Xerox 770 tray 6 misfeed
Xerox tray 6 not printing 9x12 envelopes we try different setting, weight, rotation is does not make it out of tray 6
  • 208 Answers
SOURCE: Can't print envelopes
Solution Title: How to print on COM10 envelops from the Bypass tray (PCL6) using a Windows 2000 O/S Resolution/
Solution
thumbsup.gif Fixed! thumbsdn.gif Did not fix. Resolution Role: Fix
Critical Message: The Envelope must be placed in the Bypass Tray face down (flap side up) and Long Edge IN. In Microsoft Word (Word 2000)
    1. Under the Tools tab, select Envelopes and Labels.
    2. Enter your Delivery and Return addresses.
    3. Click on Options
    4. Under Envelope Options; [Envelope size], select Size 10 (41/8 x 91/2 in)
    5. Under Printing Options, select Portrait (LEF) - Long Edge Feed
        • As Feed from, select Tray 5 (Bypass)
    6. Click <OK>
Within the WorkCentre Pro 123/128 print driver
After opening up the print driver [<Start>, <Settings>, <Printers>, double-click on the WCP 128 PCL6 driver], click on Printing Preferences under the General tab.
  • Under the Paper/Output tab
Set the following features as follow:
    • Job Type: Normal Print
    • Paper Size: COM10
    • Output Size: Same as Paper Size
    • Image orientation: Portrait
    • Image Rotation: OFF
    • 2 sided Print: 1 sided Print
    • Stapling: None
    • Output destination: Center Output Tray
    • Offset Stacking: None
  • Under Tray/Layout
  • Set Paper Source to Tray 5 (Bypass)
  • Click on Bypass Tray Settings
    • Paper Type: Heavyweight (1 or 2)
    • Feed orientation: Portrait
  • Click <OK>
  • " on Specify Paper Type and select Heavyweight (1 or 2)
  • " (Apply> and <OK>
  • " <OK> again
In Microsoft Word under Envelopes and Labels, Click <Print> to send the information to the printer.
Note: This setup represents one way of printing envelopes. Other ways setting up some features in a different manner will work as well.
Solution v1.3.20.0 312637.How to Print on COM10 Envelops From the Bypass Tray (PCL6) 2006-04-05 21:57:29
Posted on Nov 28, 2007
  • 208 Answers
SOURCE: Unable to print envelopes on Xerox WorkCentre Pro 123
Some thoughts.
Envelopes won't print from bypass tray. Cause:
Extended tray is not set up properly for envelopes. Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. Enter tools "Login" 1,1,1,1,1 Touch buttons with the following names in that order: System Settings System Settings Common Settings Other Settings Scroll down to "Extended Tray" Next to "Extended Tray" it may say "Inverter" if it does go to change settings then change it to "Offset Stacking" Close out tools.
Posted on Nov 30, 2007
  • 2072 Answers
SOURCE: How to print C5 & C4 envelopes
Here is the answer from Xerox.
> Support & Drivers > DocuColor 12 Copier/Printer Support > Search Results Solution: Printing on Envelopes is Not Supported bttn_print.gifMake Printable bttn_email.gifEmail this page elem_1_spacer.gif
CAUTION: Printing on envelopes may cause damage to the copier / printer.
Posted on Jan 08, 2008
  • 2072 Answers
SOURCE: I can't seem to print envelopes on the xerox workcentre 7345. I fed the envelope into the bypass tray, configured the settings on the workcentre as well as the word doc, but it gives me an error 012-2
There is a lengthy set up process to that. I would recommend going ot Xerox.com, then at the home page, click on Support and drivers. When you get to that page, type in 7345, then click on the support home page, once there type in envelopes and the step by step instructions are there.
You are correct, setting up envelope printing on that machine can cause you to beat your head against a wall. The machine settings and the driver settings MUST be set exact. And it may take 3 or 4 tries, even for a service rep to get it all correct. Trust me on that LOL.
But once set up, it does a nice job. It is just very picky. Personally, I think it is way over designed just to print an envelope.
Posted on May 20, 2009
SOURCE: I have a Xerox Phaser 6180MFP and when I print #10...
I am looking for a diagram on how to print envelopes with my phaser 6180 mfp - when I put the envelopes in, it keeps telling me that I need to put paper in. where can I find such diagram?
Posted on Mar 21, 2011
How to print #10 envelopes on a Xerox 3610 printer?
Solution : Print on Envelopes You can print envelopes from the Bypass Tray only.
Guidelines for Printing Envelopes
  • Print quality depends on the quality and construction of the envelopes. Try another envelope brand if you do not get desired results.
  • Maintain constant temperatures and relative humidity.
  • Store unused envelopes in their packaging to avoid excess moisture and dryness which can affect print quality and cause wrinkling. Excessive moisture can cause the envelopes to seal before or during printing.
  • Remove air bubbles from the envelopes before loading them into the tray by setting a heavy book on top of them.
  • In the print driver software, select Envelope as the paper type.
  • Do not use padded envelopes. Use envelopes that lie flat on a surface.
  • Do not use envelopes with heat activated glue.
  • Do not use envelopes with press and seal flaps.
  • Use only paper envelopes.
  • Do not use envelopes with windows or metal clasps.
To Load Envelopes in the Bypass Tray:
  1. Open the Bypass Tray.
  3. Move the width guides to the edges of the tray.
    NOTE: If you do not load envelopes in the Bypass Tray right after they have been removed from the packaging, they can bulge. Flatten them to avoid jams.
  4. To load envelopes, select an option:
    • For Number 10 envelopes, load the envelopes with the short edge going into the printer, flaps down, and flaps to the right.
    • For C5 envelopes, do one of the following. If the envelopes wrinkle, try another option.
      • Insert envelopes with the print side up, flaps closed and down, and flaps going into the printer.
    • NOTE: When loading Monarch or DL envelopes, remove the Multipurpose Tray.
  5. On the printer Control Panel, press the Menu button.
    NOTE: To navigate through the menu, use the Up or Down arrow buttons.
  6. Navigate to Tray Settings, then press OK.
  7. Navigate to the Bypass Tray, then press OK.
  8. Navigate to Tray Mode, then press OK.
  9. Navigate to Panel Specified, then press OK.
  10. To return to the previous menu, press the Left arrow button.
  11. Navigate to Paper Type, then press OK.
  12. Navigate to Envelope, then press OK.
  13. To return to the previous menu, press the Left arrow button.
  14. Navigate to Paper Size, then press OK.
  15. Navigate to the required envelope size, then press OK.
Phaser 3610 Support Drivers
Apr 09, 2014 | Xerox Office Equipment & Supplies
I can't get anything to print from tray 1, the manual feed. I'm trying to print envelopes and they keep printing on 8.5x11 paper from tray 2. If I put envelopes in tray 2 it won't print
Have you already tried this? After you click print and select your printer, click properites and select your paper from 8.5x11 to Envelope.
Jun 25, 2012 | Xerox Phaser 8560MFP Laser Printer
I need to print standard size 10 envelopes. Where/How do I load them? WorkCentre7335
Some setup will be necessary both on the WorkCenter and in your software. I will describe these steps and leave you with a link to Xerox to check as a reference:
On the WorkCenter 7335
1) In the Bypass tray, load the std. 10 envelopes width-wise with the side to be printed down, flaps tucked in and with flaps entering the printer first. Slide the guide to just touch the edges.
2) Touch <Change Settings> on the WC 7335 screen
3) Select "Envelope" from the "Paper Type" list
4) Select "No. 10 Env" from the "Paper Size" list
5) Select "Save"
6) Select "Confirm"
In your software:
As you did not specify your software, it is important to note that whatever application you are using, the following settings must agree with the steps above:
1) Feed method = Face down, Clockwise rotation
2) Feed from = Bypass
These options may be chosen in different ways depending on your software program.
You may review these setup steps for Word here:
Xerox WC 7335 Print Size 10 Envelope
Jan 25, 2010 | Xerox WorkCentre M118 Laser Printer
Envelope Feeder is not accepting the command
> Home > Support & Drivers > Knowledge Base
Solution --> Phaser 4400 Printer: Printing envelopes
Printing EnvelopesEnvelopes can be printed from the optional envelope feeder, the Multi-Purpose Tray, or Tray 1, 2, or 3.
Guidelines for envelope printing
  • Do not print on the back of the envelope.
  • Never use envelopes with windows, metal clasps, or exposed gummed surfaces.
  • Keep unused envelopes in their packaging to avoid the effects of moisture and dryness, which can affect print quality and cause wrinkling.
  • Envelopes may wrinkle depending on weight and stiffness of the envelope.
Many applications include a tool for creating an envelope document. For example, Microsoft Word includes an Envelopes and Labels feature in the Tools menu. Be sure to:
  • Select faceup.
  • Clear Clockwise Rotation.
  • Select the feed method with the image centered and the stamp on the envelope to the upper left.
caution_image88x30.gif Never use envelopes with windows, metal clasps, or exposed gummed surfaces; they can damage the printer. Damage caused by using unsupported envelopes might not be covered by your printer's warranty.
note_image33x30.gif Note: The heat from the printing process can melt certain types of envelope glue. If the envelope flap sticks shut after printing the test print, tuck the flaps inside the envelopes when printing the remaining envelopes. Printing envelopes from the envelope feeder
  1. Insert the envelopes into the envelope feeder. For more information, refer to the Trays section of the Trays and Paper Guide on the Interactive Documentation CD-ROM.
    • Place the side to be printed faceup.
    • The top of the envelopes should be toward the left of the printer.
Feb 19, 2008 | Xerox Phaser 4400B Laser Printer
Some thoughts.
Nov 22, 2007 | Xerox WorkCentre Pro 123 All-In-One Laser...
PRINT ENVELOPES
You MUST use the bypass tray and bve sure to enter the custom size, media type and weight in the driver. The settings MUST be set the same on the 180 before printing.
Running envelopes is a tricky situation, but once mastered it should work. Note that not all envelopes will run, try different sizes and brands and keep the ones that work.
Nov 16, 2007 | Konica Minolta bizhub 180 All-In-One...
Max Paper Weight
Here ya go...
Tray 1: (standard) 16 lb. Bond – 80 lb. Cover (60 – 220 gsm), coated, Phaser High Resolution Photo Paper, labels, envelopes, business cards, Phaser Professional Solid Ink Transparencies, Phaser Weatherproof Paper, Phaser Postcards, Phaser Trifold Brochures. Media sizes: A/Letter, Legal, Executive, Statement, US Folio, A4, A5, A6, B5 JIS, B5 ISO, 3 5 in. Index Cards, custom sizes; Envelopes: #10 Commercial, DL, C5, #5 , #6 , Monarch, Booklet, Lee (A7), Choukei 3 Gou, Choukei 4 Gou, custom.
Tray 2: 525-sheet tray (standard) 16 lb. Bond – 28 lb. Cover (60 –122 gsm), coated, Phaser High Resolution Photo Paper, labels, envelopes, Phaser Professional Solid Ink Transparencies, Phaser Weatherproof Paper, Phaser Postcards,Phaser Trifold Brochures. Media sizes: A/Letter, Legal, Executive, Statement, US Folio, A4, B5 JIS, B5 ISO; Envelopes: #10 Commercial, DL, and C5.
Tray 3: 525-sheet Feeder (standard on DX) Same media weights and sizes as Tray 2.
Tray 4: 525-sheet Feeder (optional) Same media weights and sizes as Tray 2.
Nov 12, 2007 | Xerox Phaser 8400 Laser Printer
Solution
    3. Click on Options
    6. Click <OK>
    • Paper Size: COM10
    • Stapling: None
  • Under Tray/Layout
  • Click <OK>
  • " <OK> again
Nov 02, 2007 | Xerox WorkCentre PRO 128 Copier
100 people viewed this question
k24674
jasbo
jasbo
