I have an old Gorenje washer (PS400GX) whick leaks and I don't know how to open it to check if something might be bloking the water. I don't have the manual. Can you assist?
Bgillespie
  • 89 Answers
SOURCE: How do I open my GE Top Load Washer to check for leak
Pull the washer foward, tilt back against the wall and look under it.... look where the water pump connects to the motor shaft... check for rust etc.... if so replace pump....
Posted on Dec 15, 2007
  • 3 Answers
SOURCE: Calypso 22066 top=load washer
You probably have hoses and sump pump plugged/jammed by not enough to the machine from operating, my machine leaked prior to cleaning out all the hoses and sump pump
Posted on Oct 07, 2008
jumptrout51
  • 3361 Answers
SOURCE: Kenmore washer does not empty on spin cycle & is leaking water
This video will show you how to open the cabinet.
Ignore the coupling replacement.
Just use it for cabinet access.
The pump is attached to the motor.
Posted on Apr 21, 2009
SOURCE: GE Profile Washer leaking underneath during spin cycle
its your outer tub it has a hole in it
Posted on May 13, 2009
blueextc3221
  • 15935 Answers
SOURCE: Gorenje PS400GX Shorting
likely the motor has developed a short. It may be wet from a failed tub seal.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
I have just moved into an Apartment with a Gorenje wi 62112 Washing machine, I have no manual Can anyone tell me what the numbers on the Dial mean What should I choose for a general wash.
Gorenje has some documentation for their washers here: http://www.gorenje.com/simplicity/en/washing_machines/simple_manual_for_washing . The numbers indicate the water temperature (in Celsius) for a given cycle. The common choices are a cottons load in hot water (60 degrees). This is great for towels and other whites. The mixed load is for permanent press that can be in warm water (40 degrees). Then there is a cold water cycle for delicates (30 degrees). However, you should check the fabric care label before choosing the cycle.
I hope this helps.
Apr 20, 2016 | General Washing Machines
Can a clogged filter cause my machine to leak?
Yes. A clogged filter can cause your machine to leak. Always keep filters clean-especially using well water.
Mar 09, 2015 | Gorenje W7543LR Red 600 mm Washer Front...
I'm trying to repair a leak coming from the spout. I don't know where the washer would be. Do I have to replace the whole cartridge? It doesn't seem to come apart to find the washer.
If you faucet is leaking, try this simple step to see if it will stop. First, turn the water supply line off under the sink. Next, open the valve that is leaking all the way open. Take a wrench and tighten the nut just below the faucet handle. Now turn the vale to off and open your supply line and then test the faucet again. What you are doing here is tightning the packing nut inside the faucet. Good luck.
Mar 09, 2012 | Plumbing
My whirlpool washer is leaking from the front center. Happens during spin cycle I think.
Hello.
If your washing machine is leaking, don't rush out to buy a new one just yet. Sometimes simple repairs to the machine can fix the leaks saving you hundreds of dollars and days of shopping for and installing a new one. Luckily, you don't have to be a master electrician to do repairs. These steps will walk you through the basics of fixing a washing machine.
Bellow are Instructions on how to solve the problem of leaking washing machine
    • 1 Look at the floor drain to make sure it isn't clogged. Sometimes it's not even the washing machine, but the drain causing those puddles of water on the floor. Unclogging the drain can be an easy and quick fix.
    • 2 Inspect the hoses for leaks or wear and tear in certain spots. Filling the washing machine may help identify any leaks or faulty hoses. If hoses are worn, replace them with non-burst stainless steel mesh hoses.
    • 3 Check the fittings of the existing hoses to the faucet fixtures and on the back of the washing machine. Sometimes a loose connection is the cause for the leaks. Tighten couplings and hose clamps if necessary to fix the leaks.
    • 4 Replace internal washers inside of the hoses if not replacing the entire hose. Something as small as a rubber gasket can create a lot of water damage. Use a screwdriver to pop the worn washer out and replace it. Repeat replacing washers on the other end of the hose.
    • 5 Examine internal components by opening the cabinet and starting the fill cycle to see if anything is leaking internally. Calcium deposits and rust may be evident around areas that have leaks.
    • 6 Use hose clamp pliers to remove any corroded spring clamps and replace them with new ones. Make sure the hose is still intact underneath the old clamp. If not, remove the internal hose and take it to an appliance repair center to find the correct replacement part.
Thanks.
Sep 03, 2011 | Whirlpool Washing Machines
Have 97 Ford T bird. I sprayed with a power washer not thinking and since the pcv rattled. I took it out and replaced. Check engine is flashing and missed @1500-2000 rpm and I think it sounds like an...
more and likely water has gotten drowned out one of you coils . this was a problem for ford with water getting around the boots and killing the coil. you can have you check engine light scan at a advance or autozone for free. it should come up with a cylinder miss fire code. post back and let me know.
Apr 08, 2010 | 1999 Ford Expedition
Wont drain water Gorenje WA61111
locate the filter and clean, this should cure
Dec 16, 2009 | Asko W600
Jan 14, 2009 | Washing Machines
Kenmore HE4T Washer Leak
there are 2 possible causes.
either
inlet valve leaking - turn water off and if water fill stops, it indicates valve leaking
valve being powered when machine off. this is very unlikely but to check, disconnect washer and see if problem stops
also, if drain is plumbed into a spigot on the sink trap, every time you empty the sink, some of the water will flow into the machine. to cure this, take the drain hose as high as possible under the sink in a swan neck
Oct 20, 2008 | Kenmore Elite 45986 Front Load Washer
How open wahser in OLD thin twin stacked dryer/washer
yep give me the model num or brand name so i know what im dealing with
Dec 30, 2007 | Washing Machines
Washing Machines Logo
48 people viewed this question
Top Washing Machines Experts
