Question about Hoover S3755 WindTunnel Bagless Canister Vacuum
Red light for HIPPA filter won't go off
I have had my vaccum for about 3 months, noticed the red light was on and washed the HIPPA filter, washed the canister and let them dry for 3 days. Everything is back in place, but the red light will not go off.
  • 2 more comments
  • Anonymous Jan 27, 2009
    same here
  • Anonymous Jan 28, 2009
    Same thing- disassembly yields no blockage; filter is new and still looks clean.
  • Anonymous Feb 02, 2009
    2 months after purchasing my vacuum, the same thing happened. I have had it professionally inspected (spending $50) and replaced the filter and belt, and still the red light is on. It has also lost suction. I will be taking it (a rather far distance away) to a certified specialist and hope to be given a brand new vacuum as a part of the warranty.
  • Anonymous Mar 22, 2009
    I am having the same problem. Even with the dust canister pulled out the light stays on. I have replaced all the filters, and there is no blockage I can see, unless it is somethere inside which can't be seen even when the unit is disassembled.
  • 1,901 Answers
Red light is sign of reduced suction due to a blokage of some sort. If you are sure the filter is thoroughly cleaned, check the hose, wand, and the nozzle connector for obstructions of any kind.
Posted on Oct 25, 2008
How do I fix dyson cordless vaccum flashing red light
Hi there, it's Jack at Dyson.
A flashing red light from a Dyson cordless vacuum signals a fault with the machine. We're happy to take you through some simple diagnostic checks over the phone when you have your machine easily to hand - just give us a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
If a replacement part is needed we can also confirm if this is covered under your Dyson guarantee.
We'll look forward to speaking with you.
Feb 20, 2015 | Dyson Vacuums
My vacuum was making a funny noise and had a bad smell
Hi John, it's Jack at Dyson.
Most Dyson vacuums include a thermal cutout which shuts the machine down for protection if it starts to overhead. You should find it will run again after it's cooled down for around 2 hours.
This is likely to have been caused by a blockage, or because the filter is overdue for a wash. To prevent this from happening again, please follow the steps shown in our Support guide:
In normal use, the filter needs to be washed at least once every 3-6 months, as shown in the video attached. Use cold water without detergent, and allow at least 12 hours for both sections of the filter to dry completely before replacing it.
If you'd like some further help from our experts after you've given both of these steps a try, please call the Dyson customer Helpline on 0800 298 0298 (UK), or 01-475-7109 (IE).
Jan 28, 2014 | Dyson DC08 Cylinder Bagless Canister...
How can you set the Caixing CX-2158 to 12 hr time instead of the military time?
for clock settings
Clock buttons from the left.
[1] Set
[2] Shift
[3] Modify
[4] Alarm
[5] End
[6] Reset - (use paperclip to push button in hole.)
Light indicators
[A] A.M.
[C] P.M.
[B] Alarm(s) active.
[D] Hour Notice
To set time and date
1.Push SET, push SHIFT to transfer from YEAR to MONTH to DAY to HOUR to MINUTE
2. Push MODIFY to change to desired value in every field (blinking)
3. Press SET or END to save.
To change from 24 - 12 hour format
1. Press MODIFY continously for about 3 to 5 seconds
NOTE: in 24-hour format, both the A.M and P.M light is OFF
1. Push ALARM, and alarm setting number 1 will show, push ALARM again to show alarms up to 8 or 9 (depending on model)
2. When desired alarm number is chosen, Press SET
3. Push SHIFT to transfer from HOUR to MINUTE
4. Push MODIFY to change desired value in every field( blinking)
5. Push END to save, (Please note Red ALARM light will lit)
1. Push ALARM until the desired alarm to cancel is shown.
2. Press MODIFY ( the dispaly will show --:--)
3. Press END (NOTE: Alarm light would only turn off only if all alarm is cancelled)
1. Push MODIFY button once (hour notice light would lit) - hourly notice is turned ON
2. Push MODIFY button again (hour notice light is off) - hourly notice is OFF
Oct 01, 2011 | Vacuums
Flashing lights.
The Flashing lights indicate several different things. 1 flashing red light means its time to charge your unit. if it is still flashing after charging then you will more than likely need to change the battery. A flashing red and green light means that the unit is overheating which could happen if the filters need to be washed, or that there is a blockage or if your machine has been left in direct sunlight. Allow 1 hour for machine to cool down. 3 flashing lights indicated that the pre-filter has been put on incorrectly. I hope this helps. If you do decide to wash your filter dont use any type of soap it is not needed and allow fiter to dry for atleast 24 hours. putting a wet or damp filter in will damage your machine.
Sep 18, 2011 | Dyson DC16 Root 6 Bagless Handheld...
The filter gives red light.Does this mean the filter must be washed or changed. How should it be washed, what does ´´washable´´ mean here?
Red light normally denoted filter is blocked. If it is a washable filter then wash it. If it liiks like a paper type filter, replace it. Washing it will make it clog up even more.
May 28, 2010 | Electrolux Oxygen Z5540 Pet Lover Vacuum
I bought it in may , I can honestly say , it is THE worst vaccum
There are several filters on bag-less vacuums that need to be cleaned. Dig out your owners manual or open the one below. See section 3 for filters and maintenance. If you are vacuuming a house bigger than about 1500 square feet, you should be cleaning the filters every other use. Personally, after using a bagless for a couple of months, I went back to my bagged vacuum.
Dec 20, 2009 | Hoover U6630-900 WindTunnel Bagless...
"New" Rainbow Eseries flashing red light
This is fine it is an indicator light that the computer is working.
Feb 24, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Hoover Light on
Mar 27, 2008 | Vacuums
Hoover S3755 WindTunnel Bagless Canister Vacuum Logo
769 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
