Question about Hitachi Drills
Remove drill bit from 18 volt drill
I can't remove the drill bit from the chuck
    Genius:
  • 1,212 Answers
Put the dril in forward, hold the collar, and just bump the switch long enough to get the internal portion to turn. The bit will likely fall out at that point.
Keyless chucks are make in a way that each of the jaws have an exposed heel that can grab onto larger bits that were inserted too far into the chuck.
Posted on Feb 18, 2012
  • 1019 Answers
SOURCE: chuck will not release bit
the Chuck should be 2 Part.
Use 2 pair of stillsons Or pipe wrenches, Tight On the 2 Chuck Parts, Crack in opposite Directions.
Alternative, Use Wrench On Chuck Jaw, Short sharp Blow With Hammer.
Mike @ compurepair.
Posted on Feb 28, 2008
SOURCE: bosch 18volt brute force cordless drill how do i remove chuck
Put the screw back in the chuck, tighten it up then back it out 1 turn. Take a punch, put it in the chuck and give it a quick hit with a hammer. That should do the trick.
Posted on Jan 31, 2009
  • 10865 Answers
SOURCE: dewalt 18 volt cordless drill
Use a pipe wrench on it to give yourself a little more leverage. It is simply jammed all the way open and it will release when you apply enough force.
Posted on Apr 30, 2009
  • 12 Answers
SOURCE: Dewalt Drill DC728. Chuck came out of drill body
If you find that the end of the screw inside the chuck is actually broke then you have a gear problem inside your drill. This is actually a very common problem. Sometimes people push too hard on their drills and the gears inside wear out and break. This prevent the motor from wearing out, but, the gears have to be replaced.
If it is the gears and not the chuck. you broke the minimium of the front gear or gears inside your drill. YOU CANNNOT repair gears. they need to be replaced. you may be able to find some off brand gears to work but, you run the risk that they are not as strong as your original ones, or may not be exactly grooved correctly.
so, if replacing your chuck does not work. find replacement gears. IF you cannot find the gears from the manufacturer see about replacing your drill.
If the chuck is still good, keep it. If you buy the same model, keep your old drill for replacement parts, ie, switch, armature, cord, etc.
hope this helps somewhat.
Posted on Jun 11, 2009
rowdy45176
  • 2176 Answers
SOURCE: remove keyless chuck on a 12 volt makita drill
go to the tip section or under my name and there are instructions on how to remove and reinstall the chuck. let me know if you need more assistance.
Posted on Jan 23, 2010
Drill bit falls out , cannot use reverse to extract srews or bolts
are you installing the bit correctly. is the chuck defective... is the a name for the product. does it have a keyless chuck... are you inept ???
Oct 24, 2013 | Dewalt 18 Volt Compact Drill Kit
Chuck won't hold bit when making drilling a hold or trying to reverse a screw, etc.
it sounds like you will need to replace the chuck on the drill. a worn chuck or a cheep brand may be your trouble.buy a good Jacob chuck and this will most likely fix your problem
Jun 20, 2013 | Dewalt 18 Volt Compact Drill Kit
I can't release the bit from the chuck.
If it is jammed then hold the bit in a vice and try to knock the chuck off with a cold chisel or suitable piece of brass. then you can remove the chuck screw and replace the chuck. You should not be able to see the bearings underneath.
Jan 27, 2013 | Black & Decker 18 Volt Cordless Drill...
Ryobi 18v drill keyless chuck stuck
Try holding the bit in a vice and gently tap the chuck off of the bit and see it it releases the pressure on the jaws.
Jun 20, 2012 | Ryobi 18v Cordless Drill - P206 18 Volt V
New Black and Decker, 18 volt, cordless drill. I can't tighen the bit
I oil mine up to help the jaws move . also check the screw at the base of the chuck inside its a standard head. shine flash lite where you put the bit it holders the Jacobs chuck to the shaft.
Jul 07, 2011 | Black & Decker & Cordless Drill
I have a DEWALT DC920 drill-driver and have a bit stuck in the chuck. The chuck adjuster appears to be stripped. Need to remove the bit and replace the chuck. Any ideas on how to get the bit released?
try tapping on all sides of the chuck lightly with a hammer and wiggling the bit... you can also try to spray some oil into the chuck and see if that loosens the bit for you... You can also clamp the bit in a vise (or get someone with a pair of pliers) and pull, that will sometimes do the trick.
Apr 04, 2011 | Dewalt 18 Volt Compact Drill Kit
My 18 volt dewalt cordless runs well except when I try to remove something with it. Reversing the drill makes my nutdriver bit fall out as it opens the chuck, so all removals have to be done by hand.
I would make sure that the bit is firmly installed in the chuck, you should hear clicking when the bit is tightening, this is the chuck locking itself on the but. and when going in reverse make sure you dont have your hand or have the chuck pressed against an object. If nether of these are the problem then there may be a problem with the chuck itself and should be replaced.
Apr 02, 2011 | Dewalt 18 Volt Compact Drill Kit
Chuck will not hold bits, How to change chuck
down inside the chuck theres a big flat head screw that should do it.
Nov 17, 2010 | Hitachi DS18DVF3 18 volt Cordless Drill...
I have an 18 volt hammer drill combo drill. I
Do the same in reverse, if possible. Also, you could use two channel locks as most of those chucks have two rings, the narrow one towards the drill itself being attached to the motor. However, make sure the screw inside the chuck is tight first -- I've seen those back out and block chucks open.
Mar 06, 2010 | Dewalt 18 Volt Compact Drill Kit
Removing the chuck on a dewalt DC925 cordless drill.
I just changed the chuck on my 18 volt xrp half inch hammer drill,yes first you must remove the torx screw with #15 torx bit,note this is a left handed thread screw,knowing the bad chuck was bad I added some heat from a propane torch to the chuck then making sure it was in 1st gear i took some vise grips and the chuck is screwed on with normal right handed threads,it broke loose (was stubborn but needs a lot of torque )ahhhhhh wat a pain.
Oct 18, 2008 | Dewalt 18 Volt Compact Drill Kit
Drills Logo
214 people viewed this question
Top Hitachi Drills Experts
John Trevino
Are you a Hitachi Drill Expert? Answer questions, earn points and help others
