Question about Sub-Zero 661/F Side by Side Refrigerator
Sub zero front door frame inside of handles is very hot
    Scholar:
  • 112 Answers
This means that your unit is unable to dissapate the heat where it is intended to, the condenser unit. Open the top panel and check the condenser unit to see if it is clogged with debris. It will be on the rh side and looks similar to a car radiator. If it is dirty, clean it. Also, check to see if the fan is running that blows through the condenser. It should be running whenever the compressor motors are. If it is not blowing, replace it.
Posted on Oct 25, 2008
Sub-zero 601R door handle is loose
It is either screwed from inside the door, or there is a plastic insert in the handle you can prise out to expose the screwheads
May 19, 2012 | Refrigerators
Loose handle on a Sub Zero 611 with stainless steel front. Used various allen keys but nothing is catching.
Unfortunatly there is no easy way to do this, but your on the right track. The handles are held in place by set screws, meaning there is not nut or bolt, the screw itself just pushes against the metal causing firmness. I found it easiest to get long allen head wrenches, lay on the floor with a flashlight, look up into the shaft and try to picture the position in you head and have at it. Persistance is the only way you'll win that battle.
Apr 24, 2012 | Sub-Zero 695/O Side by Side Refrigerator
Ice making for sub zero 48
The sub zero should make ice soon after being installed. If there is ice around the door frame of the freezer there may be a problem with the door frame heaters. There should not be ice around the door frame.
Nov 09, 2009 | Sub-Zero 661/F Side by Side Refrigerator
How do you tighten a loose handle of the fridge door? Sub zero 642
I have the Sub Zero 650. I am not sure if yours iworks same but what you do is use a 3/32 Allen wrench; as you push the handle into the screw on the door so that it is flush, you insert the Allen wrench in the hole at the bottom of the short vertical connector at top and tighten; repeat for upper or lower part of handle.
Aug 15, 2009 | Sub-Zero 642
Sub zero paint peeling
I have found no fix for this. I have tried repainting but it is not long before the paint is falling off again. Get ahold of sub-zero and tell them of the problem.
Jan 23, 2009 | Sub-Zero 650 / O Bottom Freezer...
NEED ORIGINAL DOORS ON MY 561 SUB ZERO LOOKS LIKE DOORS ON FRONT
Given the model serial number I could get your decorative panels. The door itself is a framed door and designed to take a 1/4" insert. You can have new panels made if you have changed the cabinets, order stainless steel panels or put another material of your choosing. If you would like the more about the panels reply with mod and ser number which is in the freezer door jamb at eye level. Open the door past 90 degrees and look in.
Jan 19, 2009 | Sub-Zero 561 / F
Main door handle top section pulls out from bolt on sub zero 642
There is a tiny set screw that holds that in place. It is on the bottom of the stand off and just needs to be tightened.
Nov 26, 2008 | Sub-Zero 642
Sub Zero 642 - Gasket on the Door is really HOT
That is normal and is designed that way to keep moisture from forming water drops on the door seals. The "old days" used electric heaters but most now use the heat from the compressor liquid. If it's really hot you may have dust all over the condensor coils and should be cleaned to reduce the compressors heat output. Other than that, it's normal operations!
Jan 29, 2007 | Sub-Zero 642
Sub-Zero 661/F Side by Side Refrigerator Logo
256 people viewed this question
Top Sub-Zero Refrigerators Experts
Mike Cairns
Mike Cairns
halftank123
ACME Sub Zero...
ACME Sub Zero...
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
