Question about Whirlpool Dehumidifier Dehumidifier
Dehumidifier doesnt remove water
Motor runs but no moisture removed
ttech
  • 139 Answers
SOURCE: Unit cycles off but back on quickly. Does not remove moisture.
It needs the Cover removed and take to the Local Car wash and clear the Front and Back out get all the Junk off of it Use Engine Cleaner first let soak then High Rinse Bring Home let sit outside for A Couple of Hours reassemble and She should Run like New ttech
Posted on Jul 21, 2007
SOURCE: I have a Whirlpool dehumidifier that doesn't collect water
I have a Whirlpool dehumidifier model AD50LJ0: the compressor starts but then appears to trip out. The fan keeps running. It does not condense and water. Can you help?
Posted on Jun 12, 2009
edgreason
  • 120 Answers
SOURCE: Dehumidifer
timer is not working, or thermocouple is defective.
unit must cycle forward-reverse to remove ice, thisis how it works, by melting the ice that forms.
Posted on Apr 06, 2010
heatman101
  • 43501 Answers
SOURCE: have whirlpool dehumidifier.motor runs but no more water collects
Here is a tip that I wrote that will help you...
http://www.fixya.com/support/r3877515-dehumidifier_problems_dehumidifier
heatman101
Posted on Apr 16, 2010
heatman101
  • 43501 Answers
SOURCE: doesn't remove moisture
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Posted on May 20, 2010
Our DeLonghi condensation removal system no longer removes moisture; it appears to run fine; the lights indicate all systems are on. I have cleaned the filter; cleaned the tube; disconnected the tube; set...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
heatman101
Aug 28, 2011 | DeLonghi DH100P Dehumidifier
Dehumidifier (M7DH45B2A) runs but is not removing moisture from the air. The compressor goes on as does the fan.
heatman101
Aug 27, 2011 | Maytag M7DH45B2A Dehumidifier
Doesnt remove moisture from the air. motor runs
heatman101
Aug 23, 2011 | Kenmore 54701 Dehumidifier
Does not collect water in bucket but runs all the time
Does it have a filter?
http://whirlpool.custhelp.com/app/answers/detail/a_id/953
also:
It may be that the humidity level or temperature in the room where your dehumidifier is located is too low.
When the outdoor temperature is below 50 F, the indoor air will be dry even when the air inside is warm, therefore when it's cold outside the dehumidifier may collect little or no water.
Air conditioners will also remove moisture from the room, even if it's hot and humid outside, resulting in little or no moisture collecting in the dehumidifier bucket.
Some dehumidifiers have a deicer which turns off the compressor but keeps the fan running. When the compressor is off, moisture is not removed from the air. The deicer turns off the compressor when the room temperature is cold.
Some dehumidifiers do not have a deicer. If the room temperature is low enough, ice may form on the evaporator coil. The ice prevents the dehumidifier from removing and collecting water. If ice forms on coils, unplug dehumidifier until ice melts and room temperature rises."
Jun 21, 2011 | Whirlpool AD25BBK Dehumidifier
The dehumidifier runs but does not remove moisture. The coils are cold but no frost. The inner coil is hot.
heatman101
May 17, 2011 | Amana D530M Dehumidifier
Dehumdifier not collecting water.
The filter (on some models) may be dirty or clogged. If so, clean the filter. For instructions on cleaning the filter.
I hope this help to solve, if this answer solve it, remember to rate it. Good luck.
Oct 01, 2010 | Whirlpool AD50USL Dehumidifier
Doesn't remove moisture
heatman101
May 17, 2010 | Whirlpool AD50USL Dehumidifier
The dihumidifidier is not drawing water. It is
In order for the Dehumidifier to remove moisture, the coil temperature has to be below the dewpoint temperature. If you check with the weather station and find out what the dewpoint is in your area, then measure the coil temperature or cold line coming out of the coil,it has to be below the dewpoint to get moisture, you can also look at the coil and see if it's wet which will also tell you if the coil is below the dewpoint.
Aug 05, 2009 | Whirlpool Gold AD70USS 70 Pint Per Day...
(New Unit) Motor Runs, Does Not Extract Moisture
Try setting you temperature or fan speed lower this may help.
In order for the unit to remove moisture the coil has to be below the dewpoint.
Aug 02, 2009 | Haier HD451E Dehumidifier
Dehumidifier not removed moisture from air
heatman101
Aug 30, 2008 | DeLonghi DE400P Dehumidifier
Dehumidifiers Logo
24 people viewed this question
Top Whirlpool Dehumidifiers Experts
Bill Long
Mike
Terry Schneider
Are you a Whirlpool Dehumidifier Expert? Answer questions, earn points and help others
