Question about Hotpoint First Edition WMA22 Front Load Washer
Fills when not being used
Leave the machine after it has been used. door open. water starts filling drum and overflows. why?
    Master:
  • 431 Answers
Where the water pipes plugs into machine it has a water stop valve there. turn water off at mains and unscrew pipe. it may have a blockage of some sort keepng the valve open. hope this helps
Posted on Feb 14, 2012
  • 1294 Answers
SOURCE: Drum keeps filling with water even in dryer mode
Open up the top of the machine. Plug off the wall mains. Turn off the wall faucet. How is the wire connection for the inlet valve, the water inlet. Fine? If not unscrew the inlet valve from the corner of the machine after disconnecting the hoses, & dismantle to clean it up, re-assemble, refit back to machine.
Posted on Apr 04, 2009
ginko
  • 19396 Answers
SOURCE: WF860 drum filling with water
Normally I would think that the problem is with the drain system (faulty pump or clogged lines), but you told me that also "When the washing machine is not bein.g used the drum slowly starts to fill with water!!" therefor I think it can be a dafective inlet valve or a faulty control assembly.
In either case, you will need a technician to fix this.
Posted on Dec 23, 2008
  • 4 Answers
SOURCE: wd71 error 34
get a washboard and a jug
Posted on Feb 14, 2008
  • 82 Answers
SOURCE: machin fills with water,washes and then fills again
hotpoint wma turn off the power and you are looking for the presure w
switch and chamber , the switch is at the back of the soap draw by the valves on the left hand side there should be a hose going into it take it off and blow through it if nothing happens pull the machine out and at the bottom of the back there is a white plastic cover take it off look for the sump hose and on the side of it there is a whit plastic tube this is the presure chamber clean it out might be blocked
Posted on Jun 27, 2009
barkencoa
  • 3463 Answers
SOURCE: fills water goes through program drum dose not
Remove the motor, and check the brushes in the motor, if o/k, then could be a board prob, or something as simple as a broken or bad connection.
Pleasre rate my solution.
Thanks.
Posted on Oct 10, 2009
IT KEEPS FILLING UP WITH WATER AND OVERFLOWS
There is a tube next to the drum that senses the water level, take the screws out of the back of the machine near the top and then you can lift the top off over the drum, look for the tube and see if it is plugged with lint dirt or softener. Clean it out. If that is not the problem then check the sensor that it plugs into to be sure it is not bad
Jul 03, 2016 | Washing Machines
What could be causing my washer to fill with water when off and not in use?
Either you have a short somewhere or a ghost messing with you. I'd call the repair man before the priest.
Jan 06, 2014 | KitchenAid KHWS01PMT Front Load Washer
WHEN MACHINE IS OFF DOOR IS OPEN TO AIROUT
TWO LIKLY REASONS FOR THIS
1ST IS YOUR APPLIANCE CONNECTED INTO TRAP UNDER SINK IF SO MAKESHORE ITS NOT YOUR WASTE RUNNING BACK TO MACHINE
2ND INLET VALVE IS LEAKING-TO SOLVE THAT A NEW VALVE IS NEEDED
Nov 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Random filling of the tub, door open, leaks on floor.
The only thing that can admit water with the power off to the machine is a bad Fill valve. Replace
Aug 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Even when not programmed to the washer/dryer fills up with water?
Check the water inlet valves, located where the water lines plug into the machine. Also check for proper water pressure and make sure that your water pressure is not surging. If this help please rate. Thank you
Feb 12, 2009 | Hotpoint First Edition FEW12 Front Load...
Washer Dryer - drum is filled with water even when switched off and door can still open!
Try the valves inside the back where the water hoses connect to the machine they should default to the closed position when water is not required
Oct 31, 2008 | De Dietrich LZ9619 Front Load Washer /...
Kenmore HE2 #1104751. Overflows as it is just beginning to fill with water
ck inlet just inside door upper left could be blockage in line from dispenser into tub especially if you have been using dry detergent remove detergent drawer and ck for blockage from that end too
Oct 09, 2008 | Kenmore Elite 45986 Front Load Washer
Washer filled up with water when not turned on
It sounds like the water inlet valve assembly is letting a trickle of water thru when its not supposed to. It is located on the rear of the washer, it is the part the water hoses connect to. Make sure the power and water are turned off, then disconnect the water fill hoses. The valve is attached to a bracket, the valve will have 4 electrical selenoids on it and a hose leading further into the machine. Make a drawing of where the wires/colors were attached before you pull them off. The valve for that machine (MLG2000AWW or MLG2000AXW) usually costs about $45.00 to $55.00
Jan 19, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
Drum filling with water when machine switched off
what you refer to as the overflow cap is the cover to the filter which you should remove regularly and check. however nothing to do with your problem. the water could be coming from two sources: first, if the drain is plumbed in under the sink, water can flow into the machine every time you empty the sink. the cure is to put the drain hose up as far as possible in a swan neck. secondly, the intake water valves could be leaking and the only cure then is to replace them
May 04, 2007 | Zanussi IZ12 Front Load Washer
Hotpoint First Edition WMA22 Front Load Washer Logo
123 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
