Question about Runco CL-410 Multimedia Projector
Runco lamp cuts off
After 1 minute no picture but sound
2 Suggested Answers
paul4265
  • 592 Answers
SOURCE: On my runco vx101c ,
Hi.
It sounds to me like the new bulb that you've purchased is just as bad as the old one that you took out.
If this was a regular flat screen tv, instead of a projector, then I would say that it was a cpapcitor problem.
But you said that the problem didn't come around UNTIL you replaced the bulb.
I wonder, does the bulb have a special way that it needs to be seated in it's plug?
It could be that it can only go in one direction in order for the contacts to work properly.
Now, it could be that, in removing the old bulb and replacing it, you might have damaged the solder for the socket, preventing the plug from getting a good connection.
Also, sometimes when replacing bulbs, other parts such as resistors can fail.
This can be to voltage instability, electrostatic discharge, power failures, and so on.
I would take the new bulb out, and take it and the old one to Fry's, or to BestBuy.
They both seem to have a rather well stocked supply area for bulbs, it could be that even though your bulbs might LOOK the same, they may be quite different as to the way they are made on the insides.
I hope this helps you out some, and good luck!
Posted on Mar 14, 2011
Runco picture upside down
Yes possibly because you have done a complete system reset and not a lamp hour reset so you will need to go into image or screen settings and select front view ceiling mount configuration
Apr 14, 2013 | Office Equipment & Supplies
Picture and sound cuts in and out
Lamp inside of your TV set is nearing end of lifespan. Replace it.
Feb 15, 2010 | Sony KDF-E60A20 60 in. LCD HDTV
My runco flat screen all the sudden has a bunch of colored lines going through it and won't show the picture until it sits on for a while. any ideas?
did you ever find what the problem is my tv is doing the same thing....I have a runco as well and it is getting worse...usually after about 10 minutes it starts showing the picutre and the lines go away completely but, today I never could get the lines to go away...just wondering if you found an answer
Feb 06, 2010 | Runco CW42i 42 in. HDTV-Ready Plasma...
No sound or picture, 2004 pt50dl54j
remove back panel. blow out all the dust from all the components except the fan on the right.
Vacuum out all the dust.
Have you replaced the lamp? that would help too.
There are 2 small red lamp. One indicates HEAT problem. The other one is the LAMP indicator.
Jun 13, 2009 | Panasonic PT-50DL54 50" Rear Projection...
Reset lamp timer runco vx-5000
Using the remote control for your projector, turn the unit on, then select 'menu' on the remote. On the menu that pops up in the screen, select 'SERVICE', then 'DISPLAY DEVICE', then 'INSTALLATION'... once you select that, scroll over to the "RESET" under the lamp hours... this should reset it.
Here is a link to the owners manual for your unit.
http://runco.com/legacy_prods/legacy_manuals/VX4000d_5000d_manual-v3-1.pdf
Nov 01, 2008 | Runco VX-5000ci Multimedia Projector
Projector problem
I have a great deal of experience with that projector in particular.
The burning smell along with the circle on the screen can be one of two thing in the same general area. Both are not good.
The lamp assembly has its own dedicated cooling fans. these fans can sometimes **** in dust and insects. the lamp runs at a very high temperature and can burn those things quickly. I have often found old lamps with particles fused to the glass.
The other situation is that the lamp burned something and it got stuck to the glass somewhere in the light path.
if I remember right the projector monitors the temprature of the bulb and will shutdown if it gets too hot.
Runco is based in california and has a great turn around time on projectors. Unfortunately with Runco you would be hard pressed to find a technician that wouldn't just send it to them for repairs anyways. The major down side with Runco is that customers cannot talk directly to engineers or service men.
Locate a Runco authorized retailer in your area, check runcoes site. and give them a call to see if they cant send it to runco for you. if you cannot find one in your area call Roscor or Blair & Associates in Chicago.
May 02, 2008 | Runco CL-510LT Multimedia Projector
Screen goes blank after 5-6 minutes but sound continues
It may be overheating, check fans and or obstructions of the vents
Sep 02, 2007 | Runco CL-410 Multimedia Projector
27 people viewed this question
Top Runco Office Equipment & Supplies Experts
Colin Stickland
Colin Stickland
Electro Med Services...
Are you a Runco Office Equipment and Supply Expert? Answer questions, earn points and help others
