Question about Bulova Watches
I can't seem to remove the back casing on my Bulova watch in order to replace the battery.
If you take a small scredriver (one that is used to repair eyeglasses) and run it gently around the rim of the back, you will feel a slight indentation where you can insert the screwdriver to open up the back. The battery is easily accesible but then it's tough to get the back back on!
Posted on Nov 22, 2009
    Champion:
  • 203 Answers
Its probably a screw on back that needs a special tool to open it. but even if you do open it you will not be able to seal it properly
Posted on Nov 21, 2008
I need to find out what battery I need for my bulova 96T14 watch
  • Remove back
  • Find battery and identify
  • Obtain replacement
  • Remove old battery and install new
  • Check operation
  • Reinstall back
  • Set time, etc.
Oct 10, 2016 | Bulova Watches
How do i change the battery of a Bulova 96L37 watch
take it to walmart and let them do it . of any god watch shop . you need a case press to put it back together without breaking the front crystal
Feb 14, 2015 | Bulova Watch
Time to replace the battery, but cannot manage to remove the back cover. Any special tricks? I'm familiar with using sharp knife blade to do this, but it's not working. Thanks!
You defenately need a watch case opener.
It can be more than difficult to open a watch case with a sharp knive/screwdriver without destroying it.
A case opener can be the only solution.
Otherwise you'll have to bring your watch to a professional to get the battery replaced.
http://www.watchtools.co.uk/watchtools.html#opener
Good luck
Aug 23, 2011 | Bulova Caravelle Strap 43C20 Watch for Men
I can't seem to unscrew the back to get to the battery
Thanks for contacting FIxYa..
You will need to take it to an authorized Bulova retailer to have them use the correct tool to remove your battery.
Best regards. Jewel
Sep 13, 2010 | Bulova Men's Watch
How do you remove the back of a Bulove watch to change the battery
There is a reason why Bulova watches cost so much when you need to replace the battery....it's DIFFICULT! You can try the following, but I would HIGHLY recommend having a jeweler replace it for you. At one time Walmart did it for next to nothing, but I don't know if they do Bulova watches at this time, but it costs nothing to call them.
Try this AT YOUR OWN RISK:
The best choice for removing a threaded caseback is to use a "caseback removal tool", which consists of two or three adjustable "pins" attached to a handle (most WalMarts sell a two-pin tool in their jewelry department, and you can purchase a better three-pin tool from several vendors on eBay). To use it, start by placing the watch face-down on a padded surface (to avoid scratching the crystal). Adjust the pins so that they very snugly fit into the notches cut into the caseback; if you don't, the pins can jump out when you try to use it and scratch the watch. Place the tool over the caseback and engage the pins into the slots; then, holding the watch steady with one hand and the tool in the other, give the tool a counterclockwise turn to loosen the back (it may take a lot of force to do this, especially if this is the first time the battery is being replaced). Once the caseback is loosened (usually about 1/4 to 1/2 turn), remove the tool and finish unscrewing the back by hand to avoid scratching the watch. Be careful as you remove it as some watches use a very thin O-ring on the back to make a watertight seal.
Afer replacing the battery and ensuring the watch is running properly again, carefully inspect the surface of the case and the threading on the caseback and remove any dust or grimy deposits with a soft cloth. Then, place the caseback onto the case, being careful to align the O-ring or other seals, as well as the caseback threads (tip: to ensure the threads are lined up, place the back on the watch and turn it counterclockwise about 1/2 turn or until you feel the ends of the threads "fall" into place). Screw the caseback down as far as possible by hand, then use the removal tool to tighten it the rest of the way.
Oct 03, 2009 | Bulova Crystal 96L000 Watch for Women
How do I remove the back face to replace battery?
You should take it in, it would only cost $5-10 to replace the battery. Otherwise you need a case back removal tool
Apr 15, 2009 | Bulova Diamond 98R44 Wrist Watch
How to Remove Watch Case to Replace Battery
the anser to the question is you need a special tool to open the watch as this is a screw back and you can buy this from Watch repair dealer from about £10
Jan 31, 2009 | Bulova Watch
I have a bulova 96b34 that has a rechargeable battery but needs a new one.the battery has a little welded contact on the back and i have no idea where to find one.
Batterie model is Panasonic MT920. You can order a Citizen part no: 295-5600 who is a rechargable batterie for watch mouvement Miyota model BR10. That mouvement is use in Bulova motion quartz, Invicta automatic and Citizen eco drive.
Jan 08, 2009 | Bulova Millennia Motion 96B34 Wristwatch
I have a Bulova Caravelle mens wrist watch case number C877548. I have to replace the battery but I can't figure out how to get the back of the case off. Thanks
Hi. If you take a tiny screwdriver (one that you might use to screw a screw into an eyeglass and run it gently around the back you will feel an indentation where you can insert the tip and pop open the back. The battery is easy to access but trying to get the back back on is the problem! Good Luck.
Sep 11, 2008 | Bulova Watches
Bulova 96R19 ladies diamond chronograph
Watch shops use a press to put backs on. Some will snap on using your thumbs, other need the press to apply more force.
Mar 19, 2008 | Bulova 96R19 Wrist Watch
Watches Logo
1,058 people viewed this question
Top Bulova Watches Experts
Geoff
Jimmy Accardi
Are you a Bulova Watch Expert? Answer questions, earn points and help others
