Question about Microsoft Xbox 360 Console
XBOX360 has sound but NO VIDEO
My XBOX360 has sound but no video! It turns on fine, all lights come on, you can hear fan turns on but no video! and its not A/V cables or tv cause tried many different cables and tvs!
  • 903 Answers
The only time this has happened with me (and a few times as well) is when the av cable is not pushed in properly in the back of the console.
Posted on Oct 25, 2008
2 red light on the left of xbox 360...Told overheating...pulled ...cleaned and applied new compound...re-assembled...and when powered on comes on start to show welcome screen...then fans speeds up and te...
this is an overheating issue or so your xbox360 thinks, the problem is actually a bad ramchip that will have a cold solder (or a bridged solder joint)
you will need to reflow the ram chips to fix this issue.
there is a great 6part video guide on YouTube to view for free. 6 videos from the same fellow, each video is a few mins long, and goes over everything for you.
http://www.youtube.com/user/ohiocitysales#p/u and its free unlike some eBook site.
I actually used the same method to fix over 450 Xbox360 units with no problems at all, barring a few (but i have done nearly 500 so you expect a few problems along the way), you just need a few things though like a heat gun and some thermal paste. sounds hard, but it's very easy once you start!
Hope this helps in some way. the videos are more about the 3 red light error, but the fix is pretty much the same.
Jan 02, 2010 | Video Game Consoles & Games
Xbox360 showing 4 red lights then 2 red lights when I turn it on.
yes is call the ring of death . but you need to take your xbox to some where to repair it . take it to gamestop......search it in youtube ring of death
Dec 24, 2009 | Microsoft Xbox 360 Console
My xbox360 dosent shoe the picture but all i hear is the sound
check your video output from your game console and into your tv. Make sure that there are no loose connections, turn on the game console and check the video by changing the video mode. :)
if you can hear sounds. then theres no problem with the game console, just check for the video input and output of the game console.
Hope this will help you out
Aug 09, 2009 | Microsoft Xbox 360 Console
XBOX360 RED LIGHTS FLASH ON CONSOLE AND I GET NO PICTURE?
this problem occurs:
  • When there is too much current.
  • When the voltage is too high.
  • When the temperature of the power supply is too high
  • if you have the console plugged into an extension lead try plugging directly into the wall, but 1st, turn off your console and leave power plugged in to allow fans to continue cooling the system.. after fans switch off, carefully plug out power cord and allow cord and console to cool in a well ventilated area for 24 hours. if its still red you may need to replace your power cord as it may have overheated
    Apr 02, 2009 | Video Game Consoles & Games
    Xbox360 working fine, sound ok but no vision
    it might be wires chek em all i had the same thing but i fixed it it was my wires if its not wires its your video chip melted and ur xbox360 needs repair
    Dec 14, 2008 | Microsoft Xbox 360 Console
    HDMI XBOX360 Elite -"No Signal"
    The connection order can be a key issue as to whether or not the HDMI signals will pass through the system. For best results the receiver should be turned on first, then the source device(s) and then the display. The reason for this has to do with getting the equipment to handshake properly for the HDCP protocol.
    If HDMI video will not pass through your receiver, you may with to just connect the xbox using the component cables. Since component will pass through 720p and your TV is 1080i you should expect the same qualtiy and a more crisp picture.
    Oct 12, 2008 | Denon AVR-2307Ci Receiver
    Xbox 360
    make sure the TV in the correct mode, VIDEO, COMPONENTS.
    if it was working before. a button might have been pushed by accident.
    also your xbox360 may have died, you can try it on another TV to be sure, even though the lights come on doesnt mean the xbox360 is working.
    Jun 16, 2008 | Microsoft Xbox 360 Console
    No display only sound
    Error Codes XBOX360
    http://www.llamma.com/xbox360/repair/Xbox-360-error-codes.htm
    send it it back to them for repair
    Jan 18, 2008 | Microsoft Xbox 360 Console
    Microsoft Xbox 360 Console Logo
    57 people viewed this question
    Top Microsoft Video Game Consoles & Games Experts
    marley mcelhinney
    Tre Elkins
    Martin Murray
    Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
