Question about Ricoh Aficio Office Equipment & Supplies
My Ricoh Aficio MP C4500 is ghosting when I print or copy in color using post cards
I can print & copy with no ghosting if I use regular paper. I am trying to print or copy color invitations on post cards
Cogz
  • 1326 Answers
SOURCE: RICOH Aficio 150 Paper Jam Reset
There is not a reset for jams in service mode. Did you open and close all the doors and make sure they are closed all the way. Most likely you still have a small piece of paper left some where in the paper path or you may have a broken sensor flag.
Posted on Jan 25, 2009
SOURCE: Ricoh Aficio MP 4000/5000 PCL 5e
Manufacturer did have Win 9x / NT drivers but withdrew them April 2008 when MS stopped support of those op systems.
I have same problem searching for a driver.
Posted on Mar 09, 2009
SOURCE: adding developer to the new ricoh aficio mp 1500
Are you a tech? I suspect not. You need to remove the drum unit, disassemble, separate the drum from the development unit. Remove cover of developer unit, add developer, reassemble, and run SP2214 to calibrate.
This is NOT a procedure to be performed by an end user...no disrespect intended.
Posted on Apr 11, 2009
SOURCE: Ricoh Aficio MP C3500 Error Code SC529
Was this ever fixed, I just got the same error?
Posted on Jan 06, 2010
  • 15 Answers
SOURCE: I need to copy and print a booklet from my Ricoh
Definitely, you need to download the RPCS driver.
Posted on Apr 16, 2010
How to fix a dirty copies of ricoh aficio mp c305spf
It is the photo drum which is causing this clean it or replace if it does not solve the problem.
Jun 22, 2015 | Ricoh Aficio MP-C305SPF Color Copier :...
What could the Grinding noise be that is coming from Ricoh Aficio MP C2550 for each page copied/printed?
Check for:
-broken plastic gear on right side of copier
-paper or foreign object in paper path
-paper or foreign object near fuser
Oct 15, 2014 | Ricoh Aficio Mp C2550 Copier With Feed,...
Ricoh aficio mp c4500 factory reset
Selam Ashraf, user manual should be available on ricoh.com. I use it too asI have a ricoh lazer printer. It is easy to use
Huseyin
Feb 03, 2014 | Ricoh Aficio MP-C6000
Out of focus
Out of focus - Ricoh Aficio MP C4500 Copier with Print, Scan, Fax, Finisher
Jan 29, 2014 | Ricoh Aficio MP C4500 Copier with Print,...
Maintenance
Time for a new drum.
Jan 07, 2014 | Ricoh Aficio MP-C4000
Mar 10, 2010 | Ricoh Aficio CL7000 Laser Printer
A3 prints - printing on A4 - Ricoh C4500. When users print to our Ricoh C4500 using RPCS the print comes out as a cut off A4 print, so it does not seem to be detecting the fact that it is needing to use...
Enter on the computer the follow path:
1. enter start menu
2. enter printers and faxes
3. enter by right click into properties
4. enter paper size settings
5. set the paper size for the tray or trays and press update then apply and ok
after thet it will work
Also see on the printer menu enter the same paper tray settings and set the trays by size but more important is to set the compute settings
Jul 08, 2009 | Ricoh Aficio SP C410DN Laser Printer
How to print envelopes aficio ricio mp c4500
On an MP-C4500, envelopes must be printed using the bypass tray (the fold-out tray on the right hand side). Put the envelope in face-down and tighten the two fences so the envelope is snug.
When printing the envelope, make sure the print driver is set for the correct envelope size. If envelopes tend to jam in the printer, try setting the bypass paper type for thick paper.
Nov 19, 2008 | Ricoh Aficio GX5050 GelSprinter InkJet
94 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
