Question about Philips Audio Players & Recorders
Philips sbc md110
I have a philips sbc md110 and it's fully functional (i tried it with other devices and it works just fine) and when i plug it into my imac 27'' 2010 line- in and select line input, i don't get any sound does anyone know if you need to download a driver or a use preamp?
robotek
  • 1512 Answers
SOURCE: No sound through M-Audio preamp and condenser mic
Hi micoach
The condenser mic you are using requires phantom power for it to operate. Pay to check that that is turned on m-audio. Just to be sure.you say you can get sound off the m-audio headphone socket. Just need to check that. You will need to check that you have selected the device for recording from the preferences--audio I/O options menu within audacity. Perhaps check these things and get back to me here if you still have problems.I can go into more detail with you.
regards
robotek
Posted on Jul 04, 2008
SOURCE: No sound
I removed the cover on the back (the access to musicartridges) I also removed wireless receiver unit (approx 2" black plastic piece) pull straight up to remove. after removing the receiver you'll see two screws, remove them, unscrew the mic head, pry the body apart (fingernails). You will see two circuit boards, the smaller one became disconnected. The board should reconnect easily, the outlet looks almost like the wireless receiver outlet you removed earlier. if it does not slide in easily DON"T force it, you may be trying to install into receiver outlet ( They look the same), The correct outlet is above (towards mic head) the four outlets to the music cartridges. CAREFUL NOT TO BEND PINS same with the wireless receiver.
Posted on Oct 15, 2008
  • 149 Answers
SOURCE: Hello I bought a microphone Philips SBC MD 110,but
Hi, There is never any driver needed when connecting a microphone to your pc or laptop.
Simply connect the 3.5mm jack to the microphone input on the soundcard of your pc.
Check the settings in the volume control settings at:"Playback" when using the microphone during a live presentation etc."Recording" when making a sound recording or using VOIP like Skype, MSN etc.
Note: this may vary depending on your operating system..
hope it helps..
Posted on Feb 23, 2011
  • 65 Answers
SOURCE: Hello There, I just bought
It sounds like you have done everything right. It would be a good idea to check both the mic and Protools system separately. If you can, verify that the mic works using another device such as a mixer. Also try getting a level into Protools using another mic, preferably a dynamic which doesn't require phantom power. If you are trying to use an original MBOX under Windows 7 or the latest version of OSX then it may not work at all.
Posted on Sep 26, 2011
ercupa190
  • 12223 Answers
SOURCE: philips sbc md110 not working
Dear Sir:
Sometimes the remotes control, need to be reload.
Is a good idea to go to the web from Philips http://www.philips.com/c/catalog/catalog_selector.jsp and give your model, etc, and download the exactly code for your model imac. If you have some additional trouble you can get assistance from them. So they made the remote, and the RAM, has special design, and by that reason they can fix it, with better security.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua
Posted on Feb 15, 2012
My philips gogear vibe wont turn on
Reset your GoGear with something sharp like the tip of a pen or the end of a paper clip,
if you're device isn't working properly or there's a frozen display.
Insert the sharp object into the "Reset" hole (located at the bottom of the player), and hold it there until the device turns off.
If resetting the device does nothing to restore the display, access the "Philips Device Manager" through your computer to recover the GoGear.
Click "Start" on your computer, then "Programs," "Philips Digital Audio Player," "Aria Device Manager," and then "Philips Device Manager."
This will launch the "Philips Device Manager." Make sure the GoGear is turned off completely. Connect your GoGear to your computer while holding down the "Volume Up" button.
Continue to hold the "Volume Up" button on your GoGear, until the "Philips Device Manager" recognizes the device and enters recovery mode.
Click the "Repair" button when it appears on your computer, then folow the steps to fully recover the GoGear.
Properly disconnect your GoGear from your computer and restart the device.
Recharge your device if your GoGear dies suddenly while playing.
Connect the GoGear to your computer via the supplied USB cord.
Plug one end of the USB cord into a functional, open USB port on your computer. Plug the free, smaller end of the USB cord firmly into the small USB jack on your GoGear and turn your computer on.
This will begin the charging process of your GoGear.
If recharging doesn't work, the battery may need to be replaced.
Check that your GoGear isn't in standby mode. Hold the "Power" button for two seconds to turn it back on.
hope this helps
Oct 07, 2012 | Philips GoGear ViBE SA1VBE08K MP3 Player
Philips rechargeable batteries SBC HB550S
Thank you. I have just removed the end label of my Energiser rechargeable batteries & inserted into my Phillips Headphones & they are working just fine.
Jun 08, 2012 | Philips (33-01-031) Headphones
My volume button broke
1 Reset your GoGear with something sharp like the tip of a pen or the end of a paper clip, if you're device isn't working properly or there's a frozen display. Insert the sharp object into the "Reset" hole (located at the bottom of the player), and hold it there until the device turns off. If resetting the device does nothing to restore the display, access the "Philips Device Manager" through your computer to recover the GoGear.
2 Click "Start" on your computer, then "Programs," "Philips Digital Audio Player," "Aria Device Manager," and then "Philips Device Manager." This will launch the "Philips Device Manager." Make sure the GoGear is turned off completely. Connect your GoGear to your computer while holding down the "Volume Up" button. Continue to hold the "Volume Up" button on your GoGear, until the "Philips Device Manager" recognizes the device and enters recovery mode. Click the "Repair" button when it appears on your computer, then follow the steps to fully recover the GoGear. Properly disconnect your GoGear from your computer and restart the device.
3 Recharge your device if your GoGear dies suddenly while playing. Connect the GoGear to your computer via the supplied USB cord. Plug one end of the USB cord into a functional, open USB port on your computer. Plug the free, smaller end of the USB cord firmly into the small USB jack on your GoGear and turn your computer on. This will begin the charging process of your GoGear. If recharging doesn't work, the battery may need to be replaced. Check that your GoGear isn't in standby mode. Hold the "Power" button for two seconds to turn it back on.
Apr 17, 2012 | Philips GoGear ViBE Digital Media Player
Philips sbc md110 not working
Dear Sir:
ernesto cuadra
managua, nicaragua
Feb 14, 2012 | Philips Televison & Video
My phillips gogear vibe is about 6/7 months old. it was working fine on friday, was fully charged on thursday. went to use it today and it won't even turn on. i plugged it into the laptop and it's...
Hi winnie_th132,
You can find FAQ's, manuals, and software at the Philips Support Site:
www.philips.com/support
Just enter your model number in the search.
Here is the Overview page for the SA1VBE: http://ow.ly/5RIUN
I would recommend performing a Repair/Recovery which restores your player to factory settings, as well as updates the firmware. Below are instructions for performing a Repair.
If you have any additional questions or wish to speak to a Consumer Care agent, call 1-888-744-5477.
Hope this helps. If so, let me know by rating this solution!
REPAIR INSTRUCTIONS:
Use a pen tip or other sharp object to insert the RESET hole gently on the side of the player and connect it again to your PC.
If it is still not recognized, your player may be at fault. Try the Philips Device Manager software.
NOTE: Contents will be removed by using the repair function.
  1. Install the Philips Device Manager and run it with your player connected to your PC. You can download it under the Software & drivers section.
  2. Click the Repair tab in the Device Manager, press and hold the corresponding recovery key on the player when connecting it to your PC.
  3. Follow the PC screen to recover your player.
You can find the recovery key on your player from the below table.
Jul 31, 2011 | Audio Players & Recorders
Hello I bought a microphone Philips SBC MD 110,but I don't know to use it on my pc. Its recognized like a device but dthere is no sound.I have windowsm vista OS,please can someone tell me how can i conecct...
hope it helps..
Feb 23, 2011 | Philips Audio Players & Recorders
Hi guys, i bought a philips SBC MD110 mic for my computer. im wondering how do i get it to work? is there any software around? i went into control panel and when i plug it in, it recognises the device,...
Here is some information. Hope this helps:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=SBCMD110%2F01&dct=FAQ&faqview=1&new_tmpl=1&refdisplay=HEADPHONES_QAC_71953&refnr=0071953&scy=ZA&slg=ENG
Feb 09, 2011 | Computers & Internet
Help with mp3
If it doesn't work when unplugged and fully charged, that problem is not going to go away. You can do the Repair in Philips Device Manager, but it will erase all of your songs and it probably will not work. The problem is, Philips is all out of these players, and they no longer make any 30GB models - 8GB is the max.
Jun 26, 2008 | Philips GoGear HDD6330 MP3 Player
109 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
