=DR-MV1SU
Page 84
Turn the player OFF,
Press and hold the power button, While holding it, press the Stop button for 2 seconds or more.
Once its reset, see if it will eject.
Dec 27, 2008 | JVC DR-MV1SU DVD Recorder/VCR
Lock problem with my DVD player
Dear friend,
press and hold stop+play button on the front panel of the dvd player more than 15 sec the player will be unlock
Dec 08, 2008 | JVC XV-S30 DVD Player
How do i unlock a jvc home stereo
On the unit, press the stop button and the cd eject button at the same time. The screen will say locked still. Release them and press them together again at the same time. The screen will now read unlocked. You can then eject the cd.
Oct 15, 2008 | JVC TH-C60 System
Dear friend,
It is a software problem.Reflash ur dvd player.
May 16, 2008 | JVC XV-N320 DVD Player
DVD just says reading.....
Too high speed when writing discs. Use no more than 8X. Try 4X. Also, read again the user manual and check the kind of MP3 files this device can read.
Sep 13, 2007 | JVC KD-AVX1 Car DVD Player
Televison & Video Logo
164 people viewed this question
Top Televison & Video Experts
