Question about Alpine Car Audio & Video
Yes I have a alpine 7995 cd/tuner it has 12volts and a good ground I also checked for power where the faceplate connects and there is 4.89 volts there but no face illumination and nothing happens when power button is pressed. Ialso tried pushing in the pin sized reset buttton on faceplate and still stone dead any suggestions?
  • jstuart2112 Oct 25, 2008
    yes, the unit was being bench tested from a "brand new" 12 volt car battery before install into vehicle. I pulled top cover and checked for 12 volts at mother board 12 volts is present. I also checked at the pins where detachable faceplate attaches,and found 4.89 volts on several pins there, still no illumination on faceplate or functions when power button depressd. again I tried pushing and holding a pin sized reset button on faceplate to no avail need a detailed answer please P.S. I am a ase certified mechanic for 15 years.
  • jstuart2112 Oct 26, 2008
    would imagine the clock is displayed even when power is not on so power button is not in play.
  • 360 Answers
Sounds like the face plate is wrong or its burned out......... sorry bad news but it happens justuscc
Posted on Oct 26, 2008
    Master:
  • 505 Answers
Go this link and download the user manual.
http://portablemedia.manualsonline.com/manuals/mfg/alpine_electronics/cda-7893_1.html
As you have tested the connection try to check it by connecting to a different power source. You may have to open the system because the connection on the main power board may have damaged. In that case you need to get it serviced by a qualified technician.
Thanks
Posted on Oct 25, 2008
    Brigadier General:
  • 6,966 Answers
On bench testing, both the red and yellow wires must be supplied with + 12 volts. Of course the black and the body/chassis goes to the negative.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
    Genius:
  • 1,269 Answers
It could be the power button itself which is not having direct contact inside it. If power test is ok, more likely its just the power button. How about try to trace circuit board where the power button is soldered or running, then try to short it. You can also try to replace the power button only.
    Master:
  • 763 Answers
Sir try to check the wirings of your car stereo to the battery. it must have been out of power and better to see a wiring technician for this because they have tools and knowledge to have the wirings back on its place. hope that helps!
thank you for using fixya
CHARCOIS
CHECK TUNER on Sirius XM
Ours was corrected by removing the faceplate and holding in the small red reset button that is located about halfway across the front
Jan 16, 2014 | Alpine CDE-SXM145BT Advanced Bluetooth CD...
I need to know the which color of wire goes to what pin number on the connector that on the back of alpine CDA-7995.
You need a wire harness for your vehicle make. Its like 15 bucks. You plug it into your car harness where the radio goes. It has a little peice of paper to tell you what the color codes are. You need to know what the wires on the receiver are though. For example mine are labeled with small tape that say ground,front left, right rear, Ect. Leave good feedback if this helps. Thanks
May 09, 2011 | Alpine CDA-7995 CD Player
My cda-9813 wont power on,how to take of faceplate?
Here is a link to the owner's manual for your stereo, it shows how to remove the faceplate:
http://a248.e.akamai.net/pix.crutchfield.com/Manuals/500/500CDA9815.PDF
May 14, 2010 | Alpine CDA-9813 CD Player
Cd player keeps going off and
Check that the fuse is good and that it is tight. Also check wire harness and all connections to the back of the player.
Another known cause of this is the ribbon cable connection between faceplate and main control can become pinched or loose.
Nov 20, 2009 | Alpine CDA-9851 CD Player
I've had my Alpine CDA 9883 for 17 months, and the power to the display goes in and out. I've checked the wiring connections. Any ideas?
Check the face plate pins and the deck side for build up, you can scrape them w/fingernails to clean any excess dirt etc. off them, then replace the face. That's about all you can do. If the faceplate LCD is bad you can by a new one, generally 150-200 for a new face. Check with an Alpine dealer, most good custom shops are actually very helpful.Best of luck
Jun 24, 2009 | Alpine CDA-9883 CD Player
How to connect a pioneer super tuner to a 91 honda accord
With a DC voltage tester, check the two power leads for 12+ volts and proper operation, and be sure the unit is properly grounded.
The two power leads are,
1.Constant feed: which should be connected to an un-switched power source that delivers continuous
power to the units memory.
2.Switched feed: which should be connected to a switched power source controlled by the vehicles ignition switch.
Before installing in dash check unit for proper operation.
Good luck
Aduz
Mar 27, 2009 | Pioneer DEH-P2900MP CD Receiver...
Connect alpine 7874 to alpine powered sub
You need to run the RCA cables from the head unit to the sub for the audio signal, and possibly a turn on wire (the blue one on the back of the head unit), unless the sub has an automatic power feature.
The sub also needs power and ground wires attached, but those do not connect to the head unit. Power should be run directly from the battery with an inline fuse, and ground should go to the nearest good ground point (Trunk latch, seat bolt, etc).
Mar 20, 2009 | Alpine CDM-7874 CD Player
Alpine 7995
sir check the face panel of your car stereo and see if fits correctly and if you have contact from the last owner of the stereo then call him and ask him if he experience about this
Oct 25, 2008 | Alpine CDA-7995 CD Player
Car Audio & Video Logo
61 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
