Question about Sharp 25L-S100 25" TV
No sound We lost the remote and had to use the up/down channel method of getting our tv from air to cable. Worked like a charm and we now have all our channels... but no sound. We had sound before we accessed the menu, but no sound since. Plugging in a DVD player and such does not produce sounds either.
  • 3 Answers
Try to buy a new remote control or if not available to market try to use the universal remote control you can buy in electronic supply .before you buy check first the model if covered if not try to contact the products manufacturer.
Posted on Nov 06, 2008
No picture, but sound
tried to hooked up with an air antenna. if you can not get any channel and just a white raster or snow, it could be the tuner get fried.
Jul 22, 2012 | Sony KV-32S45 32" TV
Goodmorning, bought a zenith tv didn't get the remote. Wonndering how i can programme it using just the buttons on the tv. How do i get the menus up. it only catches threes channels as of now.
Hello
There are two types Zenith TVs. One type will have "Menu" button on its front panel and other will not. If your Zenith is the first type, you can programme it without a remote control. If it is the second type, you must have a remote control hanset to programme it.
Programming method
First connect the TVs antenna socket at its back with external antenna or cable.
* With the remote control in hand, press the POWER key to
turn on the Presentation TV.
** Press MENU repeatedly until the Setup menu appears.
*** Using the Up/Down arrow on the remote control, highlight
Auto Program on the screen
**** Press the Right or Left arrow to go to the Auto Program
menu.
***** Using the Up/Down arrow, choose either Cable TV or Off-
Air Antenna on the screen.
****** Press the Right or Left arrow to begin the Channel Search.
******* Press ENTER when the channel search is done.
Note: Auto Program finds channels being received by the TV
tuner
Cable will not work unless you subscribe to a cable service
OK.
Jun 17, 2011 | Zenith H27E35DT 27" TV
I have cable but only can get up 26 channels .i don't a remote control so can yo tell me how t program my channels
You have cable, but are you using a cable box? Sounds like you are running coax direct to the TV. Is this correct? If so, you will need to get into the menu of the TV. Locate "Connections" or "Cable Source" and select "Cable" not "Air" and then let it auto format. Will take several minutes. It will only make available the channels that come in through that line. Let me know if this worked.
Jul 01, 2010 | Durabrand BH1304D 13" TV
Lost remote
Actually I found there are several remotes that work. The first is the Bright House networks remote, the larger one...The second is The Universal Remove Control by GE. It's numbered 24944 in the upper right hand corner of the paper. It's sold for $4.94 at Walmart in the checkout area...
I found that manually inputting the code for the remote doesn't work. You have to do a search for the code using their method...on this particular remote from Walmart, its hold the setup button down until it lights up, then press and depress the TV button...then press channel up until the TV changes channels. It worked once, but I just kept going, the 2nd time it worked, then I pressed the mute button [to keep the code] and it works...you simply press input and it switches to AV.
I have to admit I thought it was ridiculous that you can't use this particular TV without the remote, but I was happy that I went through the effort the first time to keep trying remotes...
This is the first kids TV that I have found that you can't find the AV channel by going through the channels AND you can't hook up two items to the AV outlets because you have to disconnect the back or front ones, to use the other....PLUS it only comes with a dual AV outlet, instead of the 3 plugs [red, white, yellow] only has the white and yellow.
A disappointing TV to say the least.
Feb 11, 2009 | Emerson SpongeBob SquarePants TV
Daewoo DVN-14F6N
Same problem...Went to Goodwill Store, they usually have a large basket of remotes. I found a Daewoo remote for a TV only, HOWEVER on the bottom it has a AIR/CABLE button. The remote doesn't say Daewoo on it only..."Remote Controller R-25B03". The rest of the button of course work with the TV portion of the DVN-14F6N.
Sep 17, 2008 | Daewoo DVN-14F6N 13" TV
Partial Cable
The TV is set to antenna mode or over the air mode rather than the cable mode. You should be able to navigate through the menus to change it to cable mode. That should resolve it.
Dan
Jun 05, 2008 | Televison & Video
Lost Remote
the sony rm-v310 universal remote solved my problem. its about 15 bucks and worked on my symphonic 20" tv. bestbuy should have one.
Dec 15, 2007 | Symphonic ST419E TV
Can't clear channel off screen of Sony Trinitron with remote
Press (on your regular remote for your satellite) the t.v. button, then press info, this worked for me and I tried everything. another viewer posted this solution and it worked great! this is not the original remote, it is the satellite remote.
Nov 22, 2007 | Televison & Video
Message on TV screen
Well i fix my problem with an universal remote control of GE here is the link from walmart that is from where u can get it just $6 when u got the control program it with the code 0254 and when everything is working press SHIFT and release and then press Volume+ and the channel set will disappear... Hope this can help
http://www.mountsandmore.com/GE-24912-GNE1003.html
Aug 27, 2007 | Televison & Video
Sharp 25L-S100 25" TV Logo
113 people viewed this question
Top Sharp Televison & Video Experts
Dave Naylor
Dave Naylor
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
