Question about Toshiba 51H84 51" Rear Projection HDTV-Ready Television
What bulb do I need forToshiba 51h84c rear projection?
I have the back off looks like 3 bulbs. True or false
Not bulbs, but 3 CRT tubes is what you are seeing rear projection TV's don't use bulbs onlly DLP projection uses a bulb as a light source....
http://tvtechwork.webs.com/
Nov 17, 2010 | Samsung HCM4215W 42" Rear Projection...
Hi I need a replacement bulb for my WS-55411 Mitsubishi. Can you help me find the right bulb and it's part number? The screen blacked out and sound still works so I assume I need a new bulb. When I shop...
Your model doesnt have a bulb since its a rear projection TV . It has three picture tubes, However loss of video with audio still working is usually caused by a vertical output failure.
Jul 28, 2010 | Mitsubishi WS-55411 55" Rear Projection...
I have a 1994 zenith big screen the picture is showing really dar
It could be that the picture tubes have gone down on emission, there is a prcedure that can be tried to bring up the overall brightness but it is just possible that you will loose some picture quality. If it's a 1994 projo tv i am thinking of the three crt system, a gray scale alignment would probably correct the dark condition in your picture, again depending on how far gone is the emission in your picture tubes, if your projo tv is the dlp system, the bad news is that you could be needing some light engine repair. The color adjustment is possible with the availability of a service manual or in the case of the dlp system, light engine repairs or replacement are available from some on line stores.
Jan 12, 2010 | Zenith E44W46LCD 44" Rear Projection...
Replacement Lamps/Bulbs for Philips 50P8341 Rear Projection TV
These are both CRT type TV's(3 picture tubes drive the image) with different screen sizes and the CRT's are not interchangeable
Oct 24, 2009 | Philips 50P8341 50" Rear Projection...
Stereo hook up to my 51h84c toshiba
YES YOU CAN DO IT BY YOURSELF. IF YOU HAVE A STEREO, IT SHOULD HAVE AUX INPUT...YOU WILL NEED AUDIO CABLES, RED AND WHITE...CHECK AT THE BACK OF YOUR TV, WHICH SAYS...AUDIO OUT..PLUG THAT TWO CABLES COLOUR CODE MODE...AND THIS END YOUR CABLE GOES IN YOUR STEREO AUX INPUT...ON YOUR STEREO SWITCH TO AUX AND SAME TIME ON YOUR TV....SO YOU WILL BE ABLE TO HEAR SOUND
Oct 14, 2009 | Toshiba 51H84 51" Rear Projection...
Need a red bulb for Zenith PVR5263RK rear projection tv
It sounds like your looking for a CRT (red) the part # is on the CRT and could be puchased through any Zenith (LG) distributer- usually around $300- $500. Google the part # when you get it and you may find a used Picture Tube (CRT)for cheaper.
Sep 22, 2009 | Zenith R57W46 57" Rear Projection...
How long do the bulbs last
Hello Dingbo the bulb usually last anywhere from 3-5 years on rear projection tv sets, every bulb is different in specs, but they usually have like 5,000 hours or so of working time. Now Ding from my experience i have seen rear projection tv sets last up to 15 years, Thank You hope this helps.
Sep 07, 2009 | Hitachi 57F500 57" Rear Projection...
DARK PICTURE ON MY SAMSUNG DLP/HD REAR PROJECTION TV
It sounds like you need to buy a new bulb, this is what usually happens when the bulb is burning out this bulbs are made to last 6000-8000 life hours
http://www.discount-merchant.com/
Nov 21, 2008 | Samsung HLP4674W 46" Rear Projection HDTV
Toshiba 51H84 51" Rear Projection HDTV-Ready Television Logo
85 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
