Question about D-Link DIR-615 Wireless Router
Probs connecting D-Link 615 with Mac
Hello, I have D-Link DIR-615 wireless router. I could not log in to the router on my MAC. On the Login (192.168.0.1) it asks: User name: Admin then Password: (I left the field blank) then Enter the correct password above and then type the characters you see in the picture below. (I've tryed "?" as on picture near but it didn't work). Pls advise
When you get the "Enter the correct password above and then type the characters you see in the picture below." as part of the login this is the non stndard (i'm not yet sure why this appears) but I found the solution to get the standard login screen is to use http://dlinkrouter/login.asp instead of the ipaddress. AT least it worked for me.
Posted on Jun 09, 2012
jkhtkd
  • 4 Answers
SOURCE: DLink DIR-615 can forward ports
You probably have a 3rd part firewall software on the PC, configure that firewall to allow the same ports. what AntiVirus do you have?
Posted on Jan 29, 2009
SOURCE: how to install d link Dir 615 router
Port opening
Posted on Apr 22, 2009
  • 25 Answers
SOURCE: D-Link DIR-615 Internet LED light not working
Even though we need more info to resolve the issue, I will make a guess here. My guess is that your D-Link is not configured right, (ie. not pulling the proper info from your ISP's DHCP server.
Try restarting the router and restart or repair your network connection on your pc. Secondly, try to do a "hard reset" on the router, or restore to default. Then reset your connection on the PC. Third, manually set the info on the router.
If you are wireless, you have a whole different issue.
Posted on Aug 14, 2009
Geekman
  • 32281 Answers
SOURCE: How can i put a password to my N router (DIR 615)?
Connect a LAN cable to the router and computer. Open your WEB Internet Explorer and your in the router's URL IP configuration address.
This will be 192.168.0.1 and the default Login = admin and the default password = (blank) just press Enter.
You can now change the default password.
Posted on Oct 21, 2009
  • 96 Answers
SOURCE: D-Link 615 Default password not working.
Your default admin password should also be blank.
-Comp Doctor
Posted on Feb 01, 2010
How can I find the WPA2 passphrase
Would either have to login into your routers configuration page through an internet browser, or if you have a Mac computer connected to the wifi use the program called Keychain to see saved passwords. Or if you have a windows computer already connected to the wifi you can find it on the wireless properties section of Control Panel. Would need your model # of your router to be more specific.
Aug 19, 2015 | D-Link DIR-615 Wireless Router
My instruction manual is in Chinese, i am using a mac and i cannot connect wirelessly to the internet, I have a DIR-605 router.
well here is a link to obtain the manual http://www.dlink.com/products/?pid=DIR-615
you need to select Support Resources Tab and choose the revision type you have. then you select product manual. One example is this one "DIR-615 no rev. http://www.dlink.com/products/?tab=3&pid=DIR-615&rev=DIR-615
GL
hope this helps
Don't forget to rate my answers
Thank You
Jammer
Sep 23, 2011 | D-Link DIR-615 Wireless Router
How do i switch off my wifi to stop people connecting to it without my permission
there is a way to stop people from connecting to your wireless network.
put a secure wireless password,activate MAC filtering and/or have your SSID hidden.
here a manual for your router.
http://static.highspeedbackbone.net/pdf/D-Link-DIR-615-Manual.pdf
just go to this link.
Sep 09, 2011 | D-Link DIR-615 Wireless Router
D-Link Dir-615 do not connect via wifi
Step 1: Open your web browser and type in the IP address of the router (192.168.0.1 by default).
Step 2: Enter the username (admin) and password (blank by default), and then click Ok or Log In .
  • How do I find my routers IP Address, in Windows XP?
  • How do I reset my router back to the factory default settings?
    (NOTE: To reach the configuration page of your D-Link router in Mac OS, you will need to use a Java compatible browser such as Firefox or Camino.)
    (NOTE: Some routers have a "Captcha" graphical login option. This option can be disabled in the advanced options of the routers configuration.)
  • Nov 20, 2010 | D-Link DIR-615 Wireless Router
    Is there a way I can set different access time controls for different wireless devices - If not with this model do you know which netgear or other wireless router can do this Thanks Farrol
    I don't know of any wireless routers that you can set up a timed access.
    What you can do is connect each wireless router to an timer that will switch on each wireless router at the times you require.
    Sep 07, 2010 | NetGear WGR614 Wireless Router
    I am trying to set up a wireless connection using dlink
    Try changing the type of Wireless Security that your are using.
    Mar 27, 2010 | D-Link DIR-615 Wireless Router
    Cannot connect MacBook to DIR-615 router
    Is your wireless network secured ?
    If you are trying to connect to the secured wireless network, make sure that the network that you are typing is correct.
    If you are not sure about the network key
    then check the network key on the router.
    You said that MAC is able to connect to the neighbor's wireless network.
    Make sure that the Wireless MAC filter on your router is disabled.
    Click here to know more about network key
    Oct 06, 2009 | D-Link DIR-615 Wireless Router
    New mac
    in dir -615 you can work it just you have to change the lan ip address in other range you get it .
    Jun 01, 2008 | D-Link DIR-625 (790069292637) Wireless...
    D-Link DIR-615 Wireless Router Logo
    196 people viewed this question
    Top D-Link Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
