Question about Konica Minolta magicolor 2300DL Laser Printer
Konica Minolta 2300 dl is "printing to file"
I found where to change it under properties of the printer but have no idea which "port" to send it to, I tried a couple different ones and it keeps saying there's an error.
I have Vista, but it has worked in the past w/ this computer, however, it seems that every time I plug it back into the computer it downloads a new driver I don't know if that's part of what's messing it up too????
  • gaylor Jan 15, 2009
    I have a Minolta 2300DL and all inks are reasonably full but everything I print comes out very pink and not as it should appear - how can I make it print without the pinkness to every picture - it prints perfectly well in black!
  • 43 Answers
The port depends on where you've connected the cable between printer and computer.
If a USB connection, select USB
if parallel cable, select parallel
if network cable (ethernet) select tcp/ip port
the driver must match the type of connection (use only 1)
you may wish to uninstall the printer driver then re-install it, keeping in mind which physical connection you have chosen to use.
Posted on Oct 25, 2008
Konica minolta magicolor 2300 dl print fades on first page
What do the internal prints look like demo page or counter list? What color is faded? Replace that image unit
Jul 30, 2014 | Konica Minolta Magicolor Office Equipment...
Just installed printer and drivers via a network connection for Vista 32bit. I did this per the instructions Provided by Konica at
I presume that the IP Address in the instruction is just an example IP Address. I don't know if your printer is connected to a router or to a Hub or Switch, but your printer's IP Address should depend on the device that provides the IP Address and the example is router. The first 3 octet of the Printer should be the same as the router's. So the setup should be router->printer then router->computer.
Feb 03, 2010 | Konica Minolta magicolor 2430 DL Laser...
Konica Minolta 5430DL second tray - print dialogue
This needs to be setup through the computer using the printer properties, not through the printer. You will need to be the local admin to make the changes. You may also have to go under advance and manual specify the tray and component types. The printer will not allow you to set options for trays and components that are not enabled or detected. Let me know if you need a step-by-step.
Nov 08, 2009 | Konica Minolta Magicolor 2530 DL Laser...
I just installed 4 new toner cartridges in my magicolor 2300 DL and I still can't print. It is still tellimg me to change the cartridges. Help!
You have to tell the printer that you have replaced the cartridges.
Here are step by step instructions:
Also, check to make sure that you have removed all the tabs and plastic strips from the toner cartridge.
Aug 04, 2009 | Konica Minolta magicolor 2300DL Laser...
Message says idle after changing three toner cartridges
have you tried to print anything? it probably means there is nothing in the printer memory that is needing to be printed.
Nov 20, 2008 | Konica Minolta magicolor 2300DL Laser...
Konica Minolta 2300 DL
Just sent you the manual.
Oct 02, 2008 | Konica Minolta magicolor 2300DL Laser...
Minolta 2300 dl laser printer fatal error 17H
had printer for approximately 2 years. Used daily in office setting. today the printer tried to print, then just stopped and it said fatal error 17H in the window. We cleared paper jam and rebooted, gives the same error message. Anything we can do?
Apr 14, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Will only let me print to file
Click on konica minolta properties, go to ports then check the correct port. Uncheck the print to file box
Mar 27, 2008 | Konica Minolta PagePro 1350W Laser Printer
Konica Minolta Magicolor 2300 DL - Fatal Error Code 0EH ????
I had the same problem one time, they told me to pull out all of the toner cartriges, power off, power on, power off, replace all cartridges and the problem went away.
Who knows why. If this doesn't work....
Call Konica Minolta tech support.
They were pretty helpful to me.
Nov 28, 2007 | Minolta magicolor 2300W Laser Printer
clean the machine , and change the toner.
Jun 02, 2007 | Konica Minolta magicolor 2300DL Laser...
Konica Minolta magicolor 2300DL Laser Printer Logo
178 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
