Bose Sounddock Power connection Schematic
I have a bose sound dock with a broken power connector plug in the back. I have the plug but need a schematic for the 4 pins and the plug. There is +18 volts, - 18volts , and 2 grounds. I need to know which goes where.
Thanks,
Jerry
  • pccpower Jan 02, 2009
    Where did you get the replacement connector? I have a BOSE power supply PSM36w-201and the connector is now so loose it will not power the base.
  • 3 Answers
I have an 8 GB iPod Nano and my Bose speaker does not charge it, although it does play it. Talked to Bose and they say they have a solution due to the fact that Apple changed the connection pin on the newer iPods (8GB, 16GB and iPod Touch) Does anyone know which pin is the one that needs to be changed and where I can get it because the SoundDock is in Lima, Peru.
Posted on Aug 21, 2009
Hi Jerry -- I have this exact problem. Could you let me know how you got the replacement plug / connector?
Cheers, James
Posted on Jul 11, 2010
My Bose 321 switches it self off after 5mins . How do I stop this.
Occasionally the system may have the sleep mode activated , we have come across this before. Reset the system completely.
Any issues.
ELECTREPAIRUSA@ELECTREPAIRUSA or you can contact us at that address as we repair/renovate all items electronic and electrical old and new.
Jan 06, 2017 | Bose Audio Players & Recorders
Can i see Bose ® Cinemate ® GS Digital Home Cinema Speaker System mainboard
Sorry that type of information is not published on the internet.
The volume comes on loud even when i have turned it down before turning off
It sounds as if the UP VOLUME button/switch is broken and ON all the time. See if it is stuck down
Aug 09, 2016 | Dual Audio Players & Recorders
I have a Sony sound bar Model CT380. It has HDMI ARC and optical digital connections. The TV does not have these connections. What can I do to work around this?
How to connect a TV Sound Bar system to a television. - SONY
https://us.en.kb.sony.com/.../how-to-connect-a-tv-sound-bar-system-to-a...
Jump to If your TV has an HDMI terminal (without ARC) and an ... - Then connect theTV's Optical digital ... If your TV does not have HDMI input ...
2.1 ch Soundbar with Bluetooth ' HT-CT380 ' Sony US
www.sony.com/electronics/sound-bars/ht-ct380
Sony Corporation
Rating: 4.1 - ‎9 reviews - ‎$249.99
Discover the 2.1 ch Soundbar with Bluetooth from Sony & explore all the Sound Barsfeatures. ... filter higher frequencies to distribute audio smoothly around the room. ...against the sound bar to make an instant Bluetooth connection. No NFC? ... the HT-CT380 to allow data to pass through the sound bar straight to your TV ...
Dec 28, 2015 | Sony Audio Players & Recorders
Wireless headphone connection on Samsung UN40H6203AF
Are the headphones regular wireless (with a transmitter, sometimes called base or dock) or are they Bluetooth headphones ?
Jan 01, 2015 | Audio Players & Recorders
Switch on akai58022 tower speaker, it worked when I got it today and now it wont even switch on
what do you have it plugged-into for power ? it uses the 8-pin Apple Lightning dock connector. If you are using a USB adapter for that, then be aware that a USB-port will only let you draw 500mA or 1/2 an Amp of power....more than that will cause failures and damage to the USB port and the Hub even.
Nov 13, 2014 | Audio Players & Recorders
How to connect speakers to sony dts receiver strde935
The front and centre speakers need bigger cable, so the 3 pair of connectors can take thick wires. The satellites need tulip plugs, because they need less power. c7118031-3f7f-4f21-84a9-bff8010fd3d2.png
Jul 09, 2014 | Audio Players & Recorders
My ipod is just playing without the sound carrying through to the speakers. I dont know how to make it work?
Verify there is nothing plugged into the headset port, including headsets, headphones, or adapters.
Original iPhone only: While on the Home screen, adjust the volume buttons. If you see the icon below, indicating that headphones are attached, there may be debris in the headset port:
To remove debris in the headset port, try connecting a pair of headphones to the headset port and then remove the headphones. Repeat this several times.
If you have paired with a Bluetooth headset that is nearby, either use the headset or turn Bluetooth off (choose Settings > General > Bluetooth).
If that doesn't work, try restarting the iPhone. Hold the Sleep/Wake button until "slide to power off" appears. Slide to power off your device. When it is off, press the Sleep/Wake button to turn it back on.
If restarting the iPhone doesn't resolve the issue, try restoring the device.
May 28, 2011 | Audio Players & Recorders
BOSe Wave Radio - Disk "not readable"
I had the same problem with the disk unreadable error and took my unit to a authorized repair dealer about 100 miles from where I live to have it fixed. It ended up costing me about $300 to have the CD unit totally replaced which is almost as much as I paid for the unit in the first place. I am like a lot of you that used the CD very little although the unit was about 3 years old. I think Bose has a problem and would like us to think it is very rare. I bought a Lifestyle surround system about 14 years ago that has a CD and have never had a problem with it so needless to say I am very disappointed in the Wave II Radio/CD system. I am fairly certain the problem will occur again, but only time will tell.
Mar 03, 2008 | Bose Wave Radio
4,230 people viewed this question
 Grubhead
Grubhead
