Question about One For All URC-3300 Remote Control
I need a manual for dreamax freeview set up box
2 Suggested Answers
gopakumarg43
  • 74482 Answers
SOURCE: what are the programming codes for a dual tv and
Hello
Dremax Frewiew sat box is not listed with One for all URC-3300 codes.
OK.
Posted on Jun 22, 2011
My techwood freeview box was working i feel aaleep n woke to a black screen & my freeview box appears to be atuck in standby mode. Can you help please?
Hi Yvonne
"FreeView"
You must be in Australia. Like me.
I would assume that you have pulled the power out & reset the unit. I don't have the freeview box but they can be similar to other set top boxes.
Does the user manual indicate that holding down certain buttons on startup will cause a reset?
Some of these units have an internal backup battery to keep your parameters in memory. Often not user accessible.
But in emergency, the battery (if you find it) can be given a quick short with a jumper wire to reset it.
Otherwise You might need a tech to look at it or swap it out
Good Luck
Apr 02, 2015 | Televison & Video
How do i tune my SAMSUNG PS42S5H for high definition channels
Does this model of TV have a built in HD receiver? I've had a quick look at the instruction manual and it looks more or less the same as mine at home. I've not got HD tv reception built in but have to use a set top box. If you're in UK, it should have Freeview HD sticker from the box or manual somewhere but as this looks like an early model tv (only 1 HDMI socket) then you may need a HD set top box such as Sky HD or Freeview HD
Oct 15, 2014 | Televison & Video
My VCR/DVD, freeview box and non digital tv will show prerecorded video and DVD but will not record (or if it has it will not display). Could it be that the set up is not wired up correctly? The freeview...
Unless the Freeview box has two tuners then your going to have problems anyway when you want to record something and watch the non-digital TV at the same time. The solution is simple get another Freeview box (they are around £10 at the moment on E-Buyer.Com) get a box like this:
grubhead_17.jpg Available on Amazon (Scart switching box). This plugs into the TV or you can connect via one of the freeview boxes. Whatever works best.
The VCR has the other Freeview box connected to the second scart. (select AV2 when setting the channel to record and set the box to the channel you want to record) the first scart from the VCR plugs into the above box. When you want to watch press the switch.
By the way if the VCR has PDC on it set it to off, as it no longer works with digital.
Aug 21, 2011 | Televison & Video
What are the programming codes for a dual tv and the dreamax freeview box....
Hello
OK.
Jun 22, 2011 | One For All URC-3300 Remote Control
Although the Freeview box is correctly installed with my TV,when the men button is pressed the only message to appear on the TV screen is No Signal,HELP!!
Ok, if you have "No Signal" that can only mean you must be selecting the wrong INPUT, when it is hooked up yo the TV, essentially the TV, is just a Display Monitor, and it doesn't use "Channels" anymore, it uses the AV, or EXTERNAL Inputs, any channel changing is done on the Freeview box. Make sure you are connected color to color, cables are connected. The antenna, goes into the freeview, the AV cables go to TV, taking the Video 7 Audio, from the Freeview box, to the "Screen" TV, set to the External input, that the "Box" has been connected too. Check your manual out.
May 08, 2010 | Televison & Video
No user manual for CE28DN9-B. Bought TVonics
HELLO
Follow these instructions:
Select a spare channel on your TV say 6 on your remote.
Press MENU.
Scroll down and select PRESET.
Using RIGHT button of F/OK/ENTER press it and this will go to TUNING.
Press RIGHT button again which will let you go to SEMI or AUTO tuning (for your purpose select "SEMI").
Scroll DOWN to highlight the actual UHF channel number or CH:C21 as it may appear on the screen.
Press the RIGHT button again yourself manually and you will see the channel number change anywhere from 21 to 69 until you come to your freeview box's RF channel output.
When you have done that scroll down to Memory and you'll see a box beside it. Press the RIGHT button and a tick will appear in the box.
You have stored your Freeview box RF channel on your TV.
Press MENU button THREE time to come out of the MENU setting.
Use this procedure again if you wish to change the RF channel on your TVONICS box.
GOOD LUCK (:-)
Oct 03, 2009 | Televison & Video
Similar problem as you helped me solve before.
OK, I think I see the problem there.
The aerial lead from the DVDR to TV should be removed.
You should have it setup the same as the other Freeview - VCR - TV
Nutshell time:
Main aerial to Freeview input.
Loop aerial from freeview output to DVDR areial input (all this does is allow you to watch freeview, or standard both out of the DVDR)
So..
Scart from Freeview to DVDR input
Scart from DVDR output to TV
Set DVDR to AV input mode.
Set TV to AV (whatever number you need for that..you now won't get anything on screen unless you have the right input selected)
If you can now see the Freeview picture on the TV and change the channels with the Freeview remote then you should be set for recording.
Having the aerial and a scart lead both going to the TV is not needed.
Apr 14, 2008 | Philips VR550 VHS VCR
Installation code tv set top box
try 1 2 3 4 universal settings works with mine
Mar 02, 2008 | Sagem PVR 6280 Freeview DTV Receiver /...
Can't re patch tv with set top box to watch tv
Hi.
Ok here goes.
1) Take airial lead from the wall socket in to antenna in on freeview box.
2) connect short usually black airial type lead in to antenna out socket on freeview. plug the other end of this lead in to aerial in on vcr.
3) connect the other end of this aerial type lead to airial plug on the back of tv.
4) now if you have 2 or more scart sockets on the back of tv set plug in the scarts in this order.
Freeview box scart with tv on it connect to scart 1 on tv set.
Freeview box vcr scart connect to vcr in scart socket on vcr.
Vcr scart marked tv plug scart from here to scart 2 on tv
If you have 3 scart sockets on tv you can connect dvd using scart to scart socket 3 on tv.
If Tv has only 1 scart the aerial leads will stay the same as I have stated,
Freeview must go to scart socket on tv set.
leave second scart from freeview to vcr plugged in so you can record freeview by putting vcr to line 1 or AV 1.
you will need to put tv on channel (0) & tune this channel to the video play a tape that you recognise then go to tv tuning & tune tv untill you see video playing then store this on channel (0).
DO NOT USE AUTO TUNING IT WILL PUT CHANNELS IN THE WRONG ORDER JUST USE MANUAL TUNING.
Now to view Dvd you will either need to purchase A scart switch box. Or have keep unpluging freeview scart from tv so you can plug in dvd .
If your tv has red yellow white phono sockets you can plug dvd in to these, you may need to purchase phono leads.
Hope this helps.
http://dysonmanuals.llc.nu/
Chris..
Jan 08, 2008 | Televison & Video
One For All URC-3300 Remote Control Logo
340 people viewed this question
Top One For All Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
