in our church an installer placed 36-8 inch 8ohm 100watt ceiling speakers in the sanctuary. also placing one in the extra rooms... bathrooms, cry rooms, etc.etc. we currently have a heath and allen board... amps and eq's. on the monitors and a seperate amp and eq for the ceiling. We also have controlled peaking on the main microphones, with volume control knobs per set of two speakers. My question... we can blast a cd till its a uncomfortable noise, but the microphones seem only to reach half the volume before they distort the speakers... what to do?
1. Even though you have some kind of peak limiting on your mics, the signal might still be peaking somewhere along the audio path and causing distortion. Gain controls might be set too high somewhere along the way.
2. The amp you are using might simply be driving too much power for the speakers to handle.
3. A faulty connection, connector, wire or input could cause distortion of something like distortion which is of course would be more apparent at higher volumes.
4. Equipment placement could be picking up sounds or interference from other sources.
5. If you are able to discern level peaks but they are occasional and not flat out, then a compressor placed in the mic signal path could certainly help - otherwise see # 1 above.
Re-20 has a loose part ... and i cannot open it to see what the issue is... there is no screw on the...
(More)
Re-20 has a loose part ... and i cannot open it to see what the issue is... there is no screw on the outside near the front of the mic...
I can't hear anything when I play it back after recording. I can hear it if I put it into my stereo...
(More)
I can't hear anything when I play it back after recording. I can hear it if I put it into my stereo cassette player.
I used a converter for the big jack to a mini jack for computers. Then put the mini jack in my...
(More)
I used a converter for the big jack to a mini jack for computers. Then put the mini jack in my computer and tried recording, it doesn't work (actual mic philips SBC ME570 works normal), the test doesn't work either. What can I do?
how do i change songs from ma headset mm400 sennheiser,,also why when i connect the headset the...
(More)
how do i change songs from ma headset mm400 sennheiser,,also why when i connect the headset the volume on my iphone goes haft way?
