Question about Electronics - Others
Folder is showing shortcut and couldnot open the file
Plz tell the way to open
  • 27,725 Answers
Click start click to open on my computer you should see your Usb drive E: right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions make sure all 3 boxes are ticked full control change and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
click start right click on my computer select open
Right click the icon of your Usb Drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
if you need more help with this post a reply
hope this helps you
Posted on Feb 26, 2012
3 Suggested Answers
SOURCE: Hi i have 2gb sd
SaveMyUsb.com can recover data from most damaged and faulty flash memory devices including memory cards and usb flash drives for just £39 - give them a try it worked for me!
Posted on Dec 31, 2010
  • 181 Answers
SOURCE: my memory card is showing
This is one VIRUS. Please Scan that sandisk with any antivirus. just you can use Kaspersky.
The manual procedure to see all the fiels is:
1. Connect the USB drive
2. go to command prompt. Run-> cmd
3. goto sandisk drive
by default c:\> prompt appears. type the drive letter with colon.
c:\> E: (if E drive assigned to your sandisk)
you can see in mycomputer: drive letter may be e: or f:
4.After getting that drive as prompt. like e:\>
Then type these commands.
attrib -s -r -h *.* /s
attrib -s -r -h desktop.ini /s
attrib -s -r -h autorun.inf /s
del desktop.ini /s
del autorun.inf /s
rd recycled /s
rd recycler /s
rd $recycled /s
5. Then goto My computer. you will find the folders and shortcuts also
please remove the SHOTCUTS only...
This will helps you .,
Posted on Jun 17, 2011
Can't find my Google icon
Fix All My Computer Shortcut Links
Computers often use shortcut links to make it easier for users to locate and open files.
These links are commonly placed in a folder easily accessible to users, such as a desktop folder.
When a shortcut is created, it is given directory information and an icon.
If the file associated with a shortcut is later moved, the shortcut may fail to locate the file.
When this problem occurs, you need to update the shortcut's directory information.
This process is often automated by operating systems, but in a some instances, you need to repair shortcuts manually
Right-click on a broken shortcut link's icon.
Select the "Properties" option. Locate the "Target" box and copy its information into your clipboard using the Ctrl and C keys.
Open the "My Computer" folder on your computer and paste the target information into the folder's address bar using the Ctrl and V keys.
If the address bar is not viewable, you may need to enable it in the folder's settings.
Find address bar options in the "View" menu under "Toolbars."
The file's target path folder will open.
Locate the file in the target path folder.
If the file is not present, the target path is inaccurate and likely the cause of the shortcut link error.
Locate the file in its correct folder.
Browse folders or search for the file by typing the file name into the "Start" menu.
After finding the file, open the properties of the shortcut link icon again.
Copy the file's correct path, from the containing folder's address bar, and paste it in to the "Target" box, replacing the incorrect link.
Another way to find a file's target path is by right clicking on the file and selecting Properties.
You can find accurate target information in the "Target" box, provided the icon is the original file icon and not a shortcut.
Aug 11, 2013 | Computers & Internet
Tip
Recreate the Show Desktop icon on the Quick Launch toolbar
To re-create the Show Desktop icon on the Quick Launch
toolbar, follow these steps....
1. Use any text editor (such as Notepad) to create a
file with the following lines:
[Shell]
Command=2
IconFile=explorer.exe,3
[Taskbar]
Command=ToggleDesktop
2. Save the new file as a file named Show Desktop.scf
in the WindowsSystem or WinntSystem32 folder. Note
that Notepad may automatically append a .txt extension
to the file name. Remove this extension if Notepad
adds it. These steps do not work if the file is named
Show Desktop.scf.txt.
3. Quit Notepad.
4. Using Windows Explorer or My Computer, right-click
the Show Desktop .scf file, and then click Create
Shortcut.
5. Copy the new shortcut to the appropriate folder. In
Microsoft Windows 95 or Windows 98, copy the shortcut
to this folder: WindowsApplication DataMicrosoftInternet
ExplorerQuick Launch
In Microsoft Windows NT or Microsoft Windows 2000,
copy the shortcut to this folder: WinNTSystem32
In Microsoft Windows XP, copy the shortcut to the
following folder: WINDOWSSystem32ConfigSystemprofileApplication
DataMicrosoftInternet ExplorerQuick Launch
6. Rename the shortcut to Desktop.
The Show Desktop icon automatically appears on the
Quick Launch toolbar.
Reference:
http://support.microsoft.com/kb/190355/EN-US/
on Jun 24, 2010 | Microsoft Windows XP Professional SP2
Start
Jun 07, 2013 | IwantSoft Free Keylogger
Samsung s2 portable, folders are showed as shortcuts !
OK you harddrive is infected with Malware. This Malware creats shortcuts of each folder and Hide the all those your main folder.
You can scan your Hardrive with fully updated Anti Virus apllication .
To see all your original folder you can enable your Shown hidden File option from your Folder option--View--uncheck show hidden files and folder--and uncheck hide protected operating system files.
Here is the step to unhide your all files and folder in one go.
Step 1:
Click on the below link and download the file "AutorunExterminator"
http://en.kioskea.net/download/download-11613-autorun-exterminator
Extract it --> Double-click on "AutorunExterminator" --> Plug your Hard drive now.
This will remove the autorun.inf files from your flash drive and also from drives.
Step 2:
Click on "Start" -->Run --> type cmd and click on OK.
Here I assume your flash drive letter as G:
Enter this command.
attrib -h -r -s /s /d g:\*.*
You can copy the above command --> Right-click in the Command Prompt and
paste it.
Note : Don't forget to replace the letter g with your flash drive letter.
Now press "Enter".
this should solve your problem.
Jul 27, 2012 | Samsung S2 - 1TB USB 2.0 Portable...
I have S2 portable 640gb external hard drive. Do not open the main folder with info and gives me only shortcuts and no way to my folders
Do you think my problem is a cable wear or the device itself
and how can get access to my data
can anyone hepl me
please
May 05, 2012 | Samsung S2 Portable 640 GB USB 30 External...
ALL folder turned into shortcuts and i really don't know how to get back my stuff. You know the hard drive has music shortcut document shortcut. Somebody help me.
You must have had them all selected and then dragged them somewhere, then maybe dragged back, creating shortcuts at that location. This could be done accidentally by holding the ALT key (or if that key is stuck down) while dragging them back or by holding the right mouse button instead of the left. If it was the right-button thing though, you would have had to also left-click on 'Create Shortcut' on the menu that popped up.
If this is what happened your 'real' folders will be wherever you dragged TO and the shortcuts will be wherever you dragged BACK to.
The fact that there are shortcuts is not alarming. Your originals must be somewhere! Use the Search function to search for any file or folder name you can remember. Start at the root of the system (My Computer) to search everything; it could take a while so be patient. When you find the missing folders just select them all and drag back to where they belong (or Cut from current location, Paste in new location).
Feb 18, 2011 | Intel Computers & Internet
Can not open itunes
Some times a newly installed version of iTunes for Windows will not open. Even though it may still shows as running in the Windows Task Manager(Ctrl+Alt+Delete-click Task Manager).
Resolution:
1. From the Start menu, click Computer.
2. In the Organize menu, click Folder and Search Options.
3. Click the View tab.
4. In the "Advanced settings" pane under "Hidden files and folders" make sure that the "Show hidden files and folders" option is selected. And Click OK.
5. Navigate to the following location by either typing it into the address bar, copying and pasting it into the address bar, or clicking through the folder hierarchy listed: C:\Program Data\Apple Computer\iTunes\SC Info
6. Right-click the SC Info.sidb file shown and on the shortcut menu, click Delete
7. Right-click the SC Info.sidd file shown and on the shortcut menu, click Delete.
8. Restart the computer and open iTunes.
*HOPE IT IS FIXED*
Oct 22, 2010 | Microsoft Windows Vista Ultimate Edition
What do I have to do to start copying file to the external hard drive. Looks like I am just getting shortcuts. The file folders have the small black arrow indicating a shortcut
Hi right click on the file you want to put on the ext. hard drive. You will see a option "send to" click that then choose the ext hard drive. This will sent the whole file and not just a shortcut. Thank you for using Fixya.com
Feb 11, 2010 | Computers & Internet
Plz tell me the cd key for cricket2007
2rbk-n522-8aw3-v8aj-5rld
after installing ur game
right click and open the cd there will be a folder named CRACK open this folder and copy the files in this folder
now right click on the cricket2007 icon on ur desktop and click properties then find target and paste the copied files in the window that will open up replace the files and click ok
now enjoy the game
Jul 01, 2009 | EA Sports Cricket 07 for Windows
Zone Alarm will not start up when I turn on my computer?
You can ADD the "Zone alarm" executable to your windows startup.
This can be done in 1 simple way.
1. Locate the "Zonealarm.exe" in your "Program files" folder. Usually your Program Files folder will be here "C:\Program Files". Just run a search for "Zonealarm.exe" inside this folder.
2. After locating the "Zonealarm.exe" file, right-click on that file. And select "Create Shortcut".
3. After that you'll find a "Zonealarm.exe" Shortcut file or icon inside the same folder.
4. Just COPY or CUT the shortcut file.
5. Now Right click on the "START" button.
6. Select "Open all users".
7. This will open a windows explorer window. Locate "Programs" folder and Enter it.
8. Inside you should locate "Startup" folder and enter it.
9. Once u ar inside the "Startup" folder, paste the already copied "Zonealarm.exe" shortcut file.
10. That's it. Now try re-starting the system.
Thanks
Dec 18, 2008 | Microsoft Windows XP Home Edition
Electronics - Others Logo
27 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
