Question about Schlage FE595VCAM716ACC Camelot Keypad Entry Lever Door Lock Aged Bronze
I need to set/change the code on my Schlage lock but the sticker is completely unreadable.
Bought an old house with a Schlage keyless entry lever on it. I have the key but would love to get the combination pad to work. Also many similar questions on this site refer to here: http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx which DOES NOT EXSIST anymore (error 404).
  • 963 Answers
I do not believe you will be able to reprogram the lock without the programming code, usually found on the sticker (unreadable, in your case).
Therefore, I urge you to call Schlage directly-they may be able to help you. here is the contact information:
United States Customer Support
Warranty & Technical Information: 1.888.805.9837
You are right about the support link going 404-It used to work. Get there by going to:Schlage.com
and clicking on "For your home"
Mouse over the "Service & Support" link, then go down & left click on "Instruction & Manuals". There ya go!
Posted on Feb 22, 2012
5 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: to drop my code and put a new code in my schlage keyless door loc
http://consumer.schlage.com/customerservice/pdfs/Programming_Deadbolt.pdf
Posted on Mar 13, 2009
VtToolMan
  • 704 Answers
SOURCE: need info to change code
Here's a link to the Schlage web site with pdf's and videos showing how to operate and program your lockset.
Just select which info you need from the list on the page.
http://consumer.schlage.com/customerservice/FE575_install_inst.asp
Hope you find this Very Helpful - Best regards!
Posted on Aug 20, 2009
SOURCE: Schlage FE365v keyless entry lock.. Lost manual. Forgot 6 digit programming code. Need instructions to restore and set all new codes.
look on the sticker located inside the outer panelo on the lock. you are going to need to disassemble the unit but it is in there.
Posted on Aug 08, 2010
  • 963 Answers
SOURCE: Lost instructions on how to
This link will take you to the page you need, to get started:
Then scroll down to this heading on that page:
Electronic Security-Keypad Entry Flex-Lock...
There's a wealth of info under that heading. You will be able to see a PDF file of the original print instructions, as well as a video of how to install the lock. This is useful because there should be a sticker to be found on the backside of the keypad, with the code number ( the programming code) that you need to reprogram the lock. This installation video (fourth item down) will be useful to allow you to disassemble it and view the sticker. This is also a great time to change the 9-volt battery! A battery should last about three years under normal usage.
The ninth item under that same header is a video which walks you through how to reprogram the keypad to your new code, using that program code that you found on the backside of the keypad.
A note about the PDF files: If you cannot view a given file, you need to first install Adobe reader. You can get the free download from here:
http://get.adobe.com/reader/
Good luck--and please provide feedback if this helps!
Posted on Nov 10, 2011
Keypads on Schlage locks
Answer from Schlage.
Thank you for your e-mail. Unfortunately if he had these locks on his business there is nothing we can do as far as repair. And unfortunately there are no dealers who have the parts available for repair. These are strictly residential keypads. I am sorry about this.
Joshua Bozarth
Consumer Loyalty Representative
Schlage Customer Commitment Center
2119 East Kansas City Road - Olathe, KS 66061
Feb 13, 2014 | Schlage Locks & Locksmithing
Programming code will not work
I work for factorylocks.com. We get programing questions all the time for Schlage FE575/595. The factory default programming code and PIN codes are on a sticker stuck to the inside of the front housing of the lock. You will need to take the lock off of the door to see this sticker. Once you have done so, reset the lock back to the factory defaults and reprogram the locks to your settings using the programming instructions you can find here http://www.youtube.com/watch?v=z8BgHP712eg
Feb 03, 2013 | Schlage FE595 Plymouth Electronic Keypad...
Schlage keyless lock lost 6 digit code and no sticker inside either
You will need to take the keypad look off of your
door and record the 6 digit programming code and the two factory
default PIN codes. You then need to perform the factory reset to
erase any codes and restore the lock back to the factory defaults.
This procedure is outlined, as well as the programming of the device, in the attached instructions.
http://www.factorylocks.com/PDFs/Programming%20Instructions.pdf
Regards,
Leslie
Factorylocks.com
877-345-6257 (877-34-LOCKS)
Jan 13, 2013 | Schlage FE595 Plymouth Electronic Keypad...
I have a schlage keyless entry door deadbold/doorknob system. i change the batteries (have done before) now my combination does not work and my reset button is not giving me the 2 beep go ahead signal
I don't have a direct answer, but here is the contact info you need for customer service:
Schlage Lock Company
Customer Service Department
2119 E Kansas City Rd
Olathe, KS 66061
Oct 03, 2012 | Schlage Locks & Locksmithing
Need to find code for Schlage keypad door lock but the sticker behind the plate is unreadable. I do have a key.
I don't believe that you can do without the programming code found on the sticker.Here is the contact info you need for customer service:
Olathe, KS 66061
http://consumer.schlage.com/Service-Support/Pages/ContactUs.aspx
Schlage FAQ: http://consumer.schlage.com/Service-Support/Pages/InstallationTroubleshooting.aspx
http://consumer.schlage.com/Service-Support/Pages/FAQ.aspx
Instructions & Manuals: http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
I urge you to call and I hope that they can help you. Good luck!
Feb 15, 2012 | Schlage FE595VCAM716ACC Camelot Keypad...
I have lost my pc for my schlage door lock. How do I fix that?
No problem!
A quick note: The back plate of the keypad side of the lock on the exterior of the door has a sticker which includes the serial number, six digit programming code and two pre-programmed four digit user codes. The lock must be disassembled to a point the exterior of the lock can be pulled away from the door and the information on the sticker made note of.
This link will take you to the page that you need to get started:
Electronic Security-Keypad Entry Flex-Lock FE595/Keypad Entry Auto-Lock FE575 Documents
There's a wealth of info under that heading. You will be able to see a PDF file of the original print instructions, as well as a video of how to install the lock. This is useful because there should be a sticker to be found on the backside of the keypad, with the code number that you need to reprogram the lock, which i noted above. This installation video (fourth item down) will be useful to allow you to disassemble it and view the sticker. This is also a great time to change the 9-volt battery!
The eighth item under that same header is a video which walks you through how to reprogram the keypad to your new code, using that programming code that you found on the backside of the keypad.
Also, you will find "Keypad Programming Guide", etc. links which are PDF type files, giving you a "picture" of the print instructions.
Good luck,and please provide feedback if this helps!
Oct 03, 2011 | Schlage FE595VCAM716ACC Camelot Keypad...
I have a schlage camelot leverset and i need to change the code. its a 4 digit code...How do i do this? thanks
No problem!
Aug 17, 2011 | Schlage FE595VCAM716ACC Camelot Keypad...
I need to change the batteries and reset the pass code in (2) keyless locks ("Locknetics On Board"). The owner's manuals were never given, and the key (Schlage) override was never used.(No...
How can I program my electronic keypad lock when the instructions with the programming code have been lost?
This number is the programming code referenced in the information for changing the entry code.
Electronic Security-Keypad Entry Flex-lock FE595/Keypad Entry Auto-Lock FE575 Documents
There's a wealth of info under that heading. You will be able to see a PDF file of the original print instructions, as well as a video of how to install the lock. This installation video (third item down) will be useful to allow you to disassemble it and view the sticker. This is also a great time to change the 9-volt battery! Batteries should be replace about every three years.
Jul 06, 2011 | Schlage FE595VCAM716ACC Camelot Keypad...
Can't remember how to reset our door code.
Since you have the model number, you should be able to call Schlage and they'll tell you how to reset it.
Apr 06, 2011 | Schlage FE595VCAM716ACC Camelot Keypad...
I need to change the combination on the Schlag lock. It is about 2 years old the numbers light up and it also has a key. It is an indoor lock. can yoiu please help me.
You might find the answers on on this page:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx#13
Also, the page for frequently asked questions may help:
Mar 05, 2011 | Schlage Locks & Locksmithing
Schlage FE595VCAM716ACC Camelot Keypad Entry Lever Door Lock Aged Bronze Logo
285 people viewed this question
Top Schlage Locks & Locksmithing Experts
JOHN LAPIER
ken skalski
Are you a Schlage Lock and Locksmithing Expert? Answer questions, earn points and help others
