Question about Stoves Kitchen Ranges
Where are the fuses located on my inglis ceramic top range
Fuses
aborcass
  • 2651 Answers
SOURCE: How to replace the ceramic range top
you need to replace the glass top itself???that might be an expensive proposition.but heres the how to. theres 2 or3 screws along the front underside of main top. this will release the top enabling you to tip back and look underneath.not a hard job, just gonna take some patients. assuming you have the new top. its gonna be a matter of taking from one and installing on other. you will not have to undo any of the wires leading to the burner elements. instead undo the screws that are holding the elements up to the top . should be 2 brackets running lent gh of unit . undo the brackets and lay the elements down on the insulation . after removing both swap out glass and reinstall new . there will be multiple ***** holes on new glass for supporting brackets. look closely at old one for proper placement
Posted on Mar 12, 2008
  • 1073 Answers
SOURCE: replace ceramic top on gas range
yes the part number that you need to order is 316251903
Posted on Apr 13, 2008
SOURCE: Inglis electric freestanding range model #IRE3230- Oven no longer working
If the oven and the electric panel no longer work, this is an electronic problem. The burners and the oven light will not be effected, nor will the fuses. The electronics card will need to be replaced by an appliance technician.
Posted on Nov 25, 2008
jtbjtb
  • 135 Answers
SOURCE: Ceramic top temperature control
This would be a faulty switch. Hope this helps!
Posted on Mar 09, 2009
  • 718 Answers
SOURCE: location of the fuses
GR448LXPQ
Go to;
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=GR448LXPQ
Click on your model number. Click on the diagrams in the left-hand side for the parts location.
A thermal fuse (9) is shown in the Chassis Diagram. You can check that and other diagrams for more.
Posted on Apr 11, 2009
A burner on my ceramic stove top doesn't work
Without the brand and model number, it is difficult to answer your question. There should be a reference number somewhere in your stove top. That would be your starting point, and from there, seek the needed info using the model number and make. Try a new ceramic burner assembly at that location....it's plug and play.
Jan 08, 2015 | Kitchen Ranges
I have an inglis dryer and it's not heating so it appears from online searching to be a fuse problem, We don't have the manual Can I just assume the fuses are in the back and we can easily replace?
If the fuse goes on this dryer it won't run at all. It is located behind the back panel along with the heating element and the cutoff thermostat(located at the top of the heater housing). I would suspect either the element or cutoff, however its not possible for it to be the thermal fuse.
Jan 13, 2011 | Whirlpool Inglis IP8200 Dryer
I have an electric range with a ceramic top. How do I clean it? There is bubbles on the ceramic too, is this from overheating? How do I get those off?
the main killer of glass cooktops is sugar.it fuses with the top and you cannot get it off. the best way is a razor knife scrape it at a 30 deg. angle. there are some cleaners made for smooth tops as well.good luck!
ERIC
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Jan 23, 2010 | Ovens
Replace ceramic glass top maytag eletric range
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Mar 19, 2009 | Frigidaire FEF366 Electric Kitchen Range
Mar 08, 2009 | Whirlpool GR465LXLS Electric Kitchen Range
Oct 24, 2008 | Kitchen Ranges
Had a power outage and since then my inglis digital stove does not work. all the light's come on but no heat on burners or oven.
my control panel doesn't light up for both ovens and the clock too. The porclain stove top all five panel do work... could i have blown a fuses? in the oven its self .
Apr 15, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Replace ceramic top on gas range
Apr 13, 2008 | Frigidaire FEF366 Electric Kitchen Range
Kitchen Ranges Logo
208 people viewed this question
Top Stoves Kitchen Ranges Experts
Paul Carew
Oloyede Monsuru
Tony Houde
Tony Houde
Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
