Question about Aiwa AV-D58 Receiver
HOW TO RESET RECEIVER - Aiwa AV-D58 Receiver
How do i reset my dvr
If you stuck in CCTV DVR Password Reset process. just visit
CCTV & Networking Technical Support Channel on youtube.
Here is the link:-
CCTV Networking Technical Support
Jan 13, 2016 | Swann Communications Home Security
I have onkyo ds 989,how i can reset my ampli,tks
Hi Venobaaurora,
To do the reset you need to turn the receiver on then on the front panel of the receiver press and hold the "VIDEO1" button while doing that press the "POWER" button. You will see the word "Clear" in the display screen and the receiver is reset back to factory default settings. PLEASE UNDERSTAND THAT YOU WILL LOSE ALL YOUR AUDIO & VIDEO ASSIGNMENTS ON THE RECEIVER PLUS YOU WILL LOSE ALL YOUR SPEAKER CONFIGURATIONS, SPEAKER DISTANCE AND ALL LEVEL CALIBRATION SETTINGS. YOU WILL ALSO LOSE ANY PROGRAMMED RADIO STATIONS IN MEMORY. Once the receiver is reset you will need to go thru the setup menu for all custom settings, Thanks, JT
Feb 27, 2015 | Onkyo Audio Players & Recorders
My Pioneer Receiver VSX-519V has a blinking HDMI light and won't show video.
You guys mentioned the reset via the front panel, and I tried that with this very same issue on my VSX-822-k and it worked!
thought I would post the instructions for anyone else that lands here:
Reset the main unit if the receiver is generally not operating correctly. Switch the receiver into standby mode. Hold down the "BAND" button while pressing the "STANDYBY/ON" button for about two seconds. When "Reset?" appears in the display window, press the "AUTO SURROUND/ STREAM DIRECT" button. "OK?" appears in the display window. Press "STEREO/A.L.C." to confirm. "OK" appears in the window. The system has been reset.
Oct 28, 2012 | Pioneer Vsx 519v-k 5.1 Home Theater 550...
I have a Pioneervsx-1021k AV Receiver and all the buttons were working fine until I decided to play with the remote. Now some of the buttons light up, and some don't. I have found that not being able...
Hello
Just reset the system and try. So many external commands may confuse the system control IC inside, will hang up very like our computer systmes do. Resetting it to factory settings will make the unit work well. To reset the system:
Disconnect the iPod and USB memory
device from the receiver beforehand
1# Switch the receiver into standby.
2# While holding down ENTER on the front
panel, press STANDBY/ON.
The display shows RESET .
3# Select 'RESET' using PRESET then
press ENTER on the front panel.
The display shows RESET? OK.
4# Press ENTER to confirm.
OK appears in the display to indicate that the
receiver has been reset to the factory default settings.
Note that all settings will be saved, even if
the receiver is unplugged.
If this process does not help you, your system needs service with its main system control circuit. Actually this is a very skilled job, and should be done either by any well experienced service technician or by the Authorised Service Center for Pioneer at your town. OK.
Aug 21, 2011 | Pioneer VSX1020K Receiver
How do i reset my pioneer vsx 919 ah amp reciever back to its original settings
In the manual, page 72
Resetting the system
Use this procedure to reset all the receiver's settings to the factory default. Use the front panel
controls to do this. Set MULTI-ZONE to OFF.
• Disconnect the iPod and USB memory device from the receiver beforehand.
1 Switch the receiver into standby.
2 While holding down ENTER on the front panel, press ?µ STANDBY/ON.
The display shows RESET < NO >.
3 Select 'RESET' using PRESET +/-, then press ENTER on the front panel.
4 Press ENTER to confirm.
OK appears in the display to indicate that the receiver has been reset to the factory default settings.
• Note that all settings will be saved, even if the receiver is unplugged.
Feb 01, 2011 | Pioneer VSX-919AH-K A/V Receiver
TOMTOM ONE XL CAN NOT RESET, COULD ANYONE TELL ME HOW TO FIX
Hi, to be able to reset the gps receiver, you will need to download a reset utility.
Follow this link and download the utility. On that page you will also see the steps to install and use it.
handheld.softpedia.com/get/GPS/GPS-Receiver-Reset-Utility-67753.shtml.
Hope it helps.
Take care.
May 18, 2010 | Tomtom One XL GPS Receiver
How do I reset from the amp protect mode Onkyo receiver TX-SR600?
How do I reset my amp / receiver from protect mode ?
May 07, 2010 | Onkyo TX-SR605 Receiver
How do you reformat the hard drive for hr-20/700
If you go into the DVR's Menu/Setup there will be menu selections to "Restart Receiver" and "Reset Receiver"
In the reset menu you should find three options "restart receiver" which is roughly equivalent (and possibly safer) than the reset button or a power cycle. "Reset defaults" will clear all of your preferences and personal setting without affecting recordings. "Reset Everything" pretty much returns the receiver to ground zero and deletes everything.
Apr 26, 2010 | Directv HR20-700
Cant distinguis the type of reset on my menu
restart reciver is the same as unplugging the receiver. Restart defaults resets the reciever with default settings such as favorites and parental controls. Restart everything erases everything including the authorization and resets the receiver so a tech can re run the satellite setup and later call for a resend of authorization for that receiver.
Jun 08, 2009 | KVH DIRECTV D12 Satellite Receiver
Receiver on but not working
call direct tv and ask for a reset. When you do not use your receiver leave it on and connecetd or it will not receive updates and will forget what it once knew. Actually I think you can use the automated system and use (I think...not sure) code 712 to reset all your receivers with out waiting for help.
Dec 22, 2008 | Samsung SIR-S300W DirecTV DTV Receiver
Aiwa AV-D58 Receiver Logo
152 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
