Question about Sew Pro QuickStitch SP-402 Mechanical Sewing Machine
Lost Spool pin and cap for QuikStitch SP-402
I borrowed the machine from my sister and it is missing the spool pin and cap, but I do have the spool stand. Is there anything else I can use as a spool pin and do I really need the spool cap? If I have to get these exact pieces, does anyone know if and where I can order only these parts? Thanks
    Scholar:
  • 34 Answers
Welcome to FixYa. If you have a spool stand, that might work as long as you can thread the machine properly (give it a try!). When the thread is placed on the machine's spool pin, the spool cap keeps the thread in place and helps the thread unwind evenly - so if you are using a spool pin, you really do need a spool cap.
If the spool stand works, you are good to go. If you need to order replacement parts, I've provided a link the manufacturer's website. From there, you can contact customer support and find out if parts are available. If you can't order replacement parts, ask customer service if the machine is compatible with another brand. Another option would be to buy a spool pin and cap at a sewing machine dealer. Take the machine with you and and make sure the parts fit before you buy them.
Here's the link to the site I mentioned:
http://www.topinnovations.com/products/sew/SP-402/SP-402.html
Thanks for stopping by. If you have an extra minute, feel free to rate my solution. I'm eager to improve my solutions if they are not helpful. If you have further questions or would like to consult with another FixYa expert, just leave a comment and I'll do what I can to resolve your problem.
Posted on Jan 31, 2009
  • talk2ginny
    talk2ginny Feb 04, 2009
    Hi -just wanted to check in and see whether you were able to thread your sister's machine using your thread stand. If you are still having problems, please feel free to check in again.
Can't figure out how to fill the bobbin
hi Beverly.
you have not said what make and model.
but try this.
Always wind the bobbin before threading the machine and needle.
  1. Place spool of thread on spool pin.
  2. Slide spool pin holder/cap firmly over rim of spool to prevent thread from tangling.
  3. Push bobbin winder pin to far left if it is not already there.
More items...
Winding a Bobbin ' Singer Sewing
www.singerco.com/sewing-resources/bobbin-winding-other
or try this.
How to fill bobbin for sewing machine
How do you fill a bobbin on a Brother sewing machine? Use only the included bobbin or bobbins of the same type (part code: SA156, SFB (XA5539-151)).
  1. Turn on the sewing machine, and open the top cover.
  2. Place the bobbin on the bobbin winder shaft so that the spring on the shaft fits into the. ...
  3. Remove the spool cap that is inserted onto the spool pin.
More items...
How do I wind the bobbin? ' Brother
support.brother.com/g/b/faqend.aspx?c=us&lang=en&prod=hf_pc420eus... Search for: How do you fill a bobbin on a Brother sewing machine?
or you could go and look at this link to see if it helps you out some more.
igniter button for SUNJOY PH018PSS Google Search
Nov 21, 2017 | Sewing Machines
Bernina artista 180 bottom stitch bunching
bunching under the material is bird nesting is a result of loose needle thread tension thread the machine up to the point of threading the needle
pull on the thread and you should have a reasonable resistance to pulling the thread
adjust the tension until you get that then thread the needle
while you may be using the tension settings if there is a problem in the tension plates area , the tension will not get high enough regardless of the indicated setting
bobbin tension can be reasonably loose
correct tension is when both threads meet at the center of the materials being sewn
May 25, 2017 | Sewing Machines
Do not know how to replace spool pin and spool cap
It looks like it might just snap into place. Of course that means you have to remove the broken bits which may require a drill, small bit and needle nose pliers.
Sep 10, 2012 | Brother XR-65t Mechanical Sewing Machine
How do you replace the spool pin on a babylock ellure sewing machine
Place the cone of thread on your right, at the back of the machine. Bring the thread up and behind the bobbin winder spindle. (where the bobbin sits) Place the largest spool cap on the empty horizontal spool pin and take the thread through the hole of the spool cap. From this point thread the machine normally. This and many other common questions are found on this link click here http://www.babylock.com/support/FAQ/?FAQ=2 If you have any further questions message me back Thanks Rick
Sep 15, 2011 | Baby Lock Ellure
The needle continues to become unthreaded. It seems the tension on the thread from the spool is too tight. However, the tension adjuster dosen't seem to work. Any suggestions? Shelly
Remove the spool and see if the thread got wound around the spindle. Does this machine require a 'splitter disc'? Needle and thread sizes compatible? Could you have missed a step in threading the machine?
Nov 26, 2010 | Sew Pro QuickStitch SP-402 Mechanical...
Missing parts & manual for A SewPro QuickStitch. Who makes this?
I need a spool pin, cap and bobbin cover for sp 5402, can you help me?
Apr 04, 2009 | Sew Pro QuickStitch SP-402 Mechanical...
Singer 750 how to rewind the bobbing?
1. Push in indent (illustration 1) on hand wheel disc. This will stop the needle from moving.
2. Place spool of thread on spool pin.
3. Slide spool pin holder/cap (illustration 2) firmly over rim of spool to prevent thread from tangling.
4. Lead thread passing it first through the lower slot of the thread guide. Next through the upper slot, leading the thread to the right and around (illustration 3).
5. Wind thread clockwise around front of bobbin winder tension disc (illustration 4).
7. Pass thread end, from inside, through small hole in rim of bobbin.
8. Holding thread end, step on speed controller to run machine until desired amount of thread is wound. (Winding stops automatically once bobbin is full.)
9. Cut thread; push bobbin to the left and remove it from bobbin winder pin.
10. Trim thread end from top of bobbin.
11. Press the bobbin winding indent on hand wheel to its original position. If necessary, turn hand wheel to engage needle movement.
Feb 09, 2009 | Sewing Machines
Sew Pro QuickStitch SP-402 Mechanical Sewing Machine Logo
536 people viewed this question
Top Sew Pro Sewing Machines Experts
Steve
Jamie Sewell
Level 1 Expert
ray gallant
Are you a Sew Pro Sewing Machine Expert? Answer questions, earn points and help others
