Question about Nikon ProStaff Rifle Scopes
I have a Bushnell 3-9x32 silver finish rifle scope. I am really happy with my scope. The rubber eye guard ring at the end of the scope has deteriorated. What can I do? I do not have a receipt or anything.
  • 32 Answers
The part is able to be replaced at a cost of about $2.00.
Contact Bushnell for agent or order online at www.bushnell.com
Posted on Oct 25, 2008
I just bought a 4-12x40 trophy xlt rifle scope with an adjustment of numbers on the bell. What is it?
That is a parallax adjustment. You set it for the distance you are shooting at. It appears to be marked in both yards and meters. This adjustment assures the reticle does not appear to move when your eye is moved slightly from side-to-side. Set it for 200 and look at a target at 50 and move your head very slightly side-to-side and you will see the difference.
Sep 17, 2014 | Bushnell Trophy XLT Riflescope 4-12x40...
Lense n my v9-IIw is loose inside
how did the lens come loose ?
if you dropped it shell out for a repair or replacement
or if it was through normal use try to get bushnell to fix it for free due to a defect in manufacture
Oct 31, 2013 | Bushnell Trophy 3-9x40 Rifle Scope, Matte...
How to disassemble my bushnell sportsman rifle scopes coz i wnt to clean it
On my Bushnell scope I have an adjustable angle ring that will bring in the view, it is held in place with 1 screw. remove it and pull down towards the windage and elevation adjustment screws. There are 3 tiny phillips screws, remove them. Then unscrew the end of the Eye Peice end peice with the lens in it. inside on the outer edge of the main tube there is a locking ring that keeps the eye peice from unscrewing off, remove it and unscrew the entire eye peice. you are now ready remove the inner tube. Be careful here this is where you can damage the cross hairs and lose the leaf spring that maintains pressure against the windage and elevation screws. When you reassemble after cleaning and with the elevation screw at 12 o'clock and windage screw at 3 o;colck, the leaf spring will be in the 7 or 8 O"clock position, it just sits in there up against a little ridge inside, with the bow facing to the center. Back off the elevation and windage screws all the way so they don't block the inner tube from going in all the way. Once it is in adjust it so the cross hairs are orented correctly and put it back together. If you want to refill with Nitrogen remove the front lense and take to someone that fills tires with Nitrogen and inject the nitrogen into the scope, Quickly reinstall the front lens as nitrogen is about 3% lighter than air and if you take too long it will all escape.
This worked well for me. Good Luck and Happy shooting
Apr 27, 2011 | Bushnell Sportsman 4x32 Riflescope (4x32...
My scope keeps getting fog and moisture, what do i do
in short,,,throw it away? the rubber "O" rings have failed and are letting in water,,,,its had it,
Nov 27, 2010 | Bushnell BANNER RIFLE SCOPEPower: 3-9X40 /...
Keep having to resight scope
Sounds like they are right. The cross hair adjustment mechanism may be defective. I'd call bushnell and see what they can do for you.
Bushnell Corporation
9200 Cody
Overland Park, KS 66214-1734 Kansas City area - (913) 752-3400
Consumers - (800) 423-3537
Dealers - (800) 221-9035
Fax - (913) 752-3550
Apr 08, 2010 | Bushnell ® Elite® 3200 3 - 9x40 mm...
Need the rubber eyegaurd for a Bushnell Sportview rifle scope
if you need the rubber eye guard for this rifle scope you are using it all wrong,,,if your eye is so close to the end bell of the scope your going to get a very black eye,,,there is at least 2 inches of eye releaf on this scope so there is no reson to have a rubber bit on the end at all, i have 3 of the bushnell scops on my rifles a ,,,7.62,, .303,,,22.250 and none have the rubber on them,,,so far iv never had a black eye!
Nov 15, 2009 | Bushnell 3-9x38 Sportview Rifle Scope...
When adjusting for a couple of inches, the next shot is a foot off. It seems to wander all over the target.
! click is 1 inch @ 100 yards, provided you have the correct scope for the rifle.
If you are sighting in a .22 LR 40 grain match velocity bullet for 100 yards, the mid range trajectory (50 Yards) is 6" higher. The bullet has a 6" arc half way to your target. If you are sighting in a .270 with 150 grain blunt tail bullets for 250 yards, the mid range trajectory is .4 higher. It only has 4/10" arc half way.
You most match the scope to the gun, and the 1 click= 1 inch rule will apply. Otherwise, it's lock it into a righd mount, fire it and adjust the scope accordingly. If you want to change the range on the scope, it will be guesswork.
I use a Bushnell Banner 3-9X40 with BDC. If you have BDC, make sure you have the correct distance ring in for the caliber.. It will make all the difference in the world.
Oct 27, 2009 | Bushnell Trophy 3-9x40 Rifle Scope, Matte...
Eye piece on my Bushnell rifle scope is loose. What could have happened?
There should be a lock ring that you need to snug up against the eye piece. Vibration can sometimes cause this ring to come loose.
Oct 01, 2009 | Bushnell Optics
Missing eye relief guard - rubber
I would try Midway.They have about everything for anything related to optics and hunting.I have used them for years.www.midwayusa.com...Good Luck
Dec 22, 2008 | Bushnell Banner Dusk & Dawn 6-18x50...
Optics Logo
407 people viewed this question
Top Nikon Optics Experts
Mark Campeau
Level 1 Expert
Are you a Nikon Optic Expert? Answer questions, earn points and help others
