Question about Samsung Washing Machines
I have samsung waching machine j1453s every time i turn it on it gives 2 H then me LE and beeb beeb and i cannot start it ,, i tried many times but it gives the same result note that the two letters L E the L is not seems like E without the top row of the letter ,, sorry i couldn`t find that letter on the key board ,, please help me to know
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 139 Answers
Do you still have your Samsung manual? If not I would recommend you down load it from the Samsung website -just to have on hand for further problems. I can honestly say that I don't remember what the code stands for but it could be a plugged filter which is a big problem with Samsung. Should be drained every 3 months
Posted on Feb 14, 2012
2 Suggested Answers
  • 56 Answers
SOURCE: i keep gettine the letters LE come up and my
if this is a LG washing machine code LE is motor fault call engineer
Posted on Feb 11, 2010
Samsung j1453s has blockage between the drum and the filter (coin)
it's simply a case of removing the pipe. Not a simple job unless you can access the clip on the hose at the drum
Mar 03, 2014 | Samsung Washing Machines
LE LIGHT IS APPEAR
Over-sudsing is the main cause of LE error codes. Using non-HE (high efficiency) detergents or too much detergent will cause stress on the motor. In addition, detergent residue can also cause leaking and odor. Follow these steps to resolved an LE error code caused by over-sudsing.
Step 1: Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Step 2: Plug the washer back in and press [Power] to turn on the washer.
Step 3: Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Step 4: Press [Start/Pause] to begin a drain only cycle.
Step 5: After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause]. This will remove excess soap suds and light residue from the drum. Repeat this step until no visible suds are in the drum of the washer.
Nov 12, 2012 | Washing Machines
LE LIGHTY IS PRESENT
My samsung washing machine J1453S is having a problem with spinning, no problem with loading water, drive belt is fine.
Hi donna sarmie,
It could be your machine is stuck on the drain cycle, and won't continue to spin, because the drain filter is clogged.
You may need to clean the Drain Filter, please find my Tip below on the procedure:
ACCESSING, DRAINING & CLEANING THE DRAIN PUMP FILTER...
Kind Regards :-)
JEDEMEYER1
* If this solution helped you, please rate it
Aug 01, 2011 | Samsung Washing Machines
I've got an LE code on the front of my washer
This error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
Are there soap suds visible in the drum?
Hope this helps.
Jul 06, 2011 | LG WM2301HW Front Load Washer
My washer is saying LE, what does LE mean? It stopped washing!
Is this a new installation?
In new installations, this error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Hope this helps.
Jun 29, 2011 | LG Washing Machines
Washer has a LE (or EE) code or something like that. First character looks like an E missing the top bar, or an L with an extra bar in the middle. i was doing a load of towels when this happened. i assumed...
Washing machine has an LE error code
Is this a new installation? In new installations, this error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Hope this helps.
Jun 09, 2011 | LG Washing Machines
LG TROMM Direct Drive WM0642HW when filled and started LE light comes on and machine stops, why. how do I reste or fix
LE is for a overload error. Do the following:
1) Unplug machine
2) Drain machine
3) Open machine and rotate barrel clockwise 4 times and counter-clockwise 4 times
4) Plug in, power on, and run regular cycle
Feb 27, 2011 | LG Washing Machines
What does LE mean?
Nov 28, 2010 | LG WM-2277HW Front Load Washer
My washing machine is cannot spin ,it show error code LE
Nov 28, 2010 | Washing Machines
Washing Machines Logo
103 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
