Question about Insignia Televison & Video
Fan noise on insignia tv
Fan noise
NS-LDVD32Q-10A buzzing noise
Try another input and another source such as a DVD player. If you still get the buzzing sound, you could have a faulty power supply output or a fault in the audio circuit of the main board.
Jan 27, 2013 | Insignia NS-LDVD32Q-10A LCD TV
Insignia tv makes a popping noise when turned on and then turns itself off
You have a shorted main circuit board, the TV is shorted and that is why it shuts off, it is a fire safety issue. Unplug the TV and call a service that checks these out. I will warn you that the average cost to repair this type of problem is about $500.00, so a new TV might be a better choice.
Feb 15, 2012 | Insignia Televison & Video
Have a hunter 52" insignia
Diane, usually, that's an indication that one or more of the fan blade irons are loose, where they attach to the fan's motor. Unfortunately, you're going to need a tall ladder and a Phillips Head Screw Driver to reach and tighten the screws. You'll have to check each fan blade iron one at a time, to find the one(s) that are loose.
Good luck. I hope this helps you solve the problem.
Jul 09, 2011 | Hunter Heating & Cooling
Whenever i watch tv mybe for 1hr i can hear that there is sound behind its very disturbing..is true that there a 2yr unlimited warranty for it???my tv is not even a year..thanks
most likely the sound you are hearing is the intercooling fan blowing out warm air from inside the TV. When the fan gets covered in dust/dirt it tends to make more noise. Usually a buzzing and/or light grinding noise.
The best thing to do would be to open the TV from behind and clean the fan. You can buy some compressed air at most office, tech, and supermarkets. Just get as much of the junk off as you can and you should hear a remarkable difference.
hope this helps!
Thomas
Feb 28, 2010 | Insignia IS-LCDTV32 32 in. Television
Trying to watch DVD played on portable Insignia player on the TV
If you hear a noise, when triying to read DVD, I am shure I´ts teh engine malfunktion.
you must get the mechanisiam or take this to a service.
I´ts very difficult for lenses to get brocken.
Jul 01, 2009 | Insignia IS-PDVD10 Portable DVD Player
Insignia PC speakers - give a weird static feedback noise
I'm going to vote for the haunted option.
Sound like you have some noise on your power lines. This can be caused from many different things. Normaly it is a motor going bad or a compressor starting up. From the AC unit or refrigerator.
See if you can correspond the noise to anything else happening in the house. Fridge starting up, AC or heat cycling on...etc.
It may be that you just have speakers and a cordless phone going bad at the same time.
It might just be Casper the friendly ghost playing tricks... ha!
Jan 23, 2009 | Insignia 2.0 Speaker System (2-Piece)
Insignia 19" LCD TV
anyone have a proble of the screen just freezing or going dark and making a high(loud) pitch noise?
Oct 28, 2007 | Insignia IS-LCDTV32 32 in. Television
Televison & Video Logo
43 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
