Question about GE Spacemaker JVM1640SJ Microwave Oven
GE SPACEMAKER 2.0 Microwave EXAUST FAN and LIGHT Button not working. I am looking if I can fix this one my own?
  • dandoon Nov 03, 2008
    the exhaust fan is not working any more
5 Suggested Answers
fridgetech
  • 473 Answers
SOURCE: GE PRofile Spacemaker XL Microwave Oven Model# JVM1460 950 watts
Sounds like the problem is in the high voltage. Most common would be magnatron, capacitor and diode. For safety reasons this should be checked by a professional. Look in your owners manual because some high voltage parts have a longer warranty than 1 yr.
Posted on Oct 10, 2007
  • 4 Answers
SOURCE: Removal of GE Spacemaker Microwave oven
1. Unplug the microwave. The plug is probably in a receptacle that is in the cabinet above the microwave, or in the wall above the shelf that is above the microwave.
2. Remove the two (or three) screws that go straight down through the bottom of the cabinet, or the shelf, into the top of the microwave. Have help in holding the microwave when you do this, as the front of the microwave will be able to fall down when the screws are removed.
3. Allow the front of the microwave to rotate down a little, then lift the back of the unit up about 1/2" to 1". At this point, the microwave will be disconnected from the mounting plate on the wall, so you can move it forward and carry it away.
Posted on Nov 29, 2007
  • 95 Answers
SOURCE: ge spacemaker microwave jvm/1650
Mmmm it's so easy,
First disconect the power, take the cover off, moslitly there would be 5 screws and two tab's on the top.
inside on the right hand side the magnetron it's a sylver box measuring about 4 in x 4 in x 5 in. It will have a plasic cover moslitly that would have to be remove first then on the magnetron there is 4 crews and one connector.
It should fall downard after.
If you have a power supply after the secondary , that may also be your problem.
Regards
Bob
Posted on Jan 22, 2008
MicrowaveSvc
  • 8968 Answers
SOURCE: GE Profile Spacemaker 2.0 Microwave
If it goes dead or blows the breaker or GFI when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. Other times, it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 19, 2008
MicrowaveSvc
  • 8968 Answers
SOURCE: Replacement light bulb for GE spacemaker microwave
That model number doesn't look quite right, but nevertheless:
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Sep 16, 2008
The exhaust fan works, the light below the microwave that shines on the stove top works. It appears to be functioning properly except that it won't heat up food. The GE Spacemaker Model JVM131001 is...
I'm all for fixing appliances but in your case I would suggest replacement. After 24 years of service the magnetron is probably only putting out half of its rated wattage. It could also be one of the reasons of the no heat condition.
Jun 19, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Ge spacemaker microwave when i plug it in comes up with PF on the screen and does not work at all,it has power and the light inside is on,i can press the 3 minute button and the microwave will wor but that...
ther should be instrustions manual sound like mocro is working suspect control panel it needs 2 be reset how read manul panosonic push stop 1 at same time menu comes up push reset this is a minor problem hopes this help u
Jul 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE PROFILE SPACEMAKER P/NO 8114-334-730 MICROWAVE TOTALLY DEAD!
Sorry Seanna, but I have been getting a lot of problems with GE microwaves. You can call customer care at 800-432-2737, but out-of-warranty repairs are very expensive. Sounds like your problem may be door latch circuitry which requires service. If your unit is old, consider replacing it as prices are very reasonable.
Ray
Dec 15, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE spacemaker microwave model #JVM1650SH
Allways unplug when your working inside a microwave, you will most likely have to replace the bulb again and also the fan, or anything else that is damaged, you will need to inspect the microwave for broken parts.
Il get you a few links to repair parts.
Sep 27, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Slow heating; sluggish fan; low interior light
The main power supply may have a fault. Also, the HV supply may be weak at the same time.
Jerry G.
Apr 01, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Ge Spacemaker XL 1800
SOME BUT NOT ALL OVENS HAVE RELAYS TO TURN THINGS ON AND OFF CHECK THE OVEN TO SEE IF YOU HAVE ANY
RELAYS AND SEE WHAT THEY DO.
Jan 06, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave wont come on at all.
replace the fuse. You have to remove the top grill and then you will find it above the display
Dec 24, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Oct 09, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker Microwave with vent fan
hi possible magnetron problem but also check highvoltage capacitor and diode . the process of ellumination is the only way to help u .first disconnect connegtor to magnetron and switch oven on if noise goes away eureka repeat with other components
Mar 18, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
235 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
D. E. Hev
 Larry
Larry
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
