Question about Sharp AR-5516s
My AR-5516 displays blinking H4, what do i do
  • 255 Answers
SOURCE: Ar 5516 display H4 error
This means that the fusing unit has a problem. Turn off the copier. Open the small side cover on the right of the fuser unit. You will see the wire connectors leading from the unit and carefully remove them.Open the three screws holding the unit and remove it, check the heater lamp continuity if out replace the lamp. Clean the thermistor and return the unit by reversing the removing process. Now try the code and it will work.
Posted on Mar 30, 2010
  • 28 Answers
SOURCE: i have photocopy sharp ar-5516 and when i switch
Perform the following procedure to enter the simulation mode.
"#" key Interrupt key "C" key Interrupt key
press 14 and start key twice.
copier should restart normaly.
If not, then you have problems with the fuser, contact me to tell you what you have to do next.
Regards,
Adi
Posted on Nov 05, 2010
Testimonial: "thanks a lot it was very helpful"
FixinFax
  • 3085 Answers
H means heat, you need a new fuser.
Posted on Mar 28, 2010
fathitkf
  • 1871 Answers
SOURCE: sharp ar 5320 displayed error code h4 and it is
Hello :
It's a bad component in the fuse. It could be a bad thermofuse or thermistor . Better to take it to a Sharp dealer . They should be able to repair it right and quickly .
good luck .
please don't forget to rate !
Posted on Apr 04, 2010
  • 4 Answers
SOURCE: Problem for Sharp AR-5320 Black
for AR 5320 just check 1- main corona 2- leveling the developer unit 3- clean cleaning plate,
for H4 just rest the machine as mentioned above, if not plz check fuzing unit -- thermostat
Posted on Aug 22, 2010
My photocopier sharp AR 5516 is showing H4, what is the solution?
There's an earlier response to this question on fixya in Dec 4, 2012. Search "sharp ar5516 error code h4". It's the third hit down.
Jul 09, 2015 | Sharp Office Equipment & Supplies
My Printer is displaying an H4 error
The error code H4 means that you have a problem with the fixing unit. It could one of the item's > The thirmistor or thermal fuse or the fixing heater lamp
Oct 05, 2012 | Sharp Office Equipment & Supplies
The printer Ar-5516 is showing H4 error
this error means:
heat roller abnormally low temperature.
for check:
1- check the heater lamp
2- check the thermistor
for reset:
clear key --> interrupt key --> "0" key --> interrupt key --> 14 --> start key
Jul 04, 2012 | Sharp AR-5316 Advanced Digital Imager...
Ma photocopieur shar 5516 marque un message d'erreur H4
H4 error indicates the fuser is faulty and should be replaced.
Jun 19, 2011 | Sharp AR-5316 Advanced Digital Imager...
Problem for Sharp AR-5320 Black and White Copier Ar 5516 display H4 error?
Aug 22, 2010 | Sharp AR-5320 Black and White Copier
Sharp ar 5516 printers error h5. h4
hi,I have error code L h on my coppier sharp 5516. your help please.
Aug 05, 2010 | Sharp AR-5316 Advanced Digital Imager...
Mar 28, 2010 | Sharp AR-5320 Black and White Copier
Sharp AR-5516s Logo
59 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
