Question about SanDisk Sansa e140 MP3 Player
Help needed i need help with my sansa.... i turned it on...... but it doesnt want to.... i tried changing the battery like five times but it doesnt want to turn on......i even tried to connect it to the laptop i have but it doest not want to turn on!!! i even downloaded new songs too!!!
Here is a fix I got from Sandisk support: Let's try this: take the battery out of the player and wait for a full 5 minutes. While the battery is out, please hold the power-on button for 10 seconds. After that, connect it to your computer (without the battery). Does it work when it's connected to the computer? Regardless of that result, disconnect it from the computer, then put a brand new alkaline battery back in, and see if it will turn on. Now, another thing I found that worked once, was to remove the battery, hold the power button for 5 seconds, then replace battery. The unit powered up after that.
Posted on Aug 24, 2006
2005 pontiac GTO - Oil change light came on. I change the oil and filter, it took almost seven Quarts. Drain it by jacking up the left side, right side and back of car. I then tried to reset the the change...
no need to fear, this is a common problem. all you need to do is turn the key to the on position, push the pedal three times, then turn key to the off lock position. this is a typo in the manual. not sure why they have not corrected this issue. hope this helps.
Apr 07, 2011 | 2005 Pontiac GTO
Hi! My Sansa e260 won't turn on. It charges
try upgrading the firmware...if that doesnt help u'll need to replace the battery here's how to update firmware- http://kb.sandisk.com/app/answers/detail/a_id/306
Aug 14, 2009 | SanDisk Sansa e260 MP3 Player
NOT DETECTING
first try changing the usb mode in your settings if still doesnt connect try this...
1 put on hold and hold record button while u turn on (your sansa is now in recovery mode)
2 connect your sansa to your comp via usb cable a box should show up saying the firmware version
3 close the window and disconnect your sansa (it will restart)
I hope my post was helpful let me know!!!!
Mar 13, 2009 | SanDisk Sansa e270 MP3 Player
Screen froze on a song
I have the exact mp3 player and this has happened to me many times. Try holding the power button for a minute or two and if that doesn't work you will need to take the screws off of the back cover. In there the battery will be right on top. Pull it out for a few seconds and put it back in. That will fix your problem.
Feb 10, 2009 | SanDisk Sansa e250 MP3 Player
My sansa e250 mp3 player is unable to connect to computer nor recognized to use .It won`t turn on change the modes
turning on to change modes is your problem. If it's completely dead you may need to replace it or refurbish it. Or if the battery is completely dead plug it in all day until you can get it to turn on. ONCE ON then you can worry about getting it to connect. Try this:
There are two connection settings in USB: MTP and MSC. For some reason MTP is the default, but it doesn't connect properly on all computers. Select MSC and plug the player in again, the computer will recognize sansa e250 but not show the driver just yet. It is installing recognition software (just basic drivers - nothing heavy) and it doesnt tell you what its doing until its complete. WAIT FOR IT. Once it is complete you will see both the sansa e250 and the removable memory slot in your "my computer" now you're good to go.
Jan 18, 2009 | SanDisk Sansa e250 MP3 Player
My display doesnt work
My son had the same problem. I think he let it get too hot, left it setting in the sun too long. We tried everything. Unfortunately, he had to reformat, and lost everything. But he had all his date backed up on an external harddrive. Sorry....
Jun 28, 2008 | SanDisk Sansa e250 MP3 Player
It doesn't turn on!!
I'm having the same kind of problem. Its really wierd and i'm really worried about it bcoz its my first mp3 player.
Apr 15, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sansa sandisk c150 mp3 player
Try to reset your device by holding the power button down for 15-20 seconds or until it resets....If that doesnt help you get the latest firmware upgrade for your device...that should solve the problems you are having...
Nov 28, 2007 | SanDisk Sansa c150 MP3 Player
Sansa e250
Try changing the MODE on the device thru Settings>Mode or USB Mode.
Then try connecting to the PC again.
If that doesnt work, add to the question and ill try something else.
Best of Luck.
Oct 31, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e140 MP3 Player Logo
65 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
