Question about Master Heaters Air Tools & Compressors
How do I connect a badger airbrush hose to a Airbrush Depot TC20T compressor?
I have a Badger airbrush hose and I want to connect it to a Airbrush Depot brand TC20T compressor. what type of adapter do I need?? Thanks
    Genius:
  • 1,212 Answers
Airbrush Depot compressor should be a 1.4NPT which is the most common- Badger makes an adapter for this size to their hose fitting. That fitting should be available from many sources. Badger did/does use a couple of sizes so make sure you know which model of brush you have.
http://badgerairbrush.com/Acessories_4.asp is the piece.it is at the bottom of the page.
If nothing else, it should be available through Walthers http://www.walthers.com
Posted on Feb 15, 2012
  • 103 Answers
SOURCE: how do you regulate the air pressure on FUWA AIRBRUSH COMPRESSOR
There is usually a regulator where the air coupling is. if not,just add one with some simple fittings and a regulator you can find at home depot in tool dept.
Posted on Jul 16, 2009
  • 5603 Answers
SOURCE: bubbles in color cup of airbrush
I assume you have adjusted the nozzle... On my unit, there is a SMALL hole in the cap for the cups to let in air above the paint. Also OFTEN the paint must be thinned to use in an airbrush. Since you havent been able to draw water even, thinning is NOT the problem.
The airbrush aspirates the paint by Bernouli's principle, that is where there is higher velocity of a fluid, there is a lower pressure. The nozzle creates that and the adjustment is important. On mine which is a "Wren", I think by Binks there is a conical piece that the paint comes out of with a throttling needle. This has the be unscrewed to open the paint path and adjust it. The air flows at high speed around this cone creating a vacuum.
The headline says "Eclipse" but that is a gravity feed so I suspect that is the old Fixya problem of having incomplete choices to pick from.
Posted on Feb 18, 2010
  • 885 Answers
SOURCE: moisture is coming through my
When you compress air the moisture in the air condenses and pools in the tank, all compressors do this whether new or old. If there is water built up in your the tank it will come out when you release the air. There is a valve on the bottom of the tank you have to open from time to time to drain this water from the tank. Take the compressor outside if possible or have something under the valve to catch the water as it comes out. Open the valve slowly or it will blow the dirty/rusty water all over. Campbell Hausfeld and some other companies make filter/driers to put on your supply line if the air needs to be dry for your use. Most box stores (Home Dept, Lowe's, etc.) carry these driers or can order them for you.
Posted on Nov 01, 2010
Zim1308
  • 543 Answers
SOURCE: i am using an iwata
Air brushes us a Theory called a "venturi" in where air pressure lowers the pressure where the paint is kept and causes it to go out the nozzle. I would try seeing if there is an obstruction in the hoses to the brush and confirm that the compressor is moving air. If none of these things are an issue also while cleaning the parts may give the appearance that the item is clean then try soaking them over night in paint thinner and replacing the O-rings and gaskets.
Posted on Apr 27, 2011
  • 27 Answers
SOURCE: water coming out airbush from hose
To get most to all water and vapor out of your line when painting is actually easy. First you need an inline water separator, and an extra 20 feet of air hose. Run the air hose off the compressor and coil it up. Put it in a bucket of icewater. Put the water trap or inline separator on after the bucket and run hose from that to your paint gun. Put a small disposable water absorber on before the paint gun too. I painted many cars like this and had horrible water problems before I did this. Now there is basically no water getting past the seperstor. Just remember to drain separator often and draining the compressor tank before you paint is good practice also.
Posted on Sep 18, 2011
How to turn up the psi
off the memory - on this particular model you have knob just before the valve and indicator, lift it up and turn clockwise to increase pressure and anticlockwise to decrease it.
Apr 04, 2014 | Airbrush-Depot Master Airbrush Model G23...
Won't spray
There are a lot of variables while airbrushing. If you are having trouble with a new airbrush(or one that isn't hugely gunked up) you likely need to do 1 or both of the following to get it to spray the paint:
1) Thin your paint, use the correct medium based on the paint type. Water can be used to thin water-based paints but too much will result in a bad coat and finish. You are looking for a milk-slightly thicker than milker consistency.
2) Crank up the air through the airbrush. Assuming you have a regulator you may need to turn the pressure up to get thicker paints to spray. If you are using a siphon feed you may need a couple extra PSI to recoup for what you are losing from the syphon. Make sure to check the max pressure your airbrush can handle before cranking it too high(most can handle at least 30 PSI).
Hope this helps.
Jan 23, 2013 | Airbrush-Depot Master Airbrush Model G23...
CANT GET PLUNGER ORING BACK INTO MY G22
Hi!
Here's a very detailed guide for this airbrush. I'm sure you'll find your answer:
https://sites.google.com/site/donsairbrushtips/master-g22
Jan 06, 2013 | Airbrush-Depot Master Airbursh G22 .3mm...
Cant get plunger o ringback into my master g22
Please take a look at this guide, it is detailed:
My daughter bought a master airbrush spray tanning system - g70 - with no instruction manual. air is coming out but no tanning solution - any assistance would be greatly appreciated
I got the exact same kit as a Christmas gift (I am a cake decorator). I have asked the supplier how to fix this problem, but they only told me to google airbrush videos. I'm not sure how to connect all the hoses to the compressor and the external paint cup. Been struggling for weeks to find info online. I also have a G34 and that works fine (but it only holds a miniscule amount of paint). Good luck, hope you manage to get an answer.
Jan 16, 2011 | Master Heaters Master Airbrush Model G75...
I cant decide between two airbrushes i am thinking on ordering.I want a large cup gravity feed and right now am debating between the Badger 100LG and the Paasche Talon.Any comments would be great
I am not familiar with either brush, but they are both well known name brands. The Paasche will probably have more readily available parts for it than the Badger in case something breaks or you drop it. I myself use Iwata, BUT the parts are expensive.
It will boil down to which brush comes with what size tip/needle in accordance to what type of media you will be shooting. Thicker paints or stains will require a bigger tip and needle, thinner paints and stains, just the opposite. I hope this helps.
Feb 21, 2010 | Paasche Talon Gravity Feed Airbrush Set
Total Novice
I suggest that you go to the Library and look up how to airbrush. The paint goes into the cup. Nozzle adjustments are learned as you go, for desired results. Good luck
Feb 01, 2009 | Badger Basket Starter Spray Gun Hobby Set
Air Tools & Compressors Logo
522 people viewed this question
Top Master Heaters Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Master Heaters Air Tool and Compressor Expert? Answer questions, earn points and help others
