Question about Zebra Z4Mplus Label Printer
Zebra zm400 won't print - Zebra Z4Mplus Label Printer
  • 7 Answers
SOURCE: zebra zm400
check the size of the document and the Zebra Fonts;
Install Zebra font if not install and its resolv
Posted on Oct 06, 2009
ashish13
  • 75 Answers
SOURCE: Some noise comes when printing
Here is the link for the Service Manual required which i uploaded for you... hope this resolves your issue...
http://www.adrive.com/home/downloadfile/136030403
Posted on Feb 12, 2009
prashanthcl
  • 460 Answers
SOURCE: zebra printer Zm400 - error condition
pls clean your printer sensors.
Posted on Aug 21, 2009
  • 31 Answers
SOURCE: I am having problems with Zebra printer MDL#ZM400
I agree with Dustproof's suggestion regarding setting defaults. After you do that, you will need to set up your firmware and driver for the correct density, speed, media handling (tear-off vs. peel - labels with gaps or black marks) , etc. If your driver does not relfect the same settings that you have saved in the printer's firmware, the driver will send commands to the printer that will change its settings. Lastly, you will need to calibrate the printer to the media that you are using. An easy way to do this on the ZM400 is to set the power on setting in the LCD menu to calibrate and the head close setting to feed, save these settings in memory and then reboot the printer. This way, you will only need to reboot your printer to calibrate when there is a problem or if you change media types. The feed setting on head close will make sure that your label advances to the the next gap or mark if you open the printhead.
If all ese fails, call Zebra tech support (800) 423 0422 and open up a support case. It is possible that the media sensor or media led is not working properly requiring that your printer be sent in for repair.
Posted on Jan 30, 2010
  • 35 Answers
SOURCE: zebra zm400 turn printed info 180 degrees
Yu can rotate the print orientation in the Z Designer printer driver, in the OPTIONS tag tick the 180Deg box
Posted on Feb 16, 2010
LA IMPRESORA ZEBRA ZM400 CUANDO SE ENCIENDE APARECE EN LA PANTALLA LCD, EL MENSAJE HEAT OPEN, COMO QUITARLO?
there is a possibility that you need to just the print head assembly, if when its at close position, the print head is far from the sensor.
With the print head is open, you will see 3 screw on the left, louse them and adjust all the print head mechanism, up and down some milliliters tie the screws again, close the printhead , try again and see if errors desapeer
Jul 24, 2014 | Zebra ZM400 Thermal Label Printer -...
How to fix dissapear printing label for Zebra ZM400
Hi, please be more especific regarding issue, can be software issue or hardware issue.
Jun 20, 2014 | Zebra ZM400 Thermal Label Printer -...
Zebra zm400 does not want to print from file
Hy, what file? thanks. try driver from www.seagulscientific.com.
Jun 03, 2014 | Zebra ZM400 Thermal Label Printer -...
For ZM400 and S4M, Has anyone had any luck with printing a white ribbon and a black or dark label without covering up the ribbon sensor with electrical tape? Isn't there a setting that can be...
You can try this: on the S4M, you can press the Menu key to go into setup mode. Under password level 3 parameters,there is a setting for ribbon which by default is set to Yes thermal trans. If you set it to No for direct thermal mode, this will in effect turn off the ribbon sensor. The printer won't stop now if it runs out of ribbon but usually you are there when printing to see that the ribbon is running out.
On other Zebras, you can turn down the sensitivity of the RIBBON LED sensor but the S4M doesn't have that setting.
See if that helps.
Jun 20, 2011 | Zebra 203DPI Printer
I cannot print from my mac to a ZM400 Zebra printer
That is correct, you can try VM Windows. I would get a cheap laptop instead, as it is easier. Hope this helps!
Apr 27, 2011 | Zebra ZM400 Direct Thermal-Thermal...
Have A Zebra Z6M Plus 300dpi printer Z6M00-2006-0000, then purchased a Zebra ZM400 300dpi printer, attempting to print using formats from Z6Mplus, result is a print approx 150 % larger ??? Downloaded...
Print configuration from both printers and compare. Print config- Hold cancel button 10 sec. while power on. Check Resolution parameter. 203dpi=8MM Full , 300dpi=12MM Full. Sounds like perhaps they are different dpi.
Apr 03, 2011 | Zebra ZM400 Thermal Label Printer -...
Zm400 print a part of a label. Hello, my Zebra ZM400 only print 1/5 last part ot the barcode label. Could you please tell me how to fix it?
What part, rigth site or bottom site?
check the lengt and the with from the driver and print the testpage (have to print on full label)
if is one of the sides, try to give more pressure to that side on the printhead.
Nov 17, 2010 | Zebra 203DPI Printer
Printing and counting problem with Zebra ZM400. We have connected a Zebra ZM400 to our network and we now have a problem with printing. When we print he prints the labels 1 by 1 instead of de total...
if you sending a file (ex. pdf or picture). to the printer, can do this, if you send the proper format with normal fonts (caracteres))to the printer, work fine. build new label from zebradesigner
May 20, 2010 | Zebra Z4Mplus Label Printer
Zebra zm400 turn printed info 180 degrees
Dec 17, 2009 | Zebra 300DPI CUTTER [zm400-3001-1000t]...
How to load new labels
http://www.scanonline.com/Online-Store/ZM400-600
Download the ZM400/600 Quick Reference Guide on the right hand side of the page. They have a diagram on how to load labels.
There should also be one inside the printer - printed on the back wall...
Jul 10, 2009 | Zebra ZM400 Direct Thermal-Thermal...
Zebra Z4Mplus Label Printer Logo
435 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
