Question about Frigidaire ATF6000ES Front Load Washer
How do i change the belt on a fws1233fso model?
Frigidaire top load model fws1233fso
2 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: newer frigidaire top load washer belt replacement
simple to replace, it simply wraps around the motor , over to the transission pulley, and the pension pulley applies "tension", will only go on one way, 2 screws across the bottom of the front panel will gain you access to the area
Posted on Dec 15, 2008
Frigidair top load washer Model fwx233res7 not spinning
If the motor is not running, then it sounds like the lid switch. If the motor is running, the belt could be the problem.
Jan 07, 2010 | Frigidaire GLWS1339AS Top-Load Washer
An old model Frigidaire top-load washer - the old "turn the dial, and pull out to start" type. Drum won't agitate - what, if anything, can I do?
Remove the front panel and inspect the drive belt. It is probably worn out and or stretched.
The Frigidaire style you have does not take overloading very well.
Also check the lid switch for continuity. It must be good for agitation to occur.
Nov 01, 2009 | Frigidaire FWS1339A Top Load Washer
I am trying to find the right dryer belt for FEX831FS1
available through sears but the part number is
134503900
16.00 dollars
Oct 09, 2009 | Frigidaire FEX831CS Top Load Stacked...
How to open the back of Frigidaire FEX831CS to change belt.
Remove the two screws from the bottom of the FRONT panel. The panel drops down and pulls off. You change the belt from the front
Jul 20, 2009 | Frigidaire FEX831CS Top Load Stacked...
BELT LOOSE ON FRIGIDAIRE WASHER HOW TO TIGHTEN
you can't really tighten a belt, I suggest that you change it, although it is extremely hard to replace a a new belt yourself. Have you checked the carbon brushes in the motor do not need changing, this could also generate a burning smell and leave you clothes wet if they are worn.
Nov 15, 2008 | Frigidaire CWS3600AS Top Load Washer
Smoking burning rubber smell from machine
Welcome
You said, frigidaire GLWS1349AS1 TOP LOADING WASHING MACHINE
pls help - is the machine done with- it set the smoke alarms off ???
Sounds like the belt is loose and smelled like rubber burning from spinning fast!
Change belt
Let me know.
Please remember to leave a rating
Oct 06, 2008 | Frigidaire GLWS1339CS Top Load Washer
Agitator will not move
Jac, my suggestion is this. The "reverse" gear in the transmission has locked up. The burning smell is coming from the belt. The motor is trying to spin the belt to turn the tranny but it won't turn  'cause it's locked up this causes the belt to burn.
If it's less than 5 years old, the tranny is under warranty. Contact Frigidaire and give them the full model and serial number and schedule a repair. (ask them to bring a belt with them when they come. you'll need one.)
Oct 11, 2007 | Frigidaire FGX831CS Top Load Stacked...
Frigidaire ATF6000ES Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
