Question about Syntax Olevia 527-S11 Television
Unable to set the screen resolution on a Olevia 27-s11
I just hook up my daughter desktop to her Olevia Tv 527-s11, tried to set the screen resolution higher so I can get a sharper and smaller icons on the monitor screen but when I go to control panel - Display - Setting - then trying to slide the slider under "Screen Resolution" from less to more, it won't budge, it stays at 640 x 480 pixels... I do believed I tried everything. please help
  • 6 Answers
SOURCE: We are trying to play out playstation 3 on our Olevia 226-T11
be sure to check:
The tv is on the appropriate AV Channel ( the same one you plugged the ps3 cable into )
The cables are connected properly.
Or Your channel input settings might be wrong on your tele ,, so maybe, AV 2 is set to actually take signal from the AV 3 input...
Maybe wrong but just check these things cause sometimes its something stupid and you'll kick youself later ha ..Good luck
Posted on Jan 13, 2009
  • 45 Answers
SOURCE: no channels found
you could try ant. on the tuner of the television and try to see if it grabs any channels on AIR ..if the scan goes all the way without finding any channels then the tuner of the television is not working. This means the mainboard will have to be exchange or repair..
This company called Amergence Technology is a 3rd party repair center and is able to offer repair services.. they could give you an idea on the repair cost and the process they have in place..
there number is 866-965-3842
Posted on Jul 28, 2009
  • 4090 Answers
SOURCE: picture is too big for the screen
go to page 37 of the manual and read through to RESET TO FACTORY SETTINGS
Thanks for using FIXYA
Posted on Sep 28, 2009
  • 112 Answers
SOURCE: I have vertical lines on the entire right side of
most of the stuff from jimmy's its second hand ( not good working or working maybe) first and the last i suppose you got a problem with the power supply on the T con on the second i suppose you have a problem with the big chip in the middle the scalier :D
Posted on Jun 02, 2011
enigmatic1
  • 27 Answers
SOURCE: Hi, my control for my olevia doesn't work anymore
I have tried a few times to use one of these universal remote controls for televisions and I have never had any success. If you have bought it new, there will be rather complicated instructions on how to set the device code into it, based on the brand, there will be numbers listed for the different models, this is the device code. If the brand is not listed, it will tell you how to set it in search mode. I have tried both, without success.
I guess some people get them to work or they wouldn't be for sale, I hope you have better luck than I did.
Posted on Aug 25, 2011
Olevia 527-S11 Power Board
you can try shopjimmy.com, or ebay. You will want to search for the part # DPS-162CP. Verify that this part# matches your old one
Sep 01, 2012 | Syntax Olevia 527-S11 Television
Olevia tv shuts off by itself
Likely the main board and most of these sets there are few or no boards available.
I have sound but no picture on my Olevia tv, model 323-S11
this sounds like a mainboard issue , a replacement mainboard will solve this problem
Apr 23, 2010 | Olevia Kolin DLT2711M 27 in. LCD...
My olevia tv shows a no signal on screen, what could it be?
try this Audio Out of your Cable box colored RED and WHITE is connected to your TV's Audio In RED and WHITE. And connect the VIDEO out of your cable box YELLOW to your TV's VIDEO IN function c_getProfessional_AskGet_refreshPicture() { var imm = $("getProfessional_ask_fromprchat"); var val = false; if(imm) { val = $("getProfessional_ask_fromprchat").checked; } var pOn = $("c_AskGet_checkBoxOn"); var pOff = $("c_AskGet_checkBoxOff"); if(!pOn || !pOff) return; if (val) { pOn.style.display = ""; pOff.style.display = "none"; } else { pOff.style.display = ""; pOn.style.display = "none"; } } function c_getProfessional_AskGet_toggleImmediate() { var oImmediate = $("getProfessional_ask_fromprchat"); if(!oImmediate) return; var val = oImmediate.checked; oImmediate.checked = !val; c_getProfessional_AskGet_refreshPicture(); } c_getProfessional_AskGet_refreshPicture();
Mar 26, 2010 | Olevia 227-S11 27 in. LCD TV
Received used Olevia 226-s11 hdtv, hook-up up (no
I need to go to Menu, Picture, Mode, Home.....
The default setting for the TV was Showroom which wouldn't let the cable signal through. Thanks for trying to help.
Jan 12, 2010 | Televison & Video
The tuner's not working and won't let add channels.
no channels? blue screen? no signal?
Solution:
A Converter hdtv box... is the SOLUTION!!! try it..youll see!!!
I had the same scan-turner problem with my Olevia "digital" Olevia tv!!
Because I was curious i tried that to see what happen..and it worked!!
Olevia tv fixed!!!
Easy..your tv is not able to scan cahnnels...then, the solution is to plugging "a thing" that can do that: a converter box.
Oct 19, 2009 | Syntax Olevia 527-S11 Television
Need 5 Digit Remote code for Olevia 227 s11 and comcast remote
mbhagdev, i've found that sometimes by using the remote code search procedure i have been able to program some hard to set brands either tv, vcr.dvd etc. try this procedure you'll find it in your set up manual for your universal remote, your other option would be to click the web page for the universal remote you are trying to program and give them the corresponding info to see if they can come up with an updated code for your olivia tv. good luck and thanks for leaving pos feed back if i answered your question.
Aug 22, 2009 | Olevia 227-S11 27 in. LCD TV
Olevia 227-S11 driver for windows xp
I had the same problem. Install powerstrip for free from download.com. It will now trick your pc into letting you change your resolution from the control panel options.
Jul 25, 2008 | Olevia LT27HVX 27 in. LCD Television
Syntax Olevia 527-S11 Television Logo
56 people viewed this question
Top Syntax Televison & Video Experts
Jaime Hernandez
Kolbrun...
Are you a Syntax Televison and Video Expert? Answer questions, earn points and help others
