Question about HP xw8200 PC Desktop
I have one HP xw8200 implements 8 memory DIMM slots but i can use only 4 memory DIMM slots. Please help me how to enable in CMOS? Thank you.
    Master:
  • 362 Answers
Hello, read this faq for your server; items 24 and 25 should help you.Regards,nicam49
http://bizsupport1.austin.hp.com/bc/docs/support/SupportManual/c00480686/c00480686.pdf
Posted on Feb 14, 2012
3 Suggested Answers
marketex
  • 371 Answers
SOURCE: Installed 1G RAM in DIMM 2 slot(correctly!). Not recognized
Do the two sticks match, all the way down to VENDOR?
Posted on Apr 10, 2009
SOURCE: HP Workstation xw8200
Server 2008 is not detecting your drives, because it does not have drives for what ever hard drive controller you are using. You will need to determine which controller your drives are attached to and load the appropriate driver during setup. I believe this system has built in SCSI and SATA controller and often shipped with add - in storage cards. Our came with a promise sata raid controller.
Posted on Jul 22, 2009
What's your question?PLEASE HOW CAN FIX HP 5100 PRINTER CODE 53.13.03
These error occurred with the printer's memory in DIMM Slot J3 (as labeled on the formatter board). This may be unsupported memory.
To help you troubleshoot the error 53.13.03 appearing on the HP 5100 printer, please follow the steps given below:
- Press the Cancel Job button.
- Turn the printer OFF, and turn it ON again.
- If the message returns, check the memory DIMM in Slot J3 to ensure it is supported memory.
- Move to a different memory slot to determine if the slot is bad.
- Reseat or replace memory in DIMM Slot J3.
http://h20564.www2.hp.com/hpsc/doc/public/display?docId=emr_na-bpl11648
If the message persists, contact HP Support Center for further assistance from the link given below:
http://www8.hp.com/us/en/contact-hp/support.html
GuruAid.com
Jun 02, 2016 | HP Office Equipment & Supplies
Hi I have a HP color Laserjet 5550dn and the screen to print out the error 49.3048, no way to fix it. Thank you very much Fernando
1. Press CANCEL JOB to clear the
print job from the printer
memory.
2. Turn the printer off and then
back on.
3. Try printing a job from a
different software application.
If the job prints, go back to
the first application and try
printing a different file. If the
message appears only with a
certain software application or
print job, contact the software
vendor for assistance.
4. If the message persists with
different software applications
and print jobs, disconnect all
cables to the printer that
connect it to the network or
PC.
5. Turn the printer off.
6. Remove all memory DIMMs
or third-party DIMMs from the
printer. (Do not remove the
firmware DIMM in slot J1.)
7. Remove all EIO devices from
the printer.
8. Turn the printer on.
9. If the error no longer exists,
install each DIMM and EIO
device one at a time, making
sure to turn the printer off and
back on as you install each
device.
10. Replace a DIMM or EIO
device if you determine that it
causes the error.
11. Remember to reconnect all
cables that connect the
printer to the network or
computer.
12. If the error persists, replace
the firmware DIMM.
13. Replace the formatter and
calibrate the printer.
If this helps please mark as FixYa... Get Paid To
Sep 13, 2011 | HP COLOR LASERJET CP 3505 N PRINTER
Hi, On an HP xw8200 motherboard , where do I connect the power on- off connector from the switch on front panel. Thanks
Refer here:
http://bizsupport1.austin.hp.com/bc/docs/support/SupportManual/c00213033/c00213033.pdf
in chapert 4 > system board componenets (page 67 of the manual), it is listed as component number 22.
The front control panel connector is toward the edge of the board from the outermost memory slot, it is right between a yellow connector for a front firewire port and a smaller connector for the hard drive LED.
Feb 25, 2011 | HP xw8200 PC Desktop
Error 53.21 hp color 5550
Doesn't specifically mention the 53.21 error this is the closest they come so you will know it deals with the ram anyway
Control panel message Event
log error
message
Description Recommended action
53.XY.ZZ CHECK RAM
DIMM SLOT X
To continue press
CANCEL JOB
None An error occurred on some
memory of the printer.
X DIMM Type
1 RAM
Y Device Location
1 DIMM Slot 1
2 DIMM Slot 2
3 DIMM Slot 3
4 DIMM Slot 4
ZZ Error Number
0 unsupported memory
1 unrecognized memory
2 unsupported memory size
3 failed RAM test
4 exceeded maximum RAM size
5 invalid DIMM speed
Press CANCEL JOB. If the problem
persists, replace the DIMM card in
the slot indicated.
Click Here for Memory
hope this helps and if so please mark FixYa!!
Jul 30, 2010 | Office Equipment & Supplies
WE ARE GETTING "MEM TEST FAILURE REPLACE DIMM 1" M: 98240 19614
1. Turn the device off and disconnect the power cord.
2. Disconnect all interface cables.
3. Remove the right side panel by sliding it towards the rear of the device until the side slides from the device.
4. Open the access door by pulling on the metal tab.
5. Remove the DIMM from the antistatic package.
6. Hold the DIMM by the edges, and align the notches on the DIMM with the DIMM slot.
(Check that the locks on each side of the DIMM slot are open.)
7. Press the DIMM straight into the slot, and press firmly. Make sure the locks on each side of the DIMM snap into place.
NOTE To remove a DIMM, first release the locks.
8. Close the access door, and press firmly until it snaps into place.
9. To replace the right side panel, line up the alignment arrows and slide the panel toward the front of the device until it latches into place.
10. Reconnect the interface cable(s) and the power cord.
11. Turn the device on.
144-pin dual inline memory module (DIMM)
here's the memory part number/numbers you'll need also:
144-pin 133MHz DDR2 DIMM
Boosts the ability of the device to handle
large or complex print jobs.
32 MB CB420A
64 MB CB421A
128 MB CB422A
256 MB CB423A
Hope this helps and if so please mark fixya
Jun 25, 2010 | HP LaserJet P3005n Printer
RAM error
Populating the memory according to the following guidelines resolves this POST error:
  • DIMMs must be configured in identical pairs.
  • The system will not boot properly if multiple DIMMs of varying density or type are installed in the system.
  • The Entry model servers come with a single 512 MB DIMM. If additional DIMMs are to be added to the existing 512MB DIMM, then another 512 MB DIMM has to be added along with the new pair of DIMMs, or it has to be removed when adding the next pair.
  • Valid DIMM pair combinations use slots 1/5 (Bank A), slots 2/6 (Bank B), slots 3/7 (Bank C), and slots 4/8 (Bank D).
  • Up to 16 GB of memory are supported on the Dual-Core 5000, and 5100 series
  • Up to 32 GB of memory are supported on the Dual-Core 5200 series, Quad-Core 5300, and 5400 series
  • FBDIMMs must be installed in pairs unless operating in single-FBDIMM mode. The server supports single-FBDIMM mode only in FBDIMM slot 1A. FBDIMMs must be installed in sequential order, beginning with bank A.
Jan 27, 2010 | HP Compaq ProLiant ML350 G3 Server
Hi Iwill be glad to assist you:
Description There is a problem with the printer memory. The dual inline memory module (DIMM) that caused the error will not be used. Values of X and Y are as follows: X = DIMM type 0 = read-only memory (ROM) 1 = random-access memory (RAM) Y = device location 0 = internal memory (ROM or RAM) 1 to 4 = DIMM slots 1, 2, 3, or 4 ZZ = error number 0 = unsupported memory 1 = unrecognized memory 2 = unsupported memory size 3 = failed RAM test 4 = exceeded maximum RAM size 6= invalid DIMM speed Action
  1. Press Cancel Job to continue.
  2. If the problem persists, turn the printer power off and then turn the printer power on.
  3. It might be necessary to replace the specified DIMM. Turn the printer power off, and then replace the DIMM that caused the error.
Nov 05, 2009 | HP Color LaserJet 3500 Printer
5 Beep Problem in xw 8200 machine.
5 short beeps the cpu on the motherboard generated an error.
Jun 10, 2009 | HP xw8200 PC Desktop
Increasing memory in e-machine t2240
Hi slcdane 13. One thing with DIMM slots is that, first of all they are color coded there. Im assuming that you have 4 DIMM slots and two of them are one color, and the other two are another color. What that means is that is if One DIMM slot has a RAM module of a certain capacity, then the other DIMM slot of the same color has to contain a RAM module of the same capacity as the first module. Now i am assuming that you have more than two RAM modules and More than 2 DIMM slots. HERE IS AN EASIER EXAMPLE
Lets say you have DIMM slots 1, 2, 3, and 4. Slots 1 and 3 are yellow, and slots 2 and 4 are red. Now lets say you also have 4 Ram modules. 2 of them are each 2 Gigabytes ready, and the other 2 are each 1 Gigabyte ready. Now lets say you take one of the 2 Gigabyte RAM modules and you place it into DIMM slot 1 which is yellow, what this means is that you have to place the other 2 Gigabyte RAM module into the DIMM slot 3 which is also yellow. The remaining 1 Gigabyte modules will have to go into DIMM slots 2 and 4 which are red.
Now do you get it? Same capacity modules have to go into same color slots. Now try it and see.
Dec 31, 2008 | E-Machines T2240 PC Desktop
HP xw8200 PC Desktop Logo
167 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
