Question about Cuisinart CPT-90 Classic Style 4-Slice Toaster
My toaster doesn't stay in the down (toast) position unless I hold it down
Almost every time we try to use our toaster, the lock that keeps the toaster in the "toast" position (bread lowered and heating elements heating) doesn't work, so we have to hold the lever down by hand. On occasion, the lock works properly immediately after depressing the lever to start toasting. Sometimes, the lock will start to work after the toaster warms up a little, and will complete a toasting cycle properly. I opened up the toaster so check if there was anything obvious getting in the way of the lock, but didn't find a physical problem. The lock is kept locked by an electromagnet that looks like is controlled by a small circuit board. If the problem is with the circuit board, I would bet that it wouldn't be cost-effective to repair. Any ideas/suggestions would be appreciated. Ed
  • Anonymous Jan 01, 2008
    I had the same problem with this model. Made sure it was unplugged,
    took the 4 screws out of the bottom as others did. Pulled off the
    handle for the toast push down and the knob for the darkness control
    (it took some effort but came off ok, if you can tilt the darkness knob
    opposite the number 1 it will come off easier, there's a hook-tab right
    at the 1 position).
    My problem was with one of the points on the 4 copper tabs that come
    together as the toast is pushed down. The outer copper tab was
    slightly out of alignment when the toast was in it's latched position
    and broke the circuit making it never want to latch. I bent the
    problem one into alignment and solved the problem.
I solved this problem on my Cuisinart CPT-90 Classic Style Toaster twice for two different problems. Of course: make sure it's UNPLUGGED while working on it and WATCH IT several times when testing so you can unplug it first and then extinguish it if it catches on fire.
1st time: There is a small solenoid mounted in the center of the circuit board. When the pop up mechanism is pressed down the circuit energizes and the the solenoid magnetically locks a plastic clip that holds the spring loaded pop up mechanism down until it's done toasting. The plastic mounts for the circuit board broke or weakened until the whole circuit board would tilt up and the solenoid clip would slip under the spring tension. I used a plastic tie-wrap to hold the circuit board firmly in place and that worked to this day.
2nd time : The four copper reed tabs can be miss aligned. If they
do not make contact, the circuit will not energize the solenoid.
The reason they warped was that, over time, the contacts build up carbon and have more resistance. Resistance equals heat. The
plastic base of the copper reed switch melted and misaligned the reeds. The second time I cleaned the reeds and bent them back into position, The third time the the plastic was to badly burned to be reliable. If I had cleaned the contacts once a year, it probably would still work now. I haven't found a place to buy a replacement reed switch so my toaster is toast. If anyone knows where to order them, I'd like to know. If the white plastic base of the reed switch is not melted, then they can be cleaned and aligned.
Note: When aligning the copper contacts, don't just hold down the pop up mechanism. The pop up mechanism will push lower than the position for toasting. Push it down and then hold the solenoid clip instead. Then the two center reeds will be at the correct spread.
Posted on Jun 26, 2010
I had the same problem with this model. Made sure it was unplugged, took the 4 screws out of the bottom as others did. Pulled off the handle for the toast push down and the knob for the darkness control (it took some effort but came off ok, if you can tilt the darkness knob opposite the number 1 it will come off easier, there's a hook-tab right at the 1 position).
My problem was with one of the points on the 4 copper tabs that come together as the toast is pushed down. The outer copper tab was slightly out of alignment when the toast was in it's latched position and broke the circuit making it never want to latch. I bent the problem one into alignment and solved the problem.
Posted on Jan 01, 2008
I had the same problem.
I opened up the toaster and found that the 4-copper connectors, that are straight up, had points between each pair. With the toaster unplugged; use a points file (I also used my wifes nail file) and polish the points so that there is good contact again. Then adjust the gap between each pair of the outer copper connectors so that they made good contact when the toast lever is pushed down. If you are very careful you can check the operation with the cover off; push the lever down, it will stay down and then push the "cancel" button and the lever will come up. (You will be able to see the spark as the points open.) Try it a few times. But don't try to adjust the gap between the connectors unless the toaster is unplugged. (Since this will happen again get a points file from a local auto parts store; tell them that it is for a 56' Chevy that still uses points in the distributor.)
Posted on Feb 23, 2009
I have the same problem and my circuit board is well glued in place, the copper tabs all make their connections so it must be a problem with the circuit board itself. Any other suggestions out there?
Posted on May 19, 2008
My problem was fixed by solution #2. After looking closely at the copper tabs and the contact points, the outer tab was indeed out of alignment. I had the toaster for 6 years, first problem ever with it. Thanks for re0alignment resolution.
Posted on May 03, 2008
Appreciate guest's solution that involved taking off the bottom of the toaster. I removed a total of 6 screws, still could not take the bottom off. Could not remove the plastic knobs. Seemed to be hung up on the control panel. So I replaced the bottom, turned it upright and then smacked it firmly against the table, hoping to get the circuit board in place again. It's working now, who knows why or for how long.
Posted on Dec 27, 2007
FIXED the Handle wont stay down problem. Unplug toaster, then remove 4 screws from bottom. pull off both platic knobs. lift off toaster top. at first i thought my electro switch was broken but i found out that the circuit board was loose. it was popping up and inturn that was breaking the magnetic field which was holding down the lever. Secure the board so there is little to zero upward movement. that should a fix. good luck. if you looking closely you can see the glue that was used by the factory to hold down that board. my glue was no longer good.
Posted on Dec 18, 2007
I have the same exact problem with my CPT-90. still thinking of how to fix it.
  • kburnssr Nov 15, 2015
    I had the same problem. I took the toaster apart several times re-aligning the points. Then one day the toaster threw a lot of smoke and would not work. The left side of the white plastic bracket that supports the 4 reeds/points had melted. No replacement parts were available. I discovered that the cause was a workmanship issue. The connector on the left side that is connected to the cord "hot" was corroded. I also noticed that only about 1/3 of the stranded wires from the 16 gauge cord were crimped into the factory female connector. The heat from the resistance in the weak connection caused the connector to corrode, eventually over-heat, and distort the plastic that supports the 2 left reed/points. I went to ACE and purchased a new 16-14 gauge female connector with a 0.187" tab and crimped ALL of the 16 gauge stranded wires into the connector. I used super-glue to affix the taller left reed to the white plastic support and used shrink-tubing and two nylon tie-wraps to hold the far left reed/point in place. It's working again, like new. It's too nice a toaster to just chuck! The newer toasters are expensive and just plain ugly.
    Find the link to the replacement for this CPT-90 toaster below. They are identical but the new one doesn't have the 1/2 slice option switch.http://www.chefsfirst.com/Commercial-Toa...
Toastess -TT 215P 2 slice toaster
if you can open it up the thing that holds the tab down could have been used up already.
tnx 4 using fixya.
drcool
Sep 09, 2008 | Toastess TT-215P 2-Slice Toaster
Why won't my calphalon toaster oven toast top of bread? Why?
If both the top and bottom elements are working then you may need to re-position the rack closer to the top element for even toasting. If there is only one rack position available then you may need to flip the bread and toast it twice.
Oct 06, 2014 | Toaster Ovens
Black & Decker Toaster Oven - elements cycle on and off, which makes for a SLOW cook.
Oven has three modes: 1) oven mode cycles elements on and off to maintain a specific temp setting for up to 60 min. 2) toast should keep all elements on for a few min. 3) broil mode top elements only always on, up to 60 min. Make sure you have dials in correct position and use the toast timer.
Apr 17, 2014 | Toaster Ovens
Control lever will not stay down
Unless you have power switch on to the toaster, the level will not stay down. Ensure you have main power available!
If the unit is powered, check that the 'toast darkeness' level is set accordingly - it is this 'thermostat' that determines when to eject the toast: if you checked that you have power and that the darkness level is not set to zero and it still does not work, then it is time to get a new toaster! If not under warranty, it is probably not worth trying to get it repaired.
Apr 08, 2014 | Bodum 10709 Toaster
GE toaster model 169100. : the lever to toast won't stay down. I researched removing the base to clean the magnets, but not regular Phillips screws. Suggestions??
I have the same GE toaster and now my lever won\'t lock in place when I push it down to cook my toast. The handle does not pull off and when you turn the toaster over there are no screws to take the toaster apart. So I guess I have to say this is a disposable toaster but I am extremely bummed because it is beautiful and match decor and microwave that has the same color scheme as my toaster.
I wish companies would stop making cheap junk that doesn\'t last more then a few years.
Sep 06, 2013 | GE small appliance toasters 169100 User...
The left side of the toaster does not stay engaged...if I hold it down it heats up but it doesn't stay down ..it doesn't catch.
There are two printed circuit boards inside front of toaster - One PC board for each side. The circuit board on the side that won't latch down in the "toasting" position , is defective. Now, does anyone have access to a schematic for this toaster?
Jul 02, 2011 | Cuisinart CMT-400 Cast Metal 4-Slice...
We have the four slice toaster. The arm on the left will no longer stay down. The side still toasts, but the arm will not lock in the down position.
try removing the lower claening plate and remove the bread crumbs and see if that makes it work again. Many people don't know there is a cleaning try on the toaster.
Mar 21, 2010 | VillaWare 5850 Uno Classic 4-Slice Toaster
Cuisinart CPT-90 Classic Style 4-Slice Toaster Logo
9,776 people viewed this question
Top Cuisinart Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dale Anderson
Dale Anderson
Level 1 Expert
Tom Chichester
Are you a Cuisinart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
