Question about Karcher Pressure Washer 1800 PSI 15 GPM Model K348M
I habe lost the manuel for the karcher 289 - Karcher Pressure Washer 1800 PSI 15 GPM Model K348M
Karcher vaporapid 1105 manual
there should be a labeled fill line on the clean water resavore
Mar 26, 2014 | Karcher Vacuums
Lost manual book for toastmaster model 289 like to get new one please thank you mr . hines
Try this link ...
http://kitchen.manualsonline.com/manuals/mfg/toastmaster/289.html
Nov 18, 2010 | Microwave Ovens
My Karcher pulses when on standby,stops when i use the trigger,but it also seems to have lost pressure.Is less than 6 months old but have lost receipt!
Is there a leak from the bottom ?
If so Problem, the leak is from the seam of the Manifold housing. There is a small crack in the seam. A design weakness.. A New Manifold Complete Replacement approx. $61.03.
If not you may replace the Pump Manifold Housing from Karcher, or locate a local Karcher Service Center.
If under 1 year old, and you can find a receipt,Karcher will replace the entire Pressure Washer under warranty.
May 03, 2010 | Karcher K 5.85 M Electric Pressure Washer
Have a Karacher k-3.86 ELECTRIC pressure washer
Check the reset button on the GFCI plug to be sure it's in. Once you pull the trigger keep holding it for at least 10 seconds to let the water push the air out and then it should start running.
Apr 16, 2010 | Karcher K 2.25 R Electric Pressure Washer
I have a Craftsman pressure washer. I have no how to book.
If you contact karcher using the link below, they will e-mail you a manuel in pdf format.
http://www.karcher.com/int/contact.htm
Sep 19, 2009 | Karcher 2500 PSI Pressure Washer
I lost my driver disc. How do I download the Driver?
I habe the complete installation software. I will provide it to you if you still need it. ohmsford2@usa.net
Apr 06, 2009 | Logitech QuickCam Express Web Camera
LOST KARCHER INSTRUCTION BOOK, ARE INSTRUCTIONS ON LINE
Here is the offical link to manuals and warranty cards for the residential models of Karcher Pressure Washers
http://www.karcherresidential.com/us/Service/usermanuals.htm
Jan 22, 2009 | Karcher K2.26 Electric Power Washer
Sound problem
Hello There Jaytee75
You need to has a 5.1 sound card at least to get the sound right on this particular speakers. and like sound blaster cards, Audigy, or X-fi, to has better connection and sound for speakers.
good Luck
Nov 28, 2007 | JBL CREATURE II Computer Speakers
Karcher Pressure Washer  1800 PSI 15 GPM Model K348M Logo
67 people viewed this question
Top Karcher Garden Experts
John Trevino
Are you a Karcher Garden Expert? Answer questions, earn points and help others
