Question about Pool & Spa
Laars lite 2 LD400N - Igniter system looks nothing lke the picture in manual
My heater does not flameup so we are thinking it’s the igniter. My manual (for the "Model LG & LD Pool and Spa Heater") has an exploded parts view of the burner tray for the LD (Direct Ignition) model. While the picture of the gas valve for the LD matches what I actually have in my unit, the picture of the LD Igniter does not. The picture shows a hotsurface igniter (see a picture here: http://www.parts4heating.com/SearchResults.asp?Extensive_Search=Y&Search=R0317200), but what I actually see in my unit looks nothing like that. This makes identifying parts difficult for me--has anyone here gotten around this problem? How?
shuggie73
SOURCE: Laars lite II Pool and spa Heater LG model
Bad pilot generator? Flow issue?
Posted on May 25, 2009
  • 246 Answers
SOURCE: Jandy Lite 2 does not ignite
burners are plug with spider get a wire and bended get it inside the orifices where the gas come out every single one than try now ? magic heater comes on
Posted on Oct 16, 2009
  • 33 Answers
SOURCE: Iv got a Laars Lite 2 Pool pool heater Model Ld 400n
Problem with the thermocoupler its not producing a minivolt of 250 plus that is needed to open the main gas valve
http://www.laarsman.co.uk
Miles
Posted on Jun 05, 2010
  • 767 Answers
SOURCE: I have a Raypac digital
Hello my name is Heath it will be my pleasure to assist you. Find the rollout switch and on the back there is a small red button if you push the button in it will reset the switch. The rollout is usually located near the burner section of the heater.I will attach a picture of a rollout switch which shows the small red button.11c0d2e.jpg
Posted on Oct 25, 2010
heatman101
  • 43501 Answers
SOURCE: i have a laars lite
The control module is not sensing the flame.
You did not list the exact model number but I think this kit will fit your heater.
Check your model number to tell for sure.
Flame sense kit
heatman101
Posted on May 24, 2011
Laars Lite 2
If the heater is "acting normal" with no failure codes and you smell gas, then I would bet it's the igniter. The fact that you smell gas indicates the heater does not have a failure in any of the safety circuits and wants to fire. It is just missing an ignition source or the gas you smell is not making it to the proper place to be ignited. Given these two options it is most often the igniter. Replacing the igniter is not difficult but it is a VERY delicate part and experience in handling it is benificial.
Apr 14, 2014 | Teledyne Laars Laars Lite 2 Pool Heater...
Convert Laars lite model lg125n to LP gas
That involves changing out the complete burner tray including the igniter/pilot assembly, burners and the gas valve. It runs deep into the cost of a new heater, (well over $1000, not installed).
Nov 27, 2013 | Teledyne Laars Laars Lite 2 Pool Heater...
I have a Laars Lite 2 400,000 btu pool heater. It
It could be that the Igniter has gone bad. Or it cold be a number of other items, like the gas valve itself. If the heater has a display panel on it, is there an error code showing? If there is, go to your Owner's Manual and find out what the code is for the heater.
If you do not have a manual, you can find one online at the following link:
http://www.inyopools.com/owners_manual/jandy_heaters_lite2.pdf
Jul 07, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Describe your Jandy Laars Lite2 Pool & Spa Heater - Electronic Dual Ignition - 125,000 BT Problem FL 4 code and have changed igniter and still getting the FL4 code its the lite 2 model...
A. Check fuses on igniter wires. Identify and correct loose connections or broken wires. B. Measure room temperature resistance and ensure value is in the correct range. See manual for details. C. Replace igniter.
Jul 04, 2009 | Jandy Laars Lite2 Pool & Spa Heater -...
LAARS LIT2 Heater Problem
i would not change any part unless it was tested and found to be faulty.for start make sure you 24volts going in and coming out of board.1st things 1st
Jun 15, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Jandy heater not starting
FL 4 is igniter failure.
1. check the fuses on igniter wire as well as the wires.
2. replace igniter
Jun 13, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Laars LJ 175 Hot Surface ignition Problem
sounds like a board problem.has it been working and this a sudden problem or is it a new heater that you are trying to put into operation?
Jul 10, 2008 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Laars lite 2 Spark egnighter will not spark
turn power off first. I would disconnect igniter wire which will be a thick orange wire that comes off of ignition module if it is spark. once you have that the end will look like a spark plug wire take shield away from metal then hold orange wire in hand close but not touching metal turn power on and it will take a couple of minutes before it should start sparking. If you don't see a spark then it is most likely the ignition module. There should be a red light on ignition module that will blink to tell you what the failure is if is is a newer on. When you turn power on to laars light 2 the inducer motor should come on then a pressure switch should send 24volt to gas valve for pilot to lite.Can you smell gas at all when laars should be igniting. If you have any questions fell free to email me back
May 10, 2008 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Pool & Spa Logo
142 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
